Can you concatenate two reference a variable?
I have 5 variables named seat1, seat2, ... Seat 5.
Is it possible to pass an int through a function and get the corresponding variable's value?
i.e:
int seat3 [5];
seat3 [3] = 1;
void input (char num) {
    num = strcat("seat", num);
    num = strcat(num, "[3]");
    //somthing to turn "seat3[3]" into 1
    return num;
void loop () {
     input(3);
I'm new to Arduino, so thank you for your help!
Hi there,
I'm not too sure what you mean, do you mean you just want a function that will return the value of the array?
if so, you could do something like this instead:
int seat[5] = {20, 40, 60, 80, 100};
void tellMeArrayValue(int *arr, int index)
  Serial.print(F("The value in seat["));
  Serial.print(index);
  Serial.print(F("] is: "));
  Serial.println(arr[index]);
void setup(){
void loop () {
     tellMeArrayValue(seat, 0);
or were you wanting to change the value of one of the integers in the array? or, just wanting to get the value?
Sorry for the confusion. I need one value from the array.
Here's the code I'm trying to use it in. Maybe I'm just being lazy...
The [5] value in the array is the Arduino pin that corresponds to the seat.
char seat[15];
        for (i=1; i <= 5; i++) {
            /* make seat value into "seat" + i + "[5]"  */
            if (analogRead(seat))
Ignore syntax.
Does that help?
Sorry, but it is no clearer to me
if (analogRead(seat[i]))
Ok, sorry...
I have a char array
int seat1 [5], seat2 [5], seat3 [5], seat4 [5], seat5 [5];
Within this for loop, I want to reference the 5th value of each seat array.
char seat[15];
So on the first loop, I want to pull the value of seat1 [5], on the second loop, seat2 [5], and so on...
I have 5 separate seat variables, so not just changing the array number.
Put each array in another array then seat[i][j]
Seat[5][5]
for (i=0; i <= 4; i++) {
if (analogRead(seat[i][4])) //4 is the fifth element
I didn't realize you could stack arrays... cool.
Do I need to declare a big array, or does that just work?
ie:
int allSeats [5] = seat1, seat2, seat3, seat4, seat5;
Try this example
int seats[][5] =
  {100, 101, 102, 103, 104},
  {105, 106, 107, 108, 109},
  {110, 111, 112, 113, 114},
  {115, 116, 117, 118, 119},
  {120, 121, 122, 123, 124}
  for (int x = 0; x < 5; x++)
    Serial.println(seats[x][4]);
I didn't know you you could do that. That's perfect! Thank you!
Well, Evan gave me the solution, but you gave me the specific details/syntax... Does it matter which I mark a "Solution"?
It does not matter to me
