Hello, I am new member of the forum (age 47) and I sometimes tend to find myself overwhelmed when trying to learn new things.
My Resume:
I have a great interest in electronics and want to learn to make thinks like I see in maker fairs, etc. I was initially inspired by they now defunct site "WindStuffNow" to make a wind generator, but as I learned what I would need to learn to get there, I got side tracked.
I used to play with the radio shack science electronics kits, and in fact I have a pretty good one now that I pull out every couple of years. I understand electronics and electricity up to basic transistors, although capacitors still mystify me. I have programmed in BASIC since I was 12, and dabbled in C, JAVA, and Perl. And, I am a router network engineer currently.
While trying to get to the point of being able to build a windmill, I learned to use a metal lathe, milling machine, and tig welder, as well as some basic sand casting of aluminum based on the Gingery series. I have done a small amount of electrical soldering in my life.
So, going forward...
I am getting close to starting to try to make some wind mill projects, and may want to start with some small models etc. One of the things I want to measure would be the RPM that a wind mill I make turns at, while I try to decide on a design. As well, I would like, if I actually make a wind mill, to be able to record the power created over time and graph the results, and finally, make a control system to maintain constant voltages.
I ran across an article about building a gauss/tesla meter with Arduino, and it captured my interest. So, if, eventually, I want to make a tachometer and power meter, and record the information or transmit it to my Mac, ostensibly with an Arduino...
Where should I start?
- What kit to use to first get started learning to connect, program and record data from an Arduino?
- What tutorials to do to learn about building or attaching sensors?
- How to locate similar projects so that I don't have to reinvent the wheel?
- How to locate mentors or trainers in my area to consult if needed?
It's nice to meet you, I look forward to your suggestions.
It seems
