Can you help me with this arduino leonardo & usb host shield
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
     System wide configuration file is "C:\Users\NURISQI\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
     Using Port                    : COM5
     Using Programmer              : avr109
     Overriding Baud Rate          : 57600
     AVR Part                      : ATmega32U4
     Chip Erase delay              : 9000 us
     PAGEL                         : PD7
     BS2                           : PA0
     RESET disposition             : dedicated
     RETRY pulse                   : SCK
     serial program mode           : yes
     parallel program mode         : yes
     Timeout                       : 200
     StabDelay                     : 100
     CmdexeDelay                   : 25
     SyncLoops                     : 32
     ByteDelay                     : 0
     PollIndex                     : 3
     PollValue                     : 0x53
     Memory Detail                 :
                              Block Poll               Page                       Polled
       Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
       eeprom        65    20     4    0 no       1024    4      0  9000  9000 0x00 0x00
       flash         65     6   128    0 yes     32768  128    256  4500  4500 0x00 0x00
       lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
       hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
       efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
       lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
       calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
       signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
     Programmer Type : butterfly
     Description     : Atmel AppNote AVR109 Boot Loader
Connecting to programmer: .
Found programmer: Id = "CATERIN"; type = S
Software Version = 1.0; No Hardware Version given.
Programmer supports auto addr increment.
Programmer supports buffered memory access with buffersize=128 bytes.
Programmer supports the following devices:
Device code: 0x44
avrdude: devcode selected: 0x44
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e9587 (probably m32u4)
avrdude: reading input file "C:\Users\NURISQI\AppData\Local\Temp\arduino\sketches\675AB016D0887E4A8FB93A91D1B35914/USBHIDBootMouse.ino.hex"
avrdude: writing flash (13820 bytes):
Writing | ################################################## | 100% 1.06s
avrdude: 13820 bytes of flash written
avrdude done. Thank you.
Hi @nurisqi.
The output you shared is the output we would expect from a successful upload.
Did Arduino IDE indicate the upload failed? If the upload fails, you will see an "Upload error: ..." notification at the bottom right corner of the IDE window:
If the upload succeeds, you will see a "Done uploading." notification there:
Note that the success notification is hidden after a few seconds, so you might miss it if you aren't watching, but you can click the :bell: icon at the right side of the status bar to show the hidden notifications again.
If you didn't get an "Upload error: ..." notification then the upload was successful and you don't need to worry about this message.
Notes on the Coloration of Upload Output in Arduino IDE
You might notice some messages printed to the "Output" panel at the bottom of the Arduino IDE window in red text while uploading. The color might give the impression that these messages are intended to communicate some sort of a problem has occurred, but it is not so in this case.
The developers of the 3rd party tool Arduino IDE uses for uploading made an unusual decision to print even the tool's purely informational output to the "standard error" stream (AKA "stderr") instead of the more common practice of printing it on the "standard output" (AKA "stdout") stream. Because it is usually associated with errors or warnings, Arduino IDE colors all output received from the stderr stream red (at least when the default IDE theme is selected).
So don't be mislead by the color of the text during the upload (though you should pay attention to red text printed while compiling because the color is significant in that case). As long as you don't see an "Upload error: ..." notification, all is well with the upload.
Yes, it turns out the upload was successful, but why can't my mouse be read when I connect it to the USB host shield?
Can you post a link to the specific USB host shield you are using?
Note that the SPI bus on a Leonardo is only on the ICSP header, not the digital pin headers.
