hi, i need send via BT a txt file of sd card, but I find nothing clear about it. Can you send a txt file via Bluetooth? or no?
It is easy enough to send the contents of the file. I guess what isn't clear, or wasn't for me, is that Arduino has no special programming for sending data over bluetooth. The data is sent over serial just like it is sent to the serial monitor. It is, after all, just sending to the serial port and what happens after that is immaterial.
You might find the following background notes useful
http://homepages.ihug.com.au/~npyner/Arduino/GUIDE_2BT.pdf
http://homepages.ihug.com.au/~npyner/Arduino/BT_2_WAY.ino
