Can you use the VL53L0X (DISTANCE SENSOR) without a Library?
I'm doing a project and discovered that in order to get higher marks I would have to use the distance sensor without an imported library. Question is, is this possible? And if is, how would I be able to build this VL53LOX Distance sensor code without any imports?
Thank you in advance
Yes, this is possible.
Do you get even better marks if you don’t use the I2C library?
