Can Upload Bootloader To Attiny85 But Can't Upload Code
Having problems uploading the blink sketch after building this Uno programming shield. Pretty sure the shield is correct after checking multiple setup guides on wiring.
Followed these steps.
1 - Added attiny board list to Preferences.
https://raw.githubusercontent.com/sleemanj/optiboot/master/dists/package_gogo_diy_attiny_index.json
2 - Upload ArduinoISP sketch to the Uno.
3 - Selected the Attiny85 board, changed programmer to Arduino As ISP, then uploaded the bootloader successfully.
4 - Opened the Attiny85 Blink sketch and compiled without error.
5 - When uploading sketch the following error occurs.
Arduino: 1.8.11 (Mac OS X), Board: "ATtiny85, Yes (Normal Arduino Serial/USB Upload), 8MHz Internal Oscillator, Millis and Tone Available, Bin, Hex, Dec Supported, Better Or Equal 1.666% Error (Default), LTO Enabled, 2.7v, Default, Default, Default"
Sketch uses 630 bytes (8%) of program storage space. Maximum is 7634 bytes.
Global variables use 18 bytes (3%) of dynamic memory, leaving 494 bytes for local variables. Maximum is 512 bytes.
/Users/t440plenovo/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino14/bin/avrdude -C/Users/t440plenovo/Library/Arduino15/packages/diy_attiny/hardware/avr/2018.9.9/avrdude.conf -v -pattiny85 -carduino -P/dev/cu.usbmodem14401 -b38400 -D -Uflash:w:/var/folders/_l/y832j5q54ljg1_jf260dg6400000gn/T/arduino_build_12156/Blink.ino.hex:i
avrdude: Version 6.3-20171130
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/Users/t440plenovo/Library/Arduino15/packages/diy_attiny/hardware/avr/2018.9.9/avrdude.conf"
User configuration file is "/Users/t440plenovo/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/cu.usbmodem14401
Using Programmer : arduino
Overriding Baud Rate : 38400
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x66
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xe0
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x66
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xe0
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x66
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xe0
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x66
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xe0
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x66
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xe0
avrdude done. Thank you.
An error occurred while uploading the sketch
Hoping for some clues on what is wrong or where to look. Thanks for your help.
The tutorial shows Arduino IDE 1.8.1, When was this IDE version available?
Maybe it works with this option:
