Hi I am curious about using OneWire library used for Dallas devices with Microchip single wire EEPROM. Not sure about three signalling both Dallas and Microchip.
Can any one please guide on this?
If these devices use the same protocol, then it should work. You can check the datasheet(s) of the devices you want to use to make sure.
If you mean "UNI/O" EEPROM like this one:
UNIO EEPROM.pdf (747.1 KB)
it is not compatible.
It was for Single-Wire EEPROMs like ATCS01. But seems to be not working with that too because of different kind of signalling they use. @jfjlaros @Smajdalf Thanks for your inputs.
