Hey there guys,
I have a problem that I cannot figure out.
I have one stepper motor driven by uln2003 driver and one 1 channel relay.
I am using 5V 1A phone charger for each my NANO, stepper and relay.
I will be adding more modules to my project but this already is becoming not practical.
For 5 modules 5 chargers, aint happening.
So I decided that I will use 1 charger for the NANO and one for the other modules.
Currently when i connect the red and black wires of the charger as in the picture, a problem arises.
As I read so far, in the parallel circuit every module should get 5V, while the amps will be the sum of all required. As long as I do not use more amps than the charger can provide, everything should be ok.
Problem:
this way the IN pin on the relay is receiving a small amount of current, but not enough to close its circuit.
The green led that lights up when I give a signal to close the circuit is glowing (a lot less but it is) nonstop.
Does that mean that there is a leak or what.
When the nano is on delay, the led is not glowing at all (as it should be, unless i give a signal to close the circuit).
This "leak" does not exist when I am powering the relay and the stepper with separate chargers.
Another thing that I cannot explain, when using separate chargers, the stepper is consuming:
idle : 350mA
moving : 300mA
but when I am using it as in the picture (1 charger for both relay and stepper)
idle : 300mA
moving : 250mA
why do does numbers change?
