Can you run an LED with analog pins?
I've been doing that since last night, I've checked all the wiring (actually I'm just using two led's for testing purposes. One led is connected to pin 2 (which is HIGH) and one to pin 8 (LOW) and one to analog pin 2 (or pin 16) (LOW) and pin 2 won't work. I've changed the pins, the wires, the led's, the breadboard, everything...
By the way, I'm using an atmega8 on a Arduino NG.
Logically it shoud work, but it doesnt. I've been doing it for long enough so it can't be a wiring problem.
And if I state for example that an analog pin 2 is HIGH/OUTPUT with port register (PORTC = B00000100, DDRC = B00000100) and use another pin as ground, it will work no problem, but if I make a for statement where my pinArray is int pinArray ={14, 15, 16, 17, 18, 19}, it will not work. However if my pinArray is pinArray = {8, 9, 10, 11, 12}, it will work with no problem.
My for statement looks like this:
for (count=0;count<6;count++) {
pinMode(pinArray[count], OUTPUT);
delay(timer2);
delay(timer2);
pinMode(pinArray[count], INPUT);
delay(timer2);
and it works fine (It's a copy from Knight rider example) with pins 8-13, not with analog pins 0-5
strange
