This is getting ridiculous! OP - post the skech you are working with. Without knowing what you are doing, we cannot come up with the best solution for you!
(manor_royal: of course you are correct. two booleans, 'logic'd together, will hold 'false', 'true' and '3' perfectly! But is this what luka' is doing? Perhaps two independent tests are in order. Or a switch statement? I mean, we just don't know ...)
The original poster never said he was doing anything, or had any "problem", or needed any "solution." They just had a question; for all we know, it was just a theory question...
westfw:
Again, sometimes you might want to have a nominally boolean variable hold other state information, i.e., usually want is a straight true/false but you might also want a condition that means that the data is valid, or stale or whatever.
As has been stated, a simple byte flag might work in this case with various bits representing the state info + the boolean value. An enum might also work.
A good analogy is the C use of an int for a return from what would normally be a function that returns a char. It can then use "out of band" values such as -1 as a special flag.
This kind of thing is impossible with a true boolean, which is probably what led to the OP.
