Can you link in source code from other sketches?
This is definitely a newb question, but is it possible to link source code from another sketch?
For example, I could have some fully debugged function code that I’d like to include in a sketch, but instead of cut/pasting it into the sketch I’m working on, I’d like to just include a reference link (#include?) to it. That’d keep my sketch easier to work on and debug. I do that kind of stuff all the time in the language I’m used to working in (Clarion…I know, you probably never heard of it :P)
Do you have to create a library or something or can you just include uncompiled source code?
Creating a library is one way. You can't include a .pde file, you can however open tabbed windows in the IDE and paste in .c or .cpp functions and then include them in your main sketch. However best to listen to the software experts that hang around here for gory details, as I only act as a programmer around here. ;)
You have two options. Like retrolefty said, you can open a new tab and paste in the code. Or, as you said, you can create a library and #include it.
To create a library, navigate to your Arduino Sketchbook. If there is not already a folder called Libraries, create one there. Then create a new folder for your library. Plop all the source files in there, including at least one header file.
This last step is crucial. Just when you think you're done, you also have to create an Examples folder inside your library's folder, whether or not you actually write any examples in it. The IDE will not consider your folder a library without the Examples folder.
You must also restart your Arduino environment before Arduino will recognize the library.
johnmchilton: This last step is crucial. Just when you think you're done, you also have to create an Examples folder inside your library's folder, whether or not you actually write any examples in it. The IDE will not consider your folder a library without the Examples folder.
I was ignorant of the Examples folder requirement. Yet I seem to have created libraries that work OK. ???
Hmm, I had to do it.
[quote author=Jack Christensen link=topic=63916.msg465131#msg465131 date=1308019458]
I was ignorant of the Examples folder requirement. Yet I seem to have created libraries that work OK. ??? [/quote]
Looking at the contents of my libraries folder, about 12 entries, none that I wrote, about 3 of them don't have a example folder. I would be very surprised if that is a requirement, it just doesn't make any sense that it would be.
Lefty
Thanks for the replies
