I'm trying to learn about arrays. From what I know i usually you have to declare the array name and size alongside the included libraries and global variables. I've noticed that the size of the array can't just be an integer, it has to be a constant integer.
My problem is that i want to store data in an array, but the length of the array will be different each time and found only during the main loop.
Is there a way to create an array with a variable length during the main loop. or do i just create a big enough array to cover all possibilities, and then just fill the rest of the array with zero's during the main loop?
The array can be created with each loop iteration with a different size using a variable.
voiding loopy()
int MyArraySize = SomeSourceOfANumber;
int myarray [MyArraySize];
I prefer to create an array larger then needed and just keep track of how many array cells are in use per loop iteration. It takes time to create and destroy an array.
i often define arrays (of struct) with a max size along with a count of the # of elements it contains. that count is incremented with each new value added, up to the max. for example
C/C++ has a malloc() that support dynamically allocating space. this is fine on a PC but for smaller processors such as an Arduino, RAM is limited and it's usually better to pre-allocate the the space that discover at run time there's not enough RAM for such things as well as stack variables
This is technically correct : C++ standard (till C++11) doesn’t support variable sized arrays. The C++11 standard does mentions array size as a constant-expression.
But... actually Variable-length automatic arrays are allowed in ISO C99 or C11 ( flexible arrays), and as an extension GCC accepts them in C90 mode and in C++
As we use GCC, and knowing it's not standard C++, you could have a local array and change its length at each loop
you can try this
Serial.println("Enter array size: ");
// not a clean way but for demonstration sake
while (Serial.available() == 0) yield(); // wait for user input
long size = Serial.parseInt();
while (Serial.available() != 0) Serial.read(); // empty the rest of the buffer
Serial.print("creating an array with "); Serial.print(size); Serial.println(" entries. (no error checking!)");
byte dynamicArray[size];
for (int i = 0; i < size; i++) dynamicArray[i] = random(i);
Serial.write('[');
for (int i = 0; i < size; i++) {
Serial.print(dynamicArray[i]); Serial.write(' ');
Serial.println("]");
the array is allocated on the Stack, so stack size restrictions may apply on some platforms
Congratulations, you've asked a question for which the answer is really "it depends".
What processor? An Uno? Don't consider it; zero memory garbage collection means every redefinition/reallocation may result in out-of-memory, and there's no 'system' on an Uno to advise you, it just crashes. ESP32? Probably not going to be a problem. Hence, you really need to give more context to get an authoritative answer.
My point was that it does not work by default everywhere in arduino land, so if you offer that idea (containers is indeed the right approach in C++), don’t forget to mention the limitations.
That’s a different discussion so I won’t hijack that thread
Remember OP is just at the stage of learning and is trying to play with arrays. That should be the main focus of this discussion (even if I feel it’s OK to mention alternatives)
That might be appropriate, if we even knew what hardware he's using. But... @batterylicker how about sharing some info, there's more than enough OT conjecture floating around here. Participation on this forum really is a two-way street, we help you if you play along.
