I have fair experience in C++ programming and new to Electronics. Currently learning to program in Arduino.
I am working on a personal project similar to a Point of Sale machine using Arduino Due.
For this reason I can power my arduino with power jack using 5V/ 3A power adapter to power both Arduino and thermal printer.
The 7 inch display uses few pins along with VIN and 5V pin. Now I need VIN pin for connecting thermal printer but it is already occupied by the TFT display. Any other digital pin using pinMode(pin,OUTPUT) and digitalWrite(pin,HIGH) gives only 3.3V.
Can we simulate a software VIN pin in arduino? or how can I draw 5V output from Arduino for connecting the thermal printer.
Please suggest as I do not want to purchase another thermal printer again.
Thanks in advance.
How much current draws your thermal printer ? (IMO it would be better to power the thermal printer from an AC/DC converter).
The DUE powered thru the USB cable can't provide more than 500 mA. When powered with a battery pack thru the jack, the DUE can provide 800 mA (it's cautious to remain way under 800 mA though).
There are 5 hardware serial plus a software serial library from antodom on github. I would be very surprised if your display used all available pins for hardware serial.
There is a handy screw shield available for the DUE formfactor at crossroadsfencing.com:
What you need to do is have your 5V/3A supply split into 3 connectors so one goes to your Due, One to your TFT and one to your thermal printer. If your power supply is a barrel jack, they make adaptors than turn those into 2 screw terminals which you could use, along with some wire. Or, you could cut the barrel connector off and solder up some wires yourself.
ard_newbie:
Thanks @ard_newbie for the reply. The thermal printer I mentioned here requires 5V 3 A. I was looking for ways to simulate a VIN pin or redirect or copy the VIN pin to some other un used digital pin. Not the software serial. I'll be looking at the link you shared.
blh64:
