Can you control 4 LED strips (WS2812B) with the Arduino Uno?
Can you control 4 LED strips (WS2812B) with the Arduino Uno? I want to control these individually via serial so that you can control them via LedFX, openrgb and so on. There is a code example?
Thanks in advance
The short answer is yes
However, it is the total number of LEDs to be controlled that matters more. How many are you aiming to control ?
If you mention libraries that do no get installed with the IDE you should provide links to those libraries.
If the libraries are worth a darn, they will have example code to demonstrate thrir use.
Hello,
In total there are 200 LEDS
Topic moved; do not post in "Uncategorized".
Should be possible.
If you mean to use different libraries, one here, one there and maybe other strips just hand-coded, there should be no problem.
No more than hooking up an LCD and a servo at the same time presents. Each strip gets its own output pin and none need know anything about the others.
What means this? I can only guess - you want to use serial comms to instruct an UNO about what to display on the strips.
If so, neither should that be any problem.
a7
#include <Arduino.h>
// --- General Settings
const uint16_t
	Num_Leds   =  80;         // strip length
const uint8_t
	Brightness =  255;        // maximum brightness
// --- FastLED Setings
#define LED_TYPE     WS2812B  // led strip type for FastLED
#define COLOR_ORDER  GRB      // color order for bitbang
#define PIN_DATA     6        // led data output pin
// #define PIN_CLOCK  7       // led data clock pin (uncomment if you're using a 4-wire LED type)
// --- Serial Settings
const unsigned long
	SerialSpeed    = 115200;  // serial port speed
const uint16_t
	SerialTimeout  = 60;      // time before LEDs are shut off if no data (in seconds), 0 to disable
// --- Optional Settings (uncomment to add)
#define SERIAL_FLUSH          // Serial buffer cleared on LED latch
// #define CLEAR_ON_START     // LEDs are cleared on reset
// --- Debug Settings (uncomment to add)
// #define DEBUG_LED 13       // toggles the Arduino's built-in LED on header match
// #define DEBUG_FPS 8        // enables a pulse on LED latch
#include <FastLED.h>
CRGB leds[Num_Leds];
uint8_t * ledsRaw = (uint8_t *)leds;
// A 'magic word' (along with LED count & checksum) precedes each block
// of LED data; this assists the microcontroller in syncing up with the
// host-side software and properly issuing the latch (host I/O is
// likely buffered, making usleep() unreliable for latch). You may see
// an initial glitchy frame or two until the two come into alignment.
// The magic word can be whatever sequence you like, but each character
// should be unique, and frequent pixel values like 0 and 255 are
// avoided -- fewer false positives. The host software will need to
// generate a compatible header: immediately following the magic word
// are three bytes: a 16-bit count of the number of LEDs (high byte
// first) followed by a simple checksum value (high byte XOR low byte
// XOR 0x55). LED data follows, 3 bytes per LED, in order R, G, B,
// where 0 = off and 255 = max brightness.
const uint8_t magic[] = {
	'A','d','a'};
#define MAGICSIZE  sizeof(magic)
// Check values are header byte # - 1, as they are indexed from 0
#define HICHECK    (MAGICSIZE)
#define LOCHECK    (MAGICSIZE + 1)
#define CHECKSUM   (MAGICSIZE + 2)
enum processModes_t {Header, Data} mode = Header;
int16_t c;  // current byte, must support -1 if no data available
uint16_t outPos;  // current byte index in the LED array
uint32_t bytesRemaining;  // count of bytes yet received, set by checksum
unsigned long t, lastByteTime, lastAckTime;  // millisecond timestamps
void headerMode();
void dataMode();
void timeouts();
// Macros initialized
#ifdef SERIAL_FLUSH
	#undef SERIAL_FLUSH
	#define SERIAL_FLUSH while(Serial.available() > 0) { Serial.read(); }
#else
#endif
#ifdef DEBUG_LED
	#define ON  1
	#define OFF 0
	#define D_LED(x) do {digitalWrite(DEBUG_LED, x);} while(0)
#else
	#define D_LED(x)
#endif
#ifdef DEBUG_FPS
	#define D_FPS do {digitalWrite(DEBUG_FPS, HIGH); digitalWrite(DEBUG_FPS, LOW);} while (0)
#else
	#define D_FPS
#endif
void setup(){
	#ifdef DEBUG_LED
		pinMode(DEBUG_LED, OUTPUT);
		digitalWrite(DEBUG_LED, LOW);
	#endif
	#ifdef DEBUG_FPS
		pinMode(DEBUG_FPS, OUTPUT);
	#endif
	#if defined(PIN_CLOCK) && defined(PIN_DATA)
		FastLED.addLeds<LED_TYPE, PIN_DATA, PIN_CLOCK, COLOR_ORDER>(leds, Num_Leds);
	#elif defined(PIN_DATA)
		FastLED.addLeds<LED_TYPE, PIN_DATA, COLOR_ORDER>(leds, Num_Leds);
	#else
		#error "No LED output pins defined. Check your settings at the top."
	#endif
	FastLED.setBrightness(Brightness);
	#ifdef CLEAR_ON_START
		FastLED.show();
	#endif
	Serial.begin(SerialSpeed);
	Serial.print("Ada\n"); // Send ACK string to host
	lastByteTime = lastAckTime = millis(); // Set initial counters
void loop(){
	t = millis(); // Save current time
	// If there is new serial data
	if((c = Serial.read()) >= 0){
		lastByteTime = lastAckTime = t; // Reset timeout counters
		switch(mode) {
			case Header:
				headerMode();
			case Data:
				dataMode();
	else {
		// No new data
		timeouts();
void headerMode(){
	static uint8_t
		headPos,
		hi, lo, chk;
	if(headPos < MAGICSIZE){
		// Check if magic word matches
		if(c == magic[headPos]) {headPos++;}
		else {headPos = 0;}
	else{
		// Magic word matches! Now verify checksum
		switch(headPos){
			case HICHECK:
				hi = c;
				headPos++;
			case LOCHECK:
				lo = c;
				headPos++;
			case CHECKSUM:
				chk = c;
				if(chk == (hi ^ lo ^ 0x55)) {
					// Checksum looks valid. Get 16-bit LED count, add 1
					// (# LEDs is always > 0) and multiply by 3 for R,G,B.
					D_LED(ON);
					bytesRemaining = 3L * (256L * (long)hi + (long)lo + 1L);
					outPos = 0;
					memset(leds, 0, Num_Leds * sizeof(struct CRGB));
					mode = Data; // Proceed to latch wait mode
				headPos = 0; // Reset header position regardless of checksum result
void dataMode(){
	// If LED data is not full
	if (outPos < sizeof(leds)){
		ledsRaw[outPos++] = c; // Issue next byte
	bytesRemaining--;
	if(bytesRemaining == 0) {
		// End of data -- issue latch:
		mode = Header; // Begin next header search
		FastLED.show();
		D_FPS;
		D_LED(OFF);
		SERIAL_FLUSH;
void timeouts(){
	// No data received. If this persists, send an ACK packet
	// to host once every second to alert it to our presence.
	if((t - lastAckTime) >= 1000) {
		lastAckTime = t; // Reset counter
		// If no data received for an extended time, turn off all LEDs.
		if(SerialTimeout != 0 && (t - lastByteTime) >= (uint32_t) SerialTimeout * 1000) {
			memset(leds, 0, Num_Leds * sizeof(struct CRGB)); //filling Led array by zeroes
			FastLED.show();
			mode = Header;
			lastByteTime = t; // Reset counter
}      how could I control 4 stripes with LEDFX?
Please read the forum guidelines to see how to properly post code and some information on making a good post.
Use the IDE autoformat tool (ctrl-t or Tools, Auto format) before posting code in a code block.
Please go back and fix your post.
It is a huge pain to copy your code, as posted, to my IDE for examination. Posting in a code block makes it much easier to work with.
Are you aware that the FastLED show() function disables interrupts while it executes. That means that any serial data that comes in during that time is ignored or corrupted.
Please link to that library like I asked.
Put the strips in series and treat as one....
That is a lot of code for 200 neopix.
#define NUM_LEDS 200
#define MATRIX_PIN 7
#define BRIGHTNESS 127
CRGB leds[NUM_LEDS];
  FastLED.addLeds<WS2812B, MATRIX_PIN, GRB>(leds, NUM_LEDS);
  FastLED.setBrightness(BRIGHTNESS); // Adjust the brightness value as needed
  FastLED.clear();
  FastLED.show();
  circle();
  FastLED.show();
  delay(50);
void circle() {
  for (int i = 1; i < NUM_LEDS; i++) {
    leds[i] = CRGB(random(255), random(255), random(255));
