Can we use arduino for delay generator
I am new to this. I am working on a projec in which i need to introduce 20us of delay to input pulse. can I use arduino to generate delay using trigger pulse.
Thanks in advance
An Uno us resolution is 5us. An ESP32's resolution is in the 12.5pico second range.
Yes, a microcontroller can introduce a delay.
Here in this code I introduce a 280us delay.
#include <WiFi.h>
#include <PubSubClient.h>
#include "certs.h" // include the connection infor for WiFi and MQTT
#include "sdkconfig.h" // used for log printing
#include "esp_system.h"
#include "freertos/FreeRTOS.h" //freeRTOS items to be used
#include "freertos/task.h"
#include <SPI.h>
#include <Adafruit_Sensor.h>
#include "Adafruit_BME680.h"
#include <Adafruit_GFX.h>    // Core graphics library
#include <Adafruit_ST7789.h> // Hardware-specific library for ST7789
#include <driver/adc.h>
#include "esp32-hal-ledc.h"
#include <HardwareSerial.h>
#include <SimpleKalmanFilter.h>
#include "MHZ19.h"
#include <ESP32Time.h>
#include <SolarCalculator.h>
ESP32Time rtc;
MHZ19 myMHZ19;
Adafruit_BME680 bme( GPIO_NUM_5 ); // use hardware SPI, set GPIO pin to use
//Adafruit_ST7789 tft = Adafruit_ST7789( TFT_CS     , TFT_DC    , TFT_MOSI   , TFT_SCLK   , TFT_RST     );
Adafruit_ST7789 tft   = Adafruit_ST7789( GPIO_NUM_15, GPIO_NUM_0, GPIO_NUM_13, GPIO_NUM_14, GPIO_NUM_22 );
WiFiClient   wifiClient; // do the WiFi instantiation thing
PubSubClient MQTTclient( mqtt_server, mqtt_port, wifiClient ); //do the MQTT instantiation thing
#define evtDoParticleRead     ( 1 << 0 ) // declare an event
#define evtWaitForBME         ( 1 << 1 )
#define evtParseMQTT          ( 1 << 3 )
EventGroupHandle_t eg; // variable for the event group handle
QueueHandle_t xQ_WindChillDewPoint;
QueueHandle_t xQ_eData; // environmental data to be displayed on the screen
struct stu_eData
  float  Temperature = 0.0f;
  float  Pressure    = 0.0f;
  float  Humidity    = 0.0f;
  float  IAQ         = 0.0f; // Index Air Quality
  float  RM0         = 0.0f; // Remaining Moisture from sensor 0
  float  PM2         = 0.0f; // particles in air
  float  WS          = 0.0f; // wind speed
  String WD          = "";   // wind direction
  float  RF          = 0.0f; // rainfall
  float  WSV         = 0.0f; // weather station volts
  float  WSC         = 0.0f; // weather station current
  float  WSP         = 0.0f; // weather station power
  float  WindChill   = 0.0f; //windchill
  float  DewPoint    = 0.0f; //dew point or dew index
  int    SunRiseHr   = 0;    // sunrise hour
  int    SunRiseMin  = 0;    //sunrise minute
  int    SunSetHr    = 0;    //sunset hour
  int    SunSetMin   = 0;    //sunset minute
  int    DuskHr      = 0;    //dusk
  int    DuskMin     = 0;    //dusk
  int    DawnHr      = 0;    // dawn
  int    DawnMin     = 0;    // dawn
  int    TransitHr   = 0;    // 'noon' time
  int    TransitMin  = 0;    // 'noon' time
  double azimuth     = 0.0f;   // Sun's azimuth, in degrees
  double elevation   = 0.0f;     // Sun's elevation, in degrees
  float  CO2         = 0.0f;
} x_eData; // environmental data
QueueHandle_t xQ_Message; // payload and topic queue of MQTT payload and topic
const int payloadSize = 100;
struct stu_message
  char payload [payloadSize] = {'\0'};
  String topic ;
} x_message;
const float oGasResistanceBaseLine = 149598.0f;
int mqttOK = 0;
volatile bool TimeSet = false;
esp_timer_handle_t oneshot_timer; //veriable to store the hardware timer handle
SemaphoreHandle_t sema_MQTT_KeepAlive;
SemaphoreHandle_t sema_PublishPM;
SemaphoreHandle_t sema_mqttOK;
//serial(2) = pin25 RX, pin26 TX
HardwareSerial co2Serial ( 2 );
// interrupt service routine for WiFi events put into IRAM
void IRAM_ATTR WiFiEvent(WiFiEvent_t event)
  switch (event) {
    case SYSTEM_EVENT_STA_CONNECTED:
      log_i("Connected to WiFi access point");
    case SYSTEM_EVENT_STA_DISCONNECTED:
      log_i("Disconnected from WiFi access point");
    case SYSTEM_EVENT_AP_STADISCONNECTED:
      log_i("WiFi client disconnected");
    default: break;
} // void IRAM_ATTR WiFiEvent(WiFiEvent_t event)
void IRAM_ATTR oneshot_timer_callback( void* arg )
  BaseType_t xHigherPriorityTaskWoken;
  xEventGroupSetBitsFromISR( eg, evtDoParticleRead, &xHigherPriorityTaskWoken );
} //void IRAM_ATTR oneshot_timer_callback( void* arg )
void IRAM_ATTR mqttCallback(char* topic, byte * payload, unsigned int length)
  memset( x_message.payload, '\0', payloadSize ); // clear payload char buffer
  x_message.topic = ""; //clear topic string buffer
  x_message.topic = topic; //store new topic
  int i = 0; // extract payload
  for ( i; i < length; i++)
    x_message.payload[i] = ((char)payload[i]);
  x_message.payload[i] = '\0';
  xQueueOverwrite( xQ_Message, (void *) &x_message );// send data to queue
} // void mqttCallback(char* topic, byte* payload, unsigned int length)
  co2Serial.begin( 9600 , SERIAL_8N1, 25, 26 ); // pin25 RX, pin26 TX
  x_eData.WD.reserve(50);
  x_message.topic.reserve( payloadSize );
  xQ_WindChillDewPoint = xQueueCreate( 1, sizeof(stu_eData) );
  xQ_Message  = xQueueCreate( 1, sizeof(stu_message) );
  xQ_eData    = xQueueCreate( 1, sizeof(stu_eData) ); // sends a queue copy of the structure
  sema_PublishPM = xSemaphoreCreateBinary();
  xSemaphoreGive( sema_PublishPM );
  sema_mqttOK    =  xSemaphoreCreateBinary();
  xSemaphoreGive( sema_mqttOK );
  ledcSetup( 4, 12000, 8 ); // ledc: 4  => Group: 0, Channel: 2, Timer: 1, led frequency, resolution  bits
  ledcAttachPin( GPIO_NUM_12, 4 );   // gpio number and channel
  ledcWrite( 4, 0 ); // write to channel number 4
  eg = xEventGroupCreate(); // get an event group handle
  // output mode
  gpio_config_t io_cfg = {}; // initialize the gpio configuration structure
  io_cfg.mode = GPIO_MODE_OUTPUT; // set gpio mode
  io_cfg.pin_bit_mask = ( (1ULL << GPIO_NUM_4) ); //bit mask of the pins to set
  gpio_config(&io_cfg); // configure the gpio based upon the parameters as set in the configuration structure
  gpio_set_level( GPIO_NUM_4, LOW); // set air particle sensor trigger pin to LOW
  // input mode
  io_cfg = {}; // reinitialize the gpio configuration structure
  io_cfg.mode = GPIO_MODE_INPUT; // set gpio mode. GPIO_NUM_0 input from water level sensor
  io_cfg.pin_bit_mask = ( (1ULL << GPIO_NUM_0) | (1ULL << GPIO_NUM_27)  ); //bit mask of the pins to set, assign gpio number to be configured
  // set up A:D channels, refer: https://dl.espressif.com/doc/esp-idf/latest/api-reference/peripherals/adc.html
  adc1_config_width(ADC_WIDTH_12Bit);
  adc1_config_channel_atten(ADC1_CHANNEL_0, ADC_ATTEN_DB_11);// using GPIO 36
  // https://docs.espressif.com/projects/esp-idf/en/latest/esp32/api-reference/system/esp_timer.html?highlight=hardware%20timer High Resoultion Timer API
  esp_timer_create_args_t oneshot_timer_args = {}; // initialize High Resoulition Timer (HRT) configuration structure
  oneshot_timer_args.callback = &oneshot_timer_callback; // configure for callback, name of callback function
  esp_timer_create( &oneshot_timer_args, &oneshot_timer ); // assign configuration to the HRT, receive timer handle
  xTaskCreatePinnedToCore( fparseMQTT, "fparseMQTT", 7000,  NULL, 5, NULL, 1 );
  xTaskCreatePinnedToCore( MQTTkeepalive, "MQTTkeepalive", 5000, NULL, 6, NULL, 1 );
  xTaskCreatePinnedToCore( DoTheBME680Thing, "DoTheBME280Thing", 20000, NULL, 5, NULL, 1);
  xTaskCreatePinnedToCore( fDoParticleDetector, "fDoParticleDetector", 6000, NULL, 3, NULL, 1 );
  xTaskCreatePinnedToCore( fmqttWatchDog, "fmqttWatchDog", 5000, NULL, 3, NULL, 1 );
  xTaskCreatePinnedToCore( fDoTheDisplayThing, "fDoTheDisplayThing", 23000, NULL, 3, NULL, 1 );
  xTaskCreatePinnedToCore( fScreenBlanking, "fScreenBlanking", 2000, NULL, 2, NULL, 1 );
  xTaskCreatePinnedToCore( fGetCO2, "fGetCO2", 4500, NULL, 2, NULL, 1 );
  xTaskCreatePinnedToCore( fParseDewPointWindChill, "fParseDewPointWindChill", 4500, NULL, 2, NULL, 1 );
  xTaskCreatePinnedToCore( fSolarCalculations, "fSolarCalculations", 10000, NULL, 2, NULL, 1 );
} //void setup()
void fSolarCalculations ( void *pvParameters )
  double sunrise;  // Sunrise, in hours (UTC)
  double transit;  // Solar noon, in hours (UTC)
  double sunset;   // Sunset, in hours (UTC)
  double dawn;     // Civil dawn, in hours (UTC)
  double dusk;     // Civil dusk, in hours (UTC)
  //double rt_ascension;  // Sun's right ascension, in degrees
  //double declination;   // Sun's declination, in degrees
  const  float time_zone = -7.0f;
  TickType_t xLastWakeTime = xTaskGetTickCount();
  const TickType_t xFrequency = 1000; //delay for mS
  int count  = 3590;
  int monthX = 1;
  int dayX   = 1;
  for (;;)
    if ( count % 60 == 0 )
      if ( (rtc.getHour(true) >= 12) & (rtc.getHour(true) <= 23) )
        dayX = 0;
        dayX = 1;
      calcSunriseSunset( rtc.getYear(), (rtc.getMonth() + monthX) , (rtc.getDay() + dayX), latitude, longitude, transit, sunrise, sunset );  // Calculate the times of sunrise, transit and sunset
      sunrise += time_zone;
      sunset  += time_zone;
      SolarTimeFormat( sunrise, 0 );
      SolarTimeFormat( sunset, 1 );
      calcCivilDawnDusk( rtc.getYear(), (rtc.getMonth() + monthX) , rtc.getDay(), latitude, longitude, transit, dawn, dusk); // Calculate the times of civil dawn and dusk (UTC)
      transit += time_zone;
      dawn    += time_zone;
      dusk    += time_zone;
      SolarTimeFormat( dawn, 2 );
      SolarTimeFormat( dusk, 3 );
      SolarTimeFormat( transit, 4 );
      calcHorizontalCoordinates( rtc.getYear(), (rtc.getMonth() + monthX) , rtc.getDay(),  rtc.getHour(true) , rtc.getMinute(), rtc.getSecond(), latitude, longitude, x_eData.azimuth, x_eData.elevation );
      x_eData.azimuth   = double(round(x_eData.azimuth * 100)) / 100; // Round to two decimal places
      x_eData.elevation = double(round(x_eData.elevation * 100)) / 100;
      if (count >= 3600 )
        SolarTimeFormat( 0.0f, 5 ); // publish MQTT
        log_i( "Hour:%d Azimuth %f, elevation %f, transit %dhr %dmin, dawn %dhr %dmin, dusk %dhr %dmin", rtc.getHour(true), x_eData.azimuth, x_eData.elevation, x_eData.TransitHr, x_eData.TransitMin, x_eData.DawnHr, x_eData.DawnMin, x_eData.DuskHr, x_eData.DuskMin );
        count = 0;
    //log_i( " high watermark % d",  uxTaskGetStackHighWaterMark( NULL ) );
    vTaskDelayUntil( &xLastWakeTime, xFrequency );
    count++;
  } //for (;;)
  vTaskDelete( NULL );
} //void fSolarCalculations ( )
void SolarTimeFormat( double h, int i  )
  int hours   = 0;
  int minutes = 0;
  if ( h != 0.0f )
    int m = int(round(h * 60));
    hours = (m / 60) % 24;
    minutes = m % 60;
  switch ( i )
    case 0:
      x_eData.SunRiseHr = hours;
      x_eData.SunRiseMin = minutes;
    case 1:
      x_eData.SunSetHr = hours;
      x_eData.SunSetMin = minutes;
    case 2:
      x_eData.DawnHr = hours;
      x_eData.DawnMin = minutes;
    case 3:
      x_eData.DuskHr = hours;
    case 4:
      x_eData.TransitHr = hours;
      x_eData.TransitMin = minutes;
    case 5:
      String sTopic = "";
      sTopic.reserve( 35 );
      sTopic.concat( String(x_eData.SunRiseHr) + "," );
      sTopic.concat( String(x_eData.SunRiseMin) + "," );
      sTopic.concat( String(x_eData.SunSetHr) + "," );
      sTopic.concat( String(x_eData.SunSetMin) + "," );
      sTopic.concat( String(x_eData.DawnHr) + "," );
      sTopic.concat( String(x_eData.DawnMin) + "," );
      sTopic.concat( String(x_eData.TransitHr) + "," );
      sTopic.concat( String(x_eData.TransitMin) );
      xSemaphoreTake( sema_MQTT_KeepAlive, portMAX_DELAY );
      MQTTclient.publish( topicSRSSDDT, sTopic.c_str() );
      xSemaphoreGive( sema_MQTT_KeepAlive );
      sTopic = "";
      sTopic.concat( String(x_eData.azimuth) + "," + String(x_eData.azimuth) );
      MQTTclient.publish( topicAzEle, sTopic.c_str() );
      sTopic = "";
  } // switch ( i ) {
} // void SolarTimeFormat( double h, int i  )
  250-400ppm Normal background concentration in outdoor ambient air
  400-1,000ppm  Concentrations typical of occupied indoor spaces with good air exchange
  1,000-2,000ppm  Complaints of drowsiness and poor air.
  2,000-5,000 ppm Headaches, sleepiness and stagnant, stale, stuffy air. Poor concentration, loss of attention, increased heart rate and slight nausea may also be present.
  5,000 Workplace exposure limit (as 8-hour TWA) in most jurisdictions.
  >40,000 ppm Exposure may lead to serious oxygen deprivation resulting in permanent brain damage, coma, even death.
void fParseDewPointWindChill( void *pvParameters )
  while ( !MQTTclient.connected() )
    vTaskDelay( 250 );
  struct stu_message px_message;
  String sDewPoint = "";
  String sWindChill = "";
  sDewPoint.reserve( payloadSize );
  sWindChill.reserve( payloadSize );
  for (;;)
    if ( xQueueReceive(xQ_WindChillDewPoint, &px_message, portMAX_DELAY) == pdTRUE )
      sDewPoint = px_message.payload;
      int commaIndex = sDewPoint.indexOf(',');
      sWindChill.concat ( sDewPoint.substring(0, commaIndex) );
      sDewPoint.remove( 0, (commaIndex + 1) );
      x_eData.WindChill = sWindChill.toFloat();
      x_eData.DewPoint = sDewPoint.toFloat();
      sDewPoint = "";
      sWindChill = "";
void fGetCO2 ( void *pvParameters )
  uint64_t TimePastKalman  = esp_timer_get_time();
  myMHZ19.begin( co2Serial );
  myMHZ19.autoCalibration();
  SimpleKalmanFilter KF_CO2( 1.0f, 1.0f, .01f );
  for ( ;; )
    KF_CO2.setProcessNoise( (esp_timer_get_time() - TimePastKalman) / 1000000.0f );
    x_eData.CO2 = KF_CO2.updateEstimate( myMHZ19.getCO2() ); // apply simple Kalman filter
    MQTTclient.publish( topicCO2, String(round(x_eData.CO2)).c_str() );
    // process wind chill and dew point
} //void fMHZ19B ( void *pvParameters )
void fScreenBlanking( void *pvParameters )
  int       TimeOfPause = 10000 * 1000;
  uint64_t  PauseStartTime = esp_timer_get_time();
  bool      Pause = false;
  const int brightness = 250;
  int       countUpDown = brightness;
  for ( ;; )
    if (!Pause )
      //if motion detect then show display otherwise blank display
      if ( !(gpio_get_level( GPIO_NUM_27)) )
        for ( countUpDown; countUpDown-- > 0; )
          ledcWrite( 4, countUpDown ); // write to channel number 4, dim backlight
          vTaskDelay( 7 );
        Pause = true;
        ledcWrite( 4, brightness );
      // still detecting movement reset blanking pause time
      if ( gpio_get_level( GPIO_NUM_27) )
        PauseStartTime = esp_timer_get_time(); // extend pause blanking time
      if ( (esp_timer_get_time() - PauseStartTime) >= TimeOfPause )
        Pause = false;
    vTaskDelay( 250 );
} //void fScreenBlanking( void *pvParameters )
void fparseMQTT( void *pvParameters )
  for (;;)
    if ( xQueueReceive(xQ_Message, &px_message, portMAX_DELAY) == pdTRUE )
      xSemaphoreTake( sema_mqttOK, portMAX_DELAY );
      mqttOK = 0;
      if ( px_message.topic == topicRemainingMoisture_0 )
        x_eData.RM0  = String(px_message.payload).toFloat();
      if ( px_message.topic == topicWindSpeed )
        x_eData.WS = String(px_message.payload).toFloat();
      if ( px_message.topic == topicWindDirection )
        x_eData.WD = "";
        x_eData.WD = String(px_message.payload);
      if ( px_message.topic == topicRainfall )
        x_eData.RF = String(px_message.payload).toFloat();
      if ( px_message.topic == topicWSVolts )
        x_eData.WSV = String(px_message.payload).toFloat();
      if ( px_message.topic == topicWSCurrent )
        x_eData.WSC = String(px_message.payload).toFloat();
      if ( px_message.topic == topicWSPower )
        x_eData.WSP = String(px_message.payload).toFloat();
      if ( px_message.topic == topicDPnWI )
        xQueueSend( xQ_WindChillDewPoint, (void *) &px_message, 1 );
      if ( String(px_message.topic) == topicOK )
        if ( !TimeSet)
          String temp = "";
          temp.reserve(50);
          temp.concat( String(px_message.payload[0]) );
          temp.concat( String(px_message.payload[1]) );
          temp.concat( String(px_message.payload[2]) );
          temp.concat( String(px_message.payload[3]) );
          int year =  temp.toInt();
          temp = "";
          temp.concat( String(px_message.payload[5]) + String(px_message.payload[6]) );
          int month =  temp.toInt();
          temp =  "";
          temp.concat(String(px_message.payload[8]) + String(px_message.payload[9]) );
          int day =  temp.toInt();
          temp = "";
          temp.concat( String(px_message.payload[11]) + String(px_message.payload[12]) );
          int hour =  temp.toInt();
          temp = "";
          temp.concat( String(px_message.payload[14]) + String(px_message.payload[15]) );
          int min =  temp.toInt();
          rtc.setTime( 0, min, hour, day, month, year );
          log_i( "rtc  %s Year %d month %d day %d", rtc.getTime(), rtc.getYear(), (rtc.getMonth() + 1), rtc.getDay() );
          TimeSet = true;
    } //if ( xQueueReceive(xQ_Message, &px_message, portMAX_DELAY) == pdTRUE )
  } //for(;;)
} // void fparseMQTT( void *pvParameters )
void fDoTheDisplayThing( void * parameter )
  tft.init( 240, 320 ); // Init ST7789 320x240
  tft.setRotation( 3 );
  tft.setTextSize( 3 );
  tft.fillScreen( ST77XX_BLACK );
  tft.setTextWrap( false );
  struct stu_eData px_eData;
  ledcWrite( 4, brightness ); //backlight set
  const int MaxString      = 20;
  String oldTempString     = "";
  String oldHumidityString = "";
  String oldAQIString      = "";
  String oldRainfall       = "";
  String oldWindDirection  = "";
  String oldAirPressure    = "";
  String oldRMO            = "";
  String oldPM2            = "";
  //String oldPower          = "";
  String oldC02 = "";
  oldHumidityString.reserve( MaxString );
  oldWindDirection.reserve( MaxString );
  oldAirPressure.reserve( MaxString );
  oldTempString.reserve( MaxString );
  oldAQIString.reserve( MaxString );
  oldRainfall.reserve( MaxString );
  //oldPower.reserve( MaxString );
  oldRMO.reserve( MaxString );
  oldPM2.reserve( MaxString );
  oldC02.reserve( MaxString );
  bool Tick = true;
  const int numOfColors = 40;
  /* https://chrishewett.com/blog/true-rgb565-colour-picker/#:~:text=A%20true%20RGB565%20colour%20picker%2021st%20Oct%202017,in%205%20bits%20and%20green%20in%206%20bits. */
  int colors[numOfColors] = { ST77XX_BLACK, ST77XX_RED, ST77XX_WHITE, ST77XX_BLUE, ST77XX_GREEN, ST77XX_CYAN, ST77XX_MAGENTA, ST77XX_YELLOW, 0xd55b, 0xee09,
                              0x2e15, 0xcb43, 0x6bad, 0x126f, 0x1264, 0xe264, 0xe7e4, 0x87e4, 0x87fe, 0x876a,
                              0xe304, 0x1cc4, 0xf4c4, 0xf4da, 0xcf66, 0xa879, 0x7f28, 0x4f37, 0xfa97, 0x6195,
                              0X8162, 0xc962, 0x517b, 0x325b, 0xea5b, 0x179b, 0xff80, 0xf960, 0x416d, 0x7bd1
  int colorCounter = 1;
  for (;;)
    if ( xQueueReceive(xQ_eData, &px_eData, portMAX_DELAY) == pdTRUE )
      tft.setCursor( 0, 0 );
      tft.setTextColor( colors[0] );
      tft.print( oldTempString );
      tft.setTextColor( colors[colorCounter] );
      oldTempString = "";
      if ( Tick )
        oldTempString.concat( "iTemp " + String(px_eData.Temperature) + "F" );
        oldTempString.concat( "Wind Chill " + String(px_eData.WindChill) + "F" );
      tft.println( oldTempString );
      tft.setCursor( 0, 30 );
      tft.print( oldHumidityString );
      if ( Tick )
        oldHumidityString.concat( "iHum  " + String(px_eData.Humidity) + "%" );
        if ( (px_eData.SunRiseHr < 10) & (px_eData.SunRiseMin < 10) )
          oldHumidityString.concat( "sRise 0" + String(px_eData.SunRiseHr) + "0" + String(px_eData.SunRiseMin) );
        if ( (px_eData.SunRiseHr >= 10) & (px_eData.SunRiseMin < 10) )
          oldHumidityString.concat( "sRise " + String(px_eData.SunRiseHr) + "0" + String(px_eData.SunRiseMin) );
        if ( (px_eData.SunRiseHr < 10) & (px_eData.SunRiseMin >= 10) )
          oldHumidityString.concat( "sRise 0" + String(px_eData.SunRiseHr) + String(px_eData.SunRiseMin) );
        if ( (px_eData.SunRiseHr >= 10) & (px_eData.SunRiseMin >= 10) )
          oldHumidityString.concat( "sRise " + String(px_eData.SunRiseHr) + String(px_eData.SunRiseMin) );
      tft.println( oldHumidityString );
      tft.setCursor( 0, 60 );
      tft.print( oldAirPressure );
      if ( Tick )
        //oldAirPressure.concat( "Pres " + String(px_eData.Pressure) + "mmHg" );
        oldAirPressure.concat( "Dew Pt. " + String(px_eData.DewPoint) + "F" );
        if ( px_eData.SunSetMin < 10 )
          oldAirPressure.concat( "sSet " + String(px_eData.SunSetHr) + "0" + String(px_eData.SunSetMin) );
        if ( px_eData.SunRiseMin >= 10 )
          oldAirPressure.concat( "sSet " + String(px_eData.SunSetHr) + String(px_eData.SunSetMin) );
      tft.println( oldAirPressure );
      tft.setCursor( 0, 90 );
      tft.print( oldAQIString );
      oldAQIString = "";
      oldAQIString.concat( "iAQI " + String(px_eData.IAQ) + "%" );
      tft.println( oldAQIString );
      tft.setCursor( 0, 120 );
      tft.print( oldRMO );
      oldRMO = "";
      //if ( Tick )
        oldRMO.concat( "iRM0 " + String(px_eData.RM0) + "%" );
      //} else {
      //  oldRMO.concat( "iCO2 " + String(CO2) + "ppm" );
      tft.println( oldRMO );
      tft.setCursor( 0, 150 );
      tft.print( oldPM2 );
      oldPM2 = "";
      oldPM2.concat( "PM2 " + String(px_eData.PM2) + "ug/m3" );
      tft.println( oldPM2 );
      tft.setCursor( 0, 180 );
      //tft.print( oldPower );
      tft.print( oldC02 );
      //oldPower = "";
      oldC02 = "";
      //oldPower.concat(  String(px_eData.WSV) + " Volts" );
      oldC02.concat(  "iCO2 " + String(x_eData.CO2) + "ppm" );
      //oldPower.concat(  String(px_eData.WSV) + "V " + String(int(px_eData.WSC * 1000.0f)) + "mA " + String((int(px_eData.WSP * 1000.0f))) + "mW" );
      //tft.println( oldPower );
      tft.println( oldC02 );
      colorCounter++;
      if ( colorCounter > (numOfColors - 1) )
        colorCounter = 1;
      Tick = !Tick;
    } //if ( xQueueReceive(xQ_eData, &px_eData, portMAX_DELAY) == pdTRUE )
  } //for (;;)
} //void fDoTheDisplayTHing( void * parameter )
void fmqttWatchDog( void * paramater )
  int UpdateImeTrigger = 86400; //seconds in a day
  int UpdateTimeInterval = 86300; // 1st time update in 100 counts
  int maxNonMQTTresponse = 15;
  for (;;)
    vTaskDelay( 1000 );
    if ( mqttOK >= maxNonMQTTresponse )
      ESP.restart();
    mqttOK++;
    UpdateTimeInterval++; // trigger new time get
    if ( UpdateTimeInterval >= UpdateImeTrigger )
      TimeSet = false; // sets doneTime to false to get an updated time after a days count of seconds
      UpdateTimeInterval = 0;
float fCalulate_IAQ_Index( int gasResistance, float Humidity)
  float hum_baseline = 40.0f;
  float hum_weighting = 0.25f;
  float gas_offset = 0.0f;
  float hum_offset = 0.0f;
  float hum_score = 0.0f;
  float gas_score = 0.0f;
  gas_offset = oGasResistanceBaseLine - float( gasResistance );
  hum_offset = float( Humidity ) - hum_baseline;
  // calculate hum_score as distance from hum_baseline
  if ( hum_offset > 0.0f )
    hum_score = 100.0f - hum_baseline - hum_offset;
    hum_score /= ( 100.0f - hum_baseline );
    hum_score *= ( hum_weighting * 100.0f );
    hum_score = hum_baseline + hum_offset;
    hum_score /= hum_baseline;
    hum_score *= ( 100.0f - (hum_weighting * 100.0f) );
  //calculate gas score as distance from baseline
  if ( gas_offset > 0.0f )
    gas_score = float( gasResistance ) / oGasResistanceBaseLine;
    gas_score *= ( 100.0f - (hum_weighting * 100.0f ) );
    gas_score = 100.0f - ( hum_weighting * 100.0f );
  return ( hum_score + gas_score );
} //void fCalulate_IAQ_Index( int gasResistance, float Humidity):
void fDoParticleDetector( void * parameter )
    ug/m3     AQI                 Lvl AQ (Air Quality)
    (air Quality Index)
    0-35     0-50                1   Excellent
    35-75    51-100              2   Average
    75-115   101-150             3   Light pollution
    115-150  151-200             4   moderate
    150-250  201-300             5   heavy
    250-500  >=300               6   serious
  float ADbits = 4095.0f;
  float uPvolts = 3.3f;
  float adcValue = 0.0f;
  float dustDensity = 0.0f;
  float Voc = 0.6f; // Set the typical output voltage, when there is zero dust.
  const float K = 0.5f; // Use the typical sensitivity in units of V per 100ug/m3.
  xEventGroupWaitBits (eg, evtWaitForBME, pdTRUE, pdTRUE, portMAX_DELAY );
  const TickType_t xFrequency = 100; //delay for mS
  for (;;)
    //enable sensor led
    gpio_set_level( GPIO_NUM_4, HIGH ); // set gpio 4 to high to turn on sensor internal led for measurement
    esp_timer_start_once( oneshot_timer, 280 ); // trigger one shot timer for a 280us timeout, warm up time.
    xEventGroupWaitBits (eg, evtDoParticleRead, pdTRUE, pdTRUE, portMAX_DELAY ); // event will be triggered by the timer expiring, wait here for the 280uS
    adcValue = float( adc1_get_raw(ADC1_CHANNEL_0) ); //take a raw ADC reading from the dust sensor
    gpio_set_level( GPIO_NUM_4, LOW );//Shut off the sensor LED
    adcValue = ( adcValue * uPvolts ) / ADbits; //calculate voltage
    dustDensity = (adcValue / K) * 100.0; //convert volts to dust density
    if ( dustDensity < 0.0f )
      dustDensity = 0.00f; // make negative values a 0
    if ( xSemaphoreTake( sema_PublishPM, 0 ) == pdTRUE )  // don't wait for semaphore to be available
      //log_i( "ADC volts %f Dust Density = %ug / m3 ", adcValue, dustDensity ); // print the calculated voltage and dustdensity
      MQTTclient.publish( topicInsidePM, String(dustDensity).c_str() );
      x_eData.PM2 = dustDensity;
}// end fDoParticleDetector()
void DoTheBME680Thing( void *pvParameters )
  SPI.begin(); // initialize the SPI library
  vTaskDelay( 10 );
  if (!bme.begin()) {
    log_i("Could not find a valid BME680 sensor, check wiring!");
    while (1);
  // Set up oversampling and filter initialization
  bme.setTemperatureOversampling(BME680_OS_8X);
  bme.setHumidityOversampling(BME680_OS_2X);
  bme.setPressureOversampling(BME680_OS_4X);
  bme.setIIRFilterSize(BME680_FILTER_SIZE_3);
  bme.setGasHeater(320, 150); // 320*C for 150 ms
  //wait for a mqtt connection
    vTaskDelay( 250 );
  xEventGroupSetBits( eg, evtWaitForBME );
  const TickType_t xFrequency = 1000 * 15; //delay for mS
  String bmeInfo = "";
  bmeInfo.reserve( 100 );
  for (;;)
    x_eData.Temperature  = bme.readTemperature();
    x_eData.Temperature  = ( x_eData.Temperature * 1.8f ) + 32.0f; // (Celsius x 1.8) + 32
    x_eData.Pressure     = bme.readPressure();
    x_eData.Pressure     = x_eData.Pressure / 133.3223684f; //converts to mmHg
    x_eData.Humidity     = bme.readHumidity();
    x_eData.IAQ          = fCalulate_IAQ_Index( bme.readGas(), x_eData.Humidity );
    //log_i( " temperature % f, Pressure % f, Humidity % f IAQ % f", x_eData.Temperature, x_eData.Pressure, x_eData.Humidity, x_eData.IAQ);
    bmeInfo.concat( String(x_eData.Temperature, 2) );
    bmeInfo.concat( "," );
    bmeInfo.concat( String(x_eData.Pressure, 2) );
    bmeInfo.concat( String(x_eData.Humidity, 2) );
    bmeInfo.concat( String(x_eData.IAQ, 2) );
    if ( MQTTclient.connected() )
      MQTTclient.publish( topicInsideInfo, bmeInfo.c_str() );
    xSemaphoreGive( sema_PublishPM ); // release publish of dust density
    mqttOK ++;
    xQueueOverwrite( xQ_eData, (void *) &x_eData );// send data to display
    bmeInfo = ""; // empty the string buffer
    findDewPointWithHumidity( x_eData.Humidity, x_eData.Temperature );
    // log_i( "DoTheBME280Thing high watermark % d",  uxTaskGetStackHighWaterMark( NULL ) );
  vTaskDelete ( NULL );
  Important to not set vTaskDelay/vTaskDelayUntil to less then 10. Errors begin to develop with the MQTT and network connection.
  makes the initial wifi/mqtt connection and works to keeps those connections open.
void MQTTkeepalive( void *pvParameters )
  sema_MQTT_KeepAlive   = xSemaphoreCreateBinary();
  xSemaphoreGive( sema_MQTT_KeepAlive ); // found keep alive can mess with a publish, stop keep alive during publish
  MQTTclient.setKeepAlive( 90 ); // setting keep alive to 90 seconds makes for a very reliable connection, must be set before the 1st connection is made.
  const TickType_t xFrequency = 250; //delay for ms
  for (;;)
    //check for a is-connected and if the WiFi 'thinks' its connected, found checking on both is more realible than just a single check
    if ( (wifiClient.connected()) && (WiFi.status() == WL_CONNECTED) )
      xSemaphoreTake( sema_MQTT_KeepAlive, portMAX_DELAY ); // whiles MQTTlient.loop() is running no other mqtt operations should be in process
      MQTTclient.loop();
    else {
      log_i( "MQTT keep alive found MQTT status % s WiFi status % s", String(wifiClient.connected()), String(WiFi.status()) );
      if ( !(wifiClient.connected()) || !(WiFi.status() == WL_CONNECTED) )
        connectToWiFi();
      connectToMQTT();
void connectToMQTT()
  byte mac[5]; // create client ID from mac address
  WiFi.macAddress(mac); // get mac address
  String clientID = String(mac[0]) + String(mac[4]) ; // use mac address to create clientID
    MQTTclient.connect( clientID.c_str(), mqtt_username, mqtt_password );
    vTaskDelay( 250 );
  MQTTclient.setCallback( mqttCallback );
  MQTTclient.subscribe  ( topicOK );
  MQTTclient.subscribe  ( topicRemainingMoisture_0 );
  MQTTclient.subscribe  ( topicWindSpeed );
  MQTTclient.subscribe  ( topicWindDirection );
  MQTTclient.subscribe  ( topicRainfall );
  MQTTclient.subscribe  ( topicWSVolts );
  MQTTclient.subscribe  ( topicWSCurrent );
  MQTTclient.subscribe  ( topicWSPower );
  MQTTclient.subscribe  ( topicDPnWI );
} //void connectToMQTT()
void connectToWiFi()
  int TryCount = 0;
  while ( WiFi.status() != WL_CONNECTED )
    TryCount++;
    WiFi.disconnect();
    WiFi.begin( SSID, PASSWORD );
    vTaskDelay( 4000 );
    if ( TryCount == 10 )
      ESP.restart();
  WiFi.onEvent( WiFiEvent );
float findDewPointWithHumidity( float humi, float temperature )
  //Celcius
  float ans =  (temperature - (14.55 + 0.114 * temperature) * (1 - (0.01 * humi)) - pow(((2.5 + 0.007 * temperature) * (1 - (0.01 * humi))), 3) - (15.9 + 0.117 * temperature) * pow((1 - (0.01 * humi)), 14));
  //log_i( "%f", ans );
  return ans;
void loop() { }
See, void fDoParticleDetector( void * parameter ).
I think the way to do it is to set Timer1 to run with Input Capture enabled for whichever edge you are trying to delay and the Input Capture interrupt enabled. When Pin 8 (the Input Capture pin) senses the edge it records the time in 16th of a microsecond. In the ISR, add 20 microseconds (320 clock ticks) to the value captured and set up one of the Output Compare registers to turn on (or off) Pin 9 or Pin 10 at the instant that is 320 ticks past the time of the edge. Turn on the Output Compare interrupt if you want to switch edges.
That way you can delay rising edges and falling edges by the desired factor (they don't have to be the same) and invert the signal if you like.
Give more details and I can write the sketch for you.
https://www.google.com/search?q=delay+a+pulse
@johnwasser @Idahowalker
Thank you for your replies.
I want to introduce delay (lets say few "us") to the input pulse whose pulse width is 20us and of 10 Hz repetition.
Thanks in advance.
A delay of "a few microseconds" on a 20-microsecond pulse is different from the original request of "introduce 20us of delay to input pulse". Are you sure you know what you want?
How many is "a few" microseconds? Twenty is plenty of time (320 instruction cycles) but you might have trouble doing it with interrupts and software with only, say, 48 instruction cycles (3 microseconds). You may need to use a hardware delay line.
Is your input pulse a HIGH pulse or a LOW pulse?
How much jitter in the delay can you tolerate? Can you define "few us" in numbers please? Delay to rising edge, falling edge or both?
5% jitter can be tolerated. I am attaching one file for your reference. I hope you get the clarity from it. let me know if you need any further information
Why would you want to use an arduino to do this, when you can do it reliably with a few logic gates?
Arduino micros() are granular to FOUR (4) microseconds, the low 2 bits always 0.
In the Arduino Playground there's a topic on timing closer than 1 microsec.
The big question to me is how close the timing has to be.
Does 20us as opposed to 20.0us mean nearest microsec, every NOP inserted takes 62.5 nanosecs to tick on by.
Need speed? Teensy 4.1 runs at 600MHz and has SD onboard. The ARM M4F has a floating point processor to do fast 64-bit floating point math. ~* salivate on that! *~
The paper shows a 20us rise time. AVR digital pin goes high at IIRC around 2.8V.
Does 10 Hz mean the input is 10 pulses per second, one every 100000us?
Is that input or desired output.... both as a timing diagram would be really clear.
I dont have any FPGA system to develop and did not find any logic gate circuit. I tried with some monostable ICs but did not get desired output(Simulation). If you know any please share.
Thanks
That is acceptable rise time, ON time for the pulse is around 30 microseconds. This is the input pulse which has to be delayed by 20us after receiving trigger pulse.
If the delay is much shorter than the pulse, you can simply use a RC!
A trigger pin for input and an output pin to make a pulse 20us later?
How close to 20us exactly?
Why not run the trigger pulse through an inductor?
