TCCR2A |= (1 << WGM21)
TCCR2B
= (1 くくCS21)
TIMSK2 |= (1 << OCIE2A)
TCCR1B |= (1 << WGM12) | (1 << CS12)
TIMSK1 = (1 << OCIE1A)
TCCR2A = 0
TCCR2B = 0
TCNT2 = 0
TCNT1 = 0
OCR1A = 31250
OCR2A = 100
TCCR1A = 0
TCCR1B = 0
ADCSRA &= ~PS_128
ADCSRA = (1 << ADPS1)
I would like to understand what are the functions of these registers and what are the purposes and results of the operations performed on them.
That is a subjective question, many times it depends on the code the processor is running. Software defines much of this and even if they will be operating.
The code you've posted appears to be configuring various registers on an AVR microcontroller, specifically for setting up timers and the analog-to-digital converter (ADC).
TCCR2A |= (1 << WGM21): This sets the Waveform Generation Mode (WGM21) bit in the Timer/Counter Control Register A (TCCR2A) for Timer 2. This is typically done to select a specific mode of operation for the timer, such as CTC (Clear Timer on Compare Match), PWM, etc.
TCCR2B = (1 << CS21): This sets the clock select bits (CS21, CS20) in the Timer/Counter Control Register B (TCCR2B) for Timer 2. The CS21 bit enables a prescaler of 8, and CS20 being low means no further division [1].
TIMSK2 |= (1 << OCIE2A): This enables the Output Compare A Match Interrupt for Timer 2 by setting the corresponding bit in the Timer/Counter Interrupt Mask Register (TIMSK2). When the timer matches the value in the Output Compare Register A (OCR2A), it will trigger an interrupt.
TCCR1B |= (1 << WGM12) | (1 << CS12): This configures Timer 1 (TCCR1B) to operate in a certain waveform generation mode (WGM12) and sets the clock select bits (CS12) to use a prescaler.
TIMSK1 = (1 << OCIE1A): Similar to the previous line, this enables the Output Compare A Match Interrupt for Timer 1.
TCCR2A = 0, TCCR2B = 0, TCNT2 = 0, TCNT1 = 0: These lines reset the Timer/Counter Control Registers (TCCR2A and TCCR2B) and the Timer/Counter Registers (TCNT2 and TCNT1) to zero, effectively stopping the timers and resetting their counts.
OCR1A = 31250, OCR2A = 100: These lines set the Output Compare Registers for both Timers 1 and 2. These registers hold the values that the timers will compare against during their operation. In the case of Timer 1, the value is likely related to generating a PWM signal or measuring a pulse duration. For Timer 2, the value could be used for generating a specific frequency or timing interval.
TCCR1A = 0, TCCR1B = 0: These lines reset the Timer/Counter Control Registers for Timer 1 to zero, stopping the timer and resetting its configuration.
ADCSRA &= ~PS_128: This clears the ADC Prescaler Selection bits (PS[2:0]) in the ADC Control and Status Register A (ADCSRA), effectively disabling any prescaling of the ADC clock.
ADCSRA = (1 << ADPS1): This sets the ADC Prescaler Selection bits to divide the system clock by 2. This is done to reduce the ADC sampling rate, which can be useful when precise timing isn't required .
Each of these configurations is essential for setting up the timers and ADC to function according to the intended application. The specific effects depend on the rest of the program and the hardware setup, including the clock speed and the connections to other peripherals.
