Okay so it's easy to make an LED blink over and over again in a loop.
But what if you just want it to blink once?
Its impossible!!!!!!!!!!!! hence the word "loop"
or maybe put the blink code in setup
or write a statement that is only true once
Bzzzzzt! People have posted examples of similar request and an answer is to put all the blink stuff in setup instead of loop. Also, apparently the below will form a loop when inside of a larger loop, preventing further execution of the larger loop.
for(;;);
How do you get the smiley face in the IDE?
Bzzzzzt!
I was only joking....
maybe you did not finish reading my comment because that is exactly what i said to do. 8)
ok? no one said anything about a for loop though?
The smiley face is just an illusion produced by your online multimedia dashboard as it tries to please and amuse you. Lets see if we can trick it.
for(;;);
Perhaps I was already typing when you made the edit.
Another simple thing would be a variable and if( statement
Like in the beginning
int firstrun = 1,
Then in loop
If( firstrun == 1){
code to blink;
firstrun = 0;
You could also use boolean true and false instead of an int
