Can you create an array of PinButtons (from the Multibutton library)?
Hi all,
Apologies if I'm missing something massive here, but having tried a few iterations of this (getting no exceptions from Create but having nothing happen when I run the code) I wondered if I'm going about this all wrong/how best to go about it?
I'm trying to use the Multibutton library for double clicks and long clicks on a set of 7 buttons. They all work as intended when initialised like in the code example, however since the rest of my code gets more complex and I don't really want to have it written 7 times, I am looking for some way to use the PinButton function and its associated .isClick(s etc) in a loop.
The simplest way I imagine this working is to have an array of the buttons, so I can do
PinButton buttons(arrayofpins);
for (count = 0; count <= 7; count++){
if buttons[count].isClick{
*dosomething
Obviously this doesn't work, but even with more complex iterations (using PinButton separately on each array element, using PinButton on separate variables then assigning them to an array etc etc) I still can't get this to work as I'd hope. Any chance of some pointers please?
Apologies if I'm way off here - it's been half a lifetime since I last worked in C++!
Sorted my own problem - I tried every combination of 'above setup' 'in setup' 'with a data type' and 'without a data type' except one. So for posterity, the working code is:
PinButton2 buttonsarray[] = {PinButton2(1),PinButton2(2),PinButton2(3),PinButton2(4),PinButton2(5),PinButton2(6),PinButton2(7)};
With no data type for the array, placed above void setup()
Allows you to do buttonsarray[count].isClick and all other Multibutton commands in a for loop :slight_smile:
Hope that helps someone one day!
