CANbus Display issues
hey guys
im been tinkering with a display gauge for my car, and now im stuck
it connects to the CANbus no problem, the display is working correctly, but i just cannot get it to display data correctly (or at all really)
currently the Oil pressure digits and bar graph work correctly
but thr boot pressure, oil temp and max boost display nothing and the oil pressure history gauge only seems to come up halfway
as a note if you just use the code related to getting data from the canbus, i can get correct data in the serial monitor
as the full code i can only get the oil pressure data
#include <mcp_can.h>
#include <mcp_can_dfs.h>
#include <SPI.h>
#include <U8x8lib.h>
#include <U8g2lib.h>
//U8G2_SSD1322_NHD_256X64_F_8080 u8g2(U8G2_R0, 40, 41, 42, 43, 44, 45, 46, 47, 30, 31, 28, 29); //[full framebuffer, size = 2048 bytes]
 U8G2_SSD1322_NHD_256X64_F_4W_HW_SPI u8g2(U8G2_R0, 46, 47, 44);
//U8G2_SSD1322_NHD_256X64_F_4W_SW_SPI u8g2(U8G2_R0, 52, 51, 46, 47, 44);
#define U8G2_16BIT
long unsigned int rxId;
unsigned char len = 0;
unsigned char rxBuf[8];
//boost press
int BoostPressure;
int BoostMax = 0;
int BoostBarMax = 30;
//oil press
int OilPressure;
//int OilMax = 0;
int OilMin = 0;
int OilBarMax = 150;
//oil temp
int OilTemp;
bool flashTracker = false;
unsigned long startMillis;
unsigned long currentMillis;
const unsigned long period = 25;
const int sensorHistoryLength = 128;
int sensorHistory[sensorHistoryLength];
int sensorHistoryPos = sensorHistoryLength - 1;
#define Stageas_width 124
#define Stageas_height 30
// 'Stageas', 124x30px
const unsigned char Stageas_bits [] PROGMEM = {
0x00, 0x00, 0x20, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0xc0, 0x3d, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x10, 0x62, 0x0c, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x1e, 0xc0, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x63, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x80, 0x31, 0x00, 0x06, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0xc0, 0x08, 0x00, 0x18, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x60, 0x0c, 0x04, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x60, 0x06, 0x1e, 0xc0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x10, 0x03, 0xfc, 0x83, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x18, 0x03, 0x0c, 0xcc, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x18, 0x03, 0x38, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0xe0, 0x03, 0xe0, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x7f, 0x80, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x8e, 0x0f, 0x0e, 0x00, 0xfe, 0xff, 0xff, 0xff, 0x7f, 0xfe, 0x7f, 0xff, 0x3f, 0xfe, 0x07,
0x00, 0x1e, 0x78, 0x1e, 0x00, 0x7e, 0x00, 0x3c, 0x78, 0x78, 0x0f, 0x80, 0x0f, 0x80, 0x07, 0x07,
0x00, 0x78, 0x80, 0x3f, 0x00, 0xfc, 0x07, 0x1e, 0xfc, 0xff, 0xc7, 0xff, 0xff, 0xcf, 0xff, 0x07,
0x00, 0xe0, 0x01, 0xf0, 0x01, 0x80, 0x1f, 0x0f, 0xff, 0xfb, 0x03, 0xdc, 0x03, 0xe0, 0xbf, 0x03,
0x80, 0x03, 0x03, 0x30, 0xe6, 0xff, 0x8f, 0x87, 0x07, 0xbc, 0xff, 0x8f, 0xff, 0x7f, 0x80, 0x03,
0x60, 0x7c, 0x06, 0x18, 0x02, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x60, 0xf0, 0x0f, 0x18, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0xc0, 0x00, 0x0e, 0x8c, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x80, 0x01, 0x08, 0x8c, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x06, 0x00, 0x76, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x0c, 0x00, 0x33, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x30, 0xc0, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0xf8, 0x00, 0x0f, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x8c, 0x98, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x80, 0x67, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00
#define Stagea_width 256
#define Stagea_height 64
static const unsigned char Stagea_bits[] U8X8_PROGMEM = {
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x3e, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x80, 0x83, 0x3f, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0xf0, 0xff, 0x31, 0x00, 0x06, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x3e, 0x7e, 0x70, 0x80, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x0f, 0x10, 0xf0, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0xe0, 0x07, 0x00, 0xe0, 0xfd, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0xf0, 0x07, 0x02, 0xc0, 0x7b, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x3c, 0xc0, 0x00, 0x00, 0x2f, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x0e, 0x70, 0x00, 0x00, 0x1e, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x07, 0x3c, 0x00, 0x00, 0x7c, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x80, 0x07, 0x0f, 0x00, 0x00, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0xe0, 0x87, 0x07, 0x00, 0x00, 0xe0, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0xf0, 0xc7, 0x03, 0x00, 0x00, 0x80, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x78, 0xe0, 0x01, 0x00, 0x00, 0x00, 0x0f, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x38, 0xf0, 0x00, 0x60, 0x00, 0x00, 0x3c, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x1c, 0x70, 0x00, 0xe0, 0x00, 0x00, 0x78, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x1c, 0x78, 0x00, 0xe0, 0x03, 0x00, 0xe0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x3e, 0x3c, 0x00, 0xf0, 0x1f, 0x00, 0xc0, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x7f, 0x3c, 0x00, 0xe0, 0x7f, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x07, 0x1e, 0x00, 0xe0, 0xfe, 0x3f, 0x00, 0x0f, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x80, 0x03, 0x1e, 0x00, 0xe0, 0xe1, 0xff, 0x80, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x80, 0x03, 0x1e, 0x00, 0xc0, 0x03, 0xe0, 0xf7, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x80, 0x01, 0x0f, 0x00, 0x80, 0x0f, 0x80, 0xff, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0xc0, 0x03, 0x0f, 0x00, 0x00, 0x7f, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0xc0, 0x7f, 0x0f, 0x00, 0x00, 0xfc, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0xfe, 0x0f, 0x00, 0x00, 0xf0, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0xc0, 0xff, 0x00, 0x00, 0xe0, 0x1f, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0xff, 0x0f, 0x00, 0x80, 0x7f, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0xfe, 0xff, 0x01, 0x00, 0xfe, 0x00, 0x00, 0x00, 0x80, 0xff, 0xff, 0xff, 0xfc, 0xff,
  0xff, 0x9f, 0xff, 0xff, 0x03, 0xf8, 0xff, 0xff, 0x1f, 0xfc, 0xff, 0xff, 0x1f, 0xfc, 0xff, 0x3f,
  0x00, 0x00, 0xfe, 0xf1, 0x1f, 0x00, 0xfc, 0x03, 0x00, 0x00, 0xc0, 0xff, 0xff, 0xff, 0xfe, 0xff,
  0xff, 0xff, 0xff, 0xff, 0x07, 0xff, 0xff, 0xff, 0x1f, 0xff, 0xff, 0xff, 0x1f, 0xfe, 0xff, 0x7f,
  0x00, 0x00, 0xfc, 0x01, 0xfe, 0x03, 0xf0, 0x07, 0x00, 0x00, 0xe0, 0xff, 0xff, 0x7f, 0xff, 0xff,
  0xff, 0xff, 0xff, 0xff, 0xc7, 0xff, 0xff, 0xff, 0xcf, 0xff, 0xff, 0xff, 0x0f, 0xff, 0xff, 0x7f,
  0x00, 0x00, 0xf8, 0x03, 0xe0, 0x3f, 0xf0, 0x0f, 0x00, 0x00, 0xe0, 0x7f, 0x00, 0x00, 0x00, 0xfe,
  0x01, 0xf8, 0x07, 0xf0, 0xe7, 0x3f, 0x00, 0x00, 0xe0, 0x7f, 0x00, 0x00, 0xc0, 0x3f, 0x80, 0x3f,
  0x00, 0x00, 0xf0, 0x07, 0x00, 0xfe, 0xe7, 0x0f, 0x00, 0x00, 0xe0, 0xff, 0x07, 0x00, 0x00, 0xff,
  0x00, 0xfc, 0x03, 0xf8, 0xf7, 0x0f, 0xfc, 0xff, 0xf7, 0xff, 0xff, 0xff, 0xe1, 0x1f, 0x80, 0x3f,
  0x00, 0x00, 0xe0, 0x1f, 0x00, 0xc0, 0xff, 0x1f, 0x00, 0x00, 0xc0, 0xff, 0xff, 0x00, 0x80, 0x7f,
  0x00, 0xff, 0xff, 0xfb, 0xf3, 0x07, 0xfe, 0xff, 0xf7, 0xff, 0xff, 0xff, 0xf1, 0xff, 0xbf, 0x3f,
  0x00, 0x00, 0x80, 0x7f, 0x00, 0x00, 0xfc, 0x1f, 0x00, 0x00, 0x00, 0xff, 0xff, 0x07, 0xc0, 0x3f,
  0x80, 0xff, 0xff, 0xfb, 0xfb, 0x03, 0xfe, 0xff, 0xfb, 0xff, 0xff, 0xff, 0xf8, 0xff, 0xff, 0x1f,
  0x00, 0x00, 0x00, 0xfe, 0x01, 0x00, 0x80, 0xff, 0x01, 0x00, 0x00, 0xe0, 0xff, 0x0f, 0xe0, 0x1f,
  0xc0, 0xff, 0xff, 0xf9, 0xfb, 0x03, 0x00, 0xfe, 0xf9, 0x07, 0x00, 0x00, 0xfe, 0xff, 0xdf, 0x1f,
  0x00, 0x00, 0x00, 0xf8, 0x07, 0x00, 0x00, 0xfe, 0x3f, 0x00, 0x00, 0x00, 0xfc, 0x1f, 0xf0, 0x0f,
  0xe0, 0xff, 0xff, 0xfc, 0xf9, 0x03, 0x00, 0xfe, 0xf8, 0x03, 0x00, 0x00, 0xff, 0xff, 0xc7, 0x1f,
  0x00, 0x00, 0x00, 0xe0, 0x0f, 0x00, 0x00, 0x1e, 0x7f, 0x00, 0x00, 0x00, 0xf0, 0x1f, 0xf8, 0x07,
  0xf8, 0x0f, 0x00, 0xfc, 0xf9, 0x07, 0x80, 0x7f, 0xf8, 0x07, 0x00, 0x80, 0x7f, 0x00, 0xc0, 0x1f,
  0x00, 0x00, 0x07, 0x00, 0x3f, 0x00, 0x00, 0x1e, 0x70, 0xc0, 0xff, 0xff, 0xff, 0x0f, 0xfc, 0x03,
  0xfc, 0x07, 0x00, 0xfc, 0xf1, 0xff, 0xff, 0x3f, 0xf0, 0xff, 0xff, 0xcf, 0x3f, 0x00, 0xe0, 0x0f,
  0x00, 0xe0, 0x7f, 0x00, 0x7c, 0x00, 0x00, 0x1e, 0x70, 0xe0, 0xff, 0xff, 0xff, 0x07, 0xfc, 0x01,
  0xfe, 0x01, 0x00, 0xfc, 0xe1, 0xff, 0xff, 0x1f, 0xe0, 0xff, 0xff, 0xf7, 0x1f, 0x00, 0xe0, 0x0f,
  0x00, 0xf8, 0xf0, 0x01, 0xf8, 0x00, 0x00, 0x1e, 0x38, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x3c, 0xc0, 0xff, 0xe3, 0x00, 0x00, 0x0f, 0x38, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x1c, 0x00, 0xff, 0xff, 0x01, 0x00, 0x0f, 0x3e, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x38, 0x00, 0x80, 0xff, 0x01, 0x00, 0xc7, 0x1f, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0xf0, 0x00, 0x00, 0xfc, 0x01, 0x80, 0x87, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0xc0, 0x01, 0x00, 0xf0, 0x01, 0x80, 0x03, 0x0f, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x80, 0x07, 0x00, 0xc0, 0x01, 0xc0, 0x03, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x0f, 0x00, 0x80, 0x00, 0xe0, 0x81, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x3c, 0x00, 0x00, 0x00, 0xf0, 0xc0, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x78, 0x00, 0x00, 0x00, 0x78, 0xfc, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0xe0, 0x01, 0x00, 0x00, 0x3c, 0xfc, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0xc0, 0x03, 0x00, 0x00, 0x1e, 0x18, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x80, 0x0f, 0x00, 0x00, 0x07, 0x1c, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x1e, 0x00, 0xc0, 0x01, 0x0e, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x80, 0x3d, 0x00, 0x30, 0x88, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x80, 0xf7, 0x00, 0x00, 0xfc, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0xe0, 0xe7, 0x01, 0x00, 0xfc, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0xf0, 0xc1, 0x01, 0x03, 0x1e, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x38, 0x80, 0xc1, 0xdf, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x0c, 0x80, 0xfb, 0xfc, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x80, 0x3f, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
MCP_CAN CAN0(10);                          // Set CS to pin
void setup(void) {
  u8g2.begin();
  u8g2.setFlipMode(1);
  if(CAN0.begin(MCP_STD, CAN_1000KBPS, MCP_16MHZ) == CAN_OK) Serial.print("MCP2515 Init Okay!!\r\n");
  else Serial.print("MCP2515 Init Failed!!\r\n");
  pinMode(2, INPUT);                       // Setting pin 2 for /INT input
  CAN0.init_Mask(0,0,0x03FF0000);                // Init first mask...
  CAN0.init_Filt(0,0,0x03610000);                // Init first filter...
  CAN0.init_Filt(1,0,0xFFFFFFFF);                // Init second filter...
  CAN0.init_Mask(1,0,0x03FF0000);                // Init second mask...
  CAN0.init_Filt(2,0,0x03610000);                // Init third filter...
  CAN0.init_Filt(3,0,0x03E00000);                // Init fourth filter...
  CAN0.init_Filt(4,0,0x03600000);                // Init fifth filter...
  CAN0.init_Filt(5,0,0x03610000);                // Init sixth filter...
  Serial.println("MCP2515 Library Mask & Filter Example...");
  CAN0.setMode(MCP_NORMAL);                // Change to normal mode to allow messages to be transmitted
  u8g2.clearBuffer();
    u8g2.drawXBMP(0,0, Stagea_width, Stagea_height, Stagea_bits);
  u8g2.sendBuffer();
  delay(2000);
  u8g2.clearBuffer();
    u8g2.drawLine(0, 32, 256, 32);
    u8g2.drawXBMP(132, 34, Stageas_width, Stageas_height, Stageas_bits);
    u8g2.drawLine(128, 32, 128, 64);
  u8g2.sendBuffer();
void loop(void) {
  if(!digitalRead(2))                    // If pin 2 is low, read receive buffer
      CAN0.readMsgBuf(&rxId, &len, rxBuf); // Read data: len = data length, buf = data byte(s)
        if (rxId == 0x0360)  //Boost Filter
      int BoostRaw = rxBuf[2] * 256 + rxBuf[3];
      for (int i = 0; i < len; i++) // print the data
      float absolutePressure = BoostRaw /10 ;
      // Subtract 14.7 psi == pressure at sea level
      BoostPressure = (absolutePressure / 6.895) - 14.7;
      Serial.print(BoostPressure);
        // Update max and min
      if (BoostPressure > BoostMax) BoostMax = BoostPressure;
       // Log the history
      addSensorHistory(BoostPressure);
            if (rxId == 0x0361)  //Oil Pressure Filter
      int OilPRaw = rxBuf[2] * 256 + rxBuf[3];
      float OilPressureK = OilPRaw /10 ;
      OilPressure = (OilPressureK - 101.3) / 6.895;
      Serial.print(OilPressure);
      //if (OilPressure > OilMax) OilMax = OilPressure;
      if (OilPressure < OilMin) OilMin = OilPressure;
      // Log the history
      addSensorHistory(OilPressure);
            if (rxId == 0x03E0)  //Oil Temp Filter
      int OilTRaw = rxBuf[6] * 256 + rxBuf[7];
      float OilTempK = OilTRaw /10 ;
      OilTemp = OilTempK - 273.15;
      Serial.print(OilTemp);
  u8g2.clearBuffer();
    // Draw current oilpressure
    u8g2.setFont(u8g2_font_fub20_tf);
    char cstr[6];
    dtostrf((float)OilPressure, 1, 1, cstr);
    u8g2.drawStr(0, 20, cstr);
    // Draw current pressure
    dtostrf((float)BoostPressure, 1, 2, cstr);
    u8g2.drawStr(130, 22, cstr);
    u8g2.drawLine(128, 0, 128, 32);
        // Draw oil temp
    u8g2.setFont(u8g2_font_fub11_tf);
    dtostrf((float)OilTemp, 1, 2, cstr);
    int yPos1 = u8g2.getStrWidth(cstr);
    u8g2.drawStr(115 - yPos1, 11, cstr);
    u8g2.setCursor(115, 11);
    u8g2.print("c");
    // Draw max pressure
    dtostrf((float)BoostMax
    / 100, 1, 2, cstr);
    int yPos = u8g2.getStrWidth(cstr);
    u8g2.drawStr(256 - yPos, 11, cstr);
    drawBarGraph(0, 22, 128, 8);
    drawBarGraph1(128, 22, 256, 8);
    u8g2.updateDisplayArea(0, 0, 32, 4);
    drawGraph(0, 32, 128, 31);
    u8g2.updateDisplayArea(0, 7, 16, 4);
void addSensorHistory(int val) {
  sensorHistory[sensorHistoryPos] = val;
  sensorHistoryPos--;
  if (sensorHistoryPos < 0) sensorHistoryPos = sensorHistoryLength - 1;
int getSensorHistory(int index) {
  index += sensorHistoryPos;
  if (index >= sensorHistoryLength) index = index - sensorHistoryLength;
  return sensorHistory[index];
// Display functions
void drawGraph(int x, int y, int len, int height) {
  // Draw the lines
  drawHorizontalDottedLine(x, y, len);
  drawHorizontalDottedLine(x, y + height, len);
  //var absMin = Math.abs;
  int absMin = abs(OilMin);
  int range = absMin + OilBarMax;
  // Draw 0 line
  int zeroYPos = mapValueToYPos(absMin, range, y, height);
  drawHorizontalDottedLine(x, zeroYPos, len);
  // Draw the graph line
  for (int i = 0; i < 128; i++) {
    // Scale the values so that the min is always 0
    int valueY = getSensorHistory(i) + absMin;
    // Calculate the coordinants
    int yPos = mapValueToYPos(valueY, range, y, height);
    int xPos = len - i;
    if (yPos < zeroYPos) {
      // Point is above zero line, fill in space under graph
      u8g2.drawVLine(xPos, yPos, zeroYPos + 1 - yPos);
      // Point is below zero line, draw graph line without filling in
      u8g2.drawPixel(xPos, yPos);
void drawBarGraph(int x, int y, int len, int height) {
  if (OilPressure > 0) {
    // Draw the pressure bar behind the graph
    int barLength = ((float)OilPressure / OilBarMax) * len;
    u8g2.setDrawColor(2);
    u8g2.drawBox(x, y, barLength, height);
    u8g2.setDrawColor(1);
void drawBarGraph1(int x, int y, int len, int height) {
  if (BoostPressure > 0) {
    int barLength = ((float)BoostPressure / BoostBarMax) * len;
// Maps a value to a y height
int mapValueToYPos(int val, int range, int y, int height) {
  float valueY = ((float)val / range) * height;
  return y + height - (int)valueY;
void drawHorizontalDottedLine(int x, int y, int len) {
  for (int i = 0; i < len; i++) {
    if (!(i % 4)) u8g2.drawPixel(x + i, y);
sorry if the code is messy, this is my first attempt and ive kind of pieced it together from examples
