i build new type stopwatch with 2, 7 segment display with 5 digit.my problem is how to display the both display with same number.i try add the output,that mean the data,clock and lath output have double pin.but it can't work.let see the code.
unsigned long currentmicros = 0;
unsigned long previousmicros = 0;
unsigned long interval = 1000;
unsigned long elapsedmicros = 0;
byte trigger = 2;
byte started = 0;
byte stopped = 0;
byte latchpin = 7, 8; // connect to pin 12 on the 74HC595
byte clockpin = 6, 12; // connect to pin 11 on the 74HC595
byte datapin = 5, 11; // connect to pin 14 on the 74HC595
int ones_seconds = 0;
int tens_seconds = 0;
int ones_minutes = 0;
int tens_minutes = 0;
int tenths = 0;
int hundredths= 0;
int thousandths = 0;
byte inPinstat;
int segdisp[10] = {
63,6,91,79,102,109,125,7,127,111 }; //segment references using 74HC595 Shift Registers
//The above numbers light up different segments of a digit
int time_update = 0;// added new flag
pinMode(latchpin, OUTPUT);
pinMode(clockpin, OUTPUT);
pinMode(datapin, OUTPUT);
pinMode(trigger, INPUT);////stat/stop.
digitalWrite(latchpin, LOW); // send the digits down to the shift registers!
shiftOut(datapin, clockpin, MSBFIRST, segdisp[tens_seconds]);
shiftOut(datapin, clockpin, MSBFIRST, segdisp[ones_seconds]);
shiftOut(datapin, clockpin, MSBFIRST, segdisp[tenths]);
shiftOut(datapin, clockpin, MSBFIRST, segdisp[hundredths]);
shiftOut(datapin, clockpin, MSBFIRST, segdisp[thousandths]);
digitalWrite(latchpin, HIGH);
inPinstat = digitalRead(trigger);
if(inPinstat == HIGH)
currentmicros = micros(); // read the time.
elapsedmicros = currentmicros - previousmicros;
if (elapsedmicros >= interval) // 10 milliseconds have gone by
previousmicros = previousmicros + elapsedmicros; // save the time for the next comparison
time_update = 1; // set flag to shift out the new time
if (time_update == 1){ // no updating if not at 10ms interval, skip this whole section
// increment the counters, roll as needed, shift the digits out
time_update = 0; // reset for next pass thru
thousandths = thousandths +1;
if (thousandths == 10){
thousandths = 0;
hundredths = hundredths +1;
if (hundredths == 10){
hundredths = 0;
tenths = tenths +1;
if (tenths == 10){
tenths = 0;
ones_seconds = ones_seconds +1;
if (ones_seconds == 10){
ones_seconds = 0;
tens_seconds = tens_seconds +1;
if (tens_seconds == 6){
tens_seconds = 0;
ones_minutes = ones_minutes +1;
