Can we control minimum voltage to maximum voltage using arduino
Hello every one I have a question here. Can we control minimum voltage to maximum voltage using arduino?
Sure, I can use an Arduino to control minimum and maximum voltage. I do not know of your coding and electronic skills to give you an honest answer to weather you can do it. What I suggest is that you give it a try and your own success or failure will let you know if you can do it.
#include <FastLED.h>
#define LED_PIN     7
#define NUM_LEDS    20
const int DUTY = 64;
  FastLED.addLeds<WS2812, LED_PIN, GRB>(leds, NUM_LEDS);
  for (int i = 0; i <= 19; i++) {
    leds[i] = CRGB ( 0, 0, 255);
    FastLED.show();
    delay(40);
  for (int i = 19; i >= 0; i--) {
    leds[i] = CRGB ( 255, 0, 0);
    FastLED.show();
    delay(40);
LED_BRIGHTNESS:1:10: fatal error: FastLED.h: No such file or directory
compilation terminated.
exit status 1
Can anyone rectify this error
did you install the fast led library? Did you try the example code?
The posted code does not show the Arduino being used as a voltage controller.
What this problem has to do with your initial question?
here is some instructions that I am not sue if you will be able to follow, with me being unfamiliar with your ability to follow instructions, that you may find helpful on installing fastled.
GitHub - stnkl/FastLEDHub: Control multiple FastLED lightstrip animations on the ESP8266 and ESP32 without reuploading.
Thanks, I tried this library still I'm getting this error.
LED_BRIGHTNESS:1:10: fatal error: FastLEDHub.h: No such file or directory
 #include <FastLEDHub.h>
exit status 1
So you need to install the FastLEDHub.h library too.
Please read and TRY TO UNDERSTAND the error messages yourself.
Did you install the library?
Yes, I have install the library
Did you install the library to Arduino/libraries/FastLEDHub-master/FastLEDHub-master? The library should be in Arduino/libraries/FastLEDHub.
I am sure you did not follow this instruction
C:\Users\DELL\Documents\Arduino\libraries\FastLEDHub\FastLEDHub
exit status 1
I have send library path and error
#define LED_PIN     7
#define NUM_LEDS    20
    FastLED.show();
    delay(40);
    FastLED.show();
    delay(40);
Why not put the library into
C:\Users\DELL\Documents\Arduino\libraries\FastLEDHub\ where it belongs?
do you see the difference between
and
And also can you chek the code again?
Why did you created TWO directories
enclosed one in another?
I did not create 2 directories. I am trying to let the OP know they created 2 directories but the OP keeps missing the clue.
