I want to control an Ultimaker2 via the usb connection. UM2's usb port is supposedly an Arduino Mega 2560. When I plug a Yun usb to the UM2... I can see the usb device via lsusb:
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 058f:6254 Alcor Micro Corp. USB Hub
Bus 001 Device 007: ID 2341:0042 Arduino SA Mega 2560 R3 (CDC ACM)
Bus 001 Device 005: ID 058f:6366 Alcor Micro Corp. Multi Flash Reader
But looking at /dev/tty* doesn't show any new ports.
Any ideas?
mdoan7:
Any ideas?
@mdoan7,
I don't know, but you may need a driver. Try dmesg
and see what was installed.
also goggle Arduino SA Mega 2560
This showed up in the search
http://www.ladyada.net/learn/arduino/lesson0-lin.html
Remember, this is an OpenWrt kernel, not a stock or standard kernel. Meaning, it is unlikely you have any drivers installed - beyond the minimum.
If you need a driver, these links might help.
arduino/openwrt-packages-yun
Yún Software Packages
http://codesnippets.altervista.org/documentation/yun/packages/packages.html
The Yún CLI Tools
http://codesnippets.altervista.org/documentation/yun/CLI_tools/CLItools.html
Jesse
opkg update
opkg install kmod-usb-acm
ls -al /dev/ttyACM0
crw-rw-rw- 1 root root 166, 0 May 6 01:20 /dev/ttyACM0
I found the kmod-usb-acm shortly after posting the question and it's working nicely now. Thanks everyone for the detailed responses. Awesome forum never fails.
