Can you call a variable from an object in another tab?
I'm attempting to call a variable in void loop() that is declared in a function in another tab (photocellRead). Is this possible in Arduino 1.0? Am I making any glaring mistakes here? Thanks in advance.
void loop(){ photocellRead();
//frit actuators start switch (solarPosition){ case 1: digitalWrite(fritAct1, LOW); digitalWrite(fritAct2, LOW); break; case 2: analogWrite(fritAct1, 50); // change this latter to reflect PWM analogWrite(fritAct2, 50); break; case 3: analogWrite(fritAct1, 100); // change this latter to reflect PWM analogWrite(fritAct2, 100); break; case 4: analogWrite(fritAct1, 50); // change this latter to reflect PWM analogWrite(fritAct2, 50); break; case 5: digitalWrite(fritAct1, LOW); digitalWrite(fritAct2, LOW); break; }
You can reference a variable, but not call it, unless the variable is a function pointer.
(Is it just me, or are those two items of code identical?)
Sorry about the paste. Here is the other function.
void photocellRead(){
pinMode(interLight1, INPUT); pinMode(interLight2, INPUT); pinMode(interLight3, INPUT);
pinMode(exterLight1, INPUT); pinMode(exterLight2, INPUT); pinMode(exterLight3, INPUT); pinMode(exterLight4, INPUT); pinMode(exterLight5, INPUT);
int photoCell1 = analogRead(interLight1); int photoCell2 = analogRead(interLight2); int photoCell3 = analogRead(interLight3);
int avgInteriorLight = (photoCell1 + photoCell2 + photoCell3)/3;
int photoCell4 = analogRead(exterLight1); int photoCell5 = analogRead(exterLight2); int photoCell6 = analogRead(exterLight3); int photoCell7 = analogRead(exterLight4); int photoCell8 = analogRead(exterLight5);
Serial.println(" "); Serial.println("Begin"); Serial.println("interior Light Sensor 1: "); Serial.println(photoCell1, DEC); Serial.println("interior Light Sensor 2: "); Serial.println(photoCell2, DEC); Serial.println("interior Light Sensor 3: "); Serial.println(photoCell3, DEC);
Serial.println("interior Light Average Value: "); Serial.println(avgInteriorLight, DEC); Serial.println(" ");
Serial.println("Exterior Light Sensor 1: "); Serial.println(photoCell4, DEC); Serial.println("Exterior Light Sensor 2: "); Serial.println(photoCell5, DEC); Serial.println("Exterior Light Sensor 3: "); Serial.println(photoCell6, DEC); Serial.println("Exterior Light Sensor 4: "); Serial.println(photoCell7, DEC); Serial.println("Exterior Light Sensor 5: "); Serial.println(photoCell8, DEC);
int photoArray[] = {photoCell4, photoCell5, photoCell6, photoCell7, photoCell8};
solarPosition = getIndexOfMaximumValue(photoArray, 5) + 1;
Serial.println(" "); Serial.println("Solar position relative to array index: "); Serial.println(solarPosition, DEC); }
I don't know why, but the IDE wouldn't let me copy the other set and I hadn't noticed when first posted.
Regardless of whether the function are in different tabs or the same tab, any variable declared within a function can never be referenced in another function. For that, it would need global/external scope.
AWOL: Regardless of whether the function are in different tabs or the same tab, any variable declared within a function can never be referenced in another function. For that, it would need global/external scope.
Bummer...thanks for the info.
Sorry, that should have read "directly referenced". You can, of course pass pointers and references between functions.
Another thing is it isn't necessary to set the pin mode of a pin you're going to do an analogRead on.
AWOL: You can reference a variable, but not call it, unless the variable is a function pointer.
I think AWOL tries to fool you a bit ;) Of course you can use both functions and global variables: One tab:
char msg[] = "Hello World";
void sayHello()
  Serial.println(msg);
Another tab:
extern void sayHello(); // NOT required
extern char msg[]; // required
  if (strlen(msg) > 2) sayHello();
  delay(2000);
Notice the "extern" keyword ! Arduino IDE tries to be smart and secretly adds the first line by itself.
