hi , can you explain this program when there is " double averagearray ( int* arr, int number);"
#define SensorPin A0 //pH mètre en sortie A0
#define Offset 0
#define LED 13
#define samplingInterval 20
#define printInterval 800
#define ArrayLenth 40
int pHArray[ArrayLenth];
int pHArrayIndex=0;
void setup(void)
pinMode(LED,OUTPUT);
Serial.println("pH de la piscine : ");
void loop(void)
static unsigned long samplingTime = millis();
static unsigned long printTime = millis();
static float pHValue,voltage;
if(millis()-samplingTime > samplingInterval)
pHArray[pHArrayIndex++]=analogRead(SensorPin);
if(pHArrayIndex==ArrayLenth)pHArrayIndex=0;
voltage = avergearray(pHArray, ArrayLenth)5.0/1023;
pHValue = 3.5voltage+Offset;
samplingTime=millis();
if(millis() - printTime > printInterval)
Serial.print(" Valeur du pH: ");
Serial.println(pHValue,1);
if (pHValue < 7){
Serial.println(" Votre pH est Acide , rajoutez du pH+");
else{
if (pHValue > 7.8){
Serial.println(" Votre pH est Basique , rajoutez du pH-");
else{
Serial.println(" Votre pH est bon.");
digitalWrite(LED,digitalRead(LED)^1);
printTime=millis();
double avergearray(int* arr, int number){
int i;
int max,min;
double avg;
long amount=0;
if(number<=0){
Serial.println("Erreur/n");
return 0;
if(number<5){
for(i=0;i<number;i++){
amount+=arr*;*
- avg = amount/number;*
- return avg;*
- }else{*
- if(arr[0]<arr[1]){*
- min = arr[0];max=arr[1];*
- else{*
- min=arr[1];max=arr[0];*
- for(i=2;i<number;i++){*
_ if(arr*<min){_
_ amount+=min; //arr<min*_
_ min=arr*;
}else {
if(arr>max){
amount+=max; //arr>max*
max=arr*;
}else{
amount+=arr; //min<=arr<=max*
}//if*
* }//for*
* avg = (double)amount/(number-2);
}//if*
* return avg;
}*_
