the corresponding component[right page id and component id] in touch event list will be asked. nexLoop(nex_listen_list);/
before that, I'm sorry if my language is difficult to understand. I'm still learning.
and, sorry if it does not comply with the rules of the post on this forum. I'm noob
If I understand your code correctly, It seems that you using RX and TX hardware pins with software serial library with Arduino UNO? That is not allowed. Simply use hardware Serial as shown in basic examples inside Arduino software IDE, or use digital pin 2 or 3 (or other suitable) with software serial library.
As far is concerned to me, do not apologize by the language, to many people here English is not native. Just be clear what is the problem, what Arduino/MCU is and make short subject describing the problem/question, instead "Can you help me". As well use code tags when posting code.
i used arduino uno and in board, RX pin 0 & TX pin 1..
i too change a NexConfig.h for compatible in arduino uno, is it wrong??
so, what should i do??
noob314:
I have no idea what you did regarding NexConfig.h. Avoid to change any system files after Arduino installation, unless you are certain that will not be harmful or change some functionality. Reinstall clean Arduino software again.
You can do one of two things I already suggested you. If you do any of these, UART code will work.
noob314:
You have to confirm me do you see output on Serial Monitor when compile and upload this example. If you do, your Arduino software and hardware works fine with UART.
Then change your code according to this example and that is all.
Please read the first post in any forum entitled how to use this forum. http://forum.arduino.cc/index.php/topic,148850.0.html .
Then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Can I suggest you look for the NewPing library and let it do ALL the hardwork of driving the ultrasonic unit?
delay(2000);
digitalWrite(TRIGPIN, LOW);
delayMicroseconds(2);
digitalWrite(TRIGPIN, HIGH);
delayMicroseconds(10);
int distance = pulseIn(ECHOPIN, HIGH);
distance = distance/58;
H2 = HT-distance;
Serial.print("t0.txt="");
Serial.print(H2);
Serial.print(""");
/Serial.print("nTinggi.val=5");
Serial.print(H2);
Serial.print(""");/
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
* When a pop or push event occured every time,
* the corresponding component[right page id and component id] in touch event list will be asked. nexLoop(nex_listen_list);/
