Can we use 4051 and 595 in VVVV with Arduino...???
im trying to exprimennting with vvvv is sit possible to use 4051 and vvvv to together??? any code or sketch or link????
What is vvvv?
its s software like Grasshopper...
vvvv is a hybrid visual/textual live-programming environment for easy prototyping and development... where you can connect arduino by firmata n all..
im trying to connect 595 and 4051 with vvvv ...
OK that is a start, don't expect everyone to know obscure stuff. It might be big in your world, but here is not your world. :)
Please read this:- How to use this forum It requests that you post links to stuff that is obscure.
If as you say the Arduino end runs firmata, then it should be just a matter of programming the "other end" to send the firmata commands to the Arduino to do what you want. The exact commands will depend on how you wire up the parts to the Arduino.
Note that firmata turns the Arduino into a lobotomized input / output board so you have none of the "intelligence" or processing power normally associated with the Arduino. So there is no Arduino sketch that can help you here, you have to do all the work from vvvv.
