My first project!
I have a fairly simple project that uses an Arduino Uno to control 5 LEDs, a buzzer and two small servos (T Pro MicroServo 9g SG90). I'm using a 9V 1A power supply. Everything works great, except for one problem - the servos are moving some small parts and the tolerances are pretty small. When I unplug the Arduino and repower it, the servos reset to zero, which messes up the mechanics. (Also, they buzz slightly when they are powered, which is annoying but not a project-killer). Is it possible to prevent the servos from resetting?
A teacher of mine suggested I reprogram the servos to use less than the full range (1 to 178 degrees) but that didn't work.
Thanks!
