halllo
i am just trying to make an digital cluster this time
and i want to know if it is posible to drive those two chips from one arduino board
all of my pins are free
thanks a lot
halllo
thanks a lot
The 74hc595 needs 3 pins... I don't know what the max7219 is, but I don't think that it would need more than the remaining 9 pins...
The 7219 has an SPI-style interface that uses four pins so you can use both.
yes but i cant
not sure wich pins i have to use
i have max7219 on 10 11 12 as the example and then
74hc595 does not work on 7 8 9 or 2 3 4
maybe we have to do somethink with the timers?
thanks a lot
yes but i cant
thanks a lot
We might be able to help, but only if you post your code and possibly a wiring drawing. There is no reason that the Arduino couldn't handle these two chips.
Lefty
just forgot to declare the output pins on the void setup
thanks a lot
