can we give input to mcp2515 from CANoe
Welcome to the forum
Your topic was MOVED to its current forum category which is more appropriate than the original as it has nothing to do with Installation and Troubleshooting of the IDE
No? Not directly at least. CANoe is going to be designed to use Vector's professional hardware (which tends to be expensive), not cobbled together hobbyist jank.
Your question is very ambiguous, What are you asking. What are you connecting? Just for information: You can connect to CANoe on the CAN side to a transceiver connected to the MPC2515 without a problem. You just need to follow the rules. It is a very good tool.
CANoe is a development and testing software tool from Vector Informatik GmbH. The software is primarily used by automotive manufacturers and electronic control unit (ECU) suppliers for development, analysis, simulation, testing, diagnostics and start-up of ECU networks and individual ECUs.
Hi, @vaj1889
Welcome to the forum.
Can you please tell us your electronics, programming, arduino, hardware experience?
Can you tell us what the application of your project is?
Thanks.. Tom..
thank you
