CANbus MCP2515 source/destination filtering
I am in the middle of building a custom Canbus IO module based off an Atmega2560 chip. The module will have 10 high current outputs with pwm control and current feedback, 20 digital inputs, 5 analog inputs and 4 0-5v analog outputs. I've been working on figuring out the J1939 message structure I'll be using. These modules will be slave devices being controlled by a master ECU. Since more than one of these modules may be on the same network, I've added a CAN Address switch to each module so the user can select the CAN ID 1-255 of each unit. The plan was to have each module broadcast the state of all the digital inputs in a single CAN message. If I Select 0xFF00 as the PGN ID and then use the 8 bytes to represent the state in bit form for the status of the input for that particular module then how does the master know which module the message came from? Is the module address in the CANbus message?
I've been looking at the arduino CANBUS examples for the MCP2515 module and it looks like you can filter based on PGN but I don't see anything to filter based on source address or destination address.
I am also trying to figure out how to add the Module ID to a message when I send it.
Can someone provide some clarification on how I might do this?
I believe I've figured out some of my question.
So if I want to broadcast the status of all the inputs using a single message i would create the message in the following format:
Priority - 0C - 12
PGN - FF03 - 65283
Source Address - FE - 254
0x0CFF03FE plus 8 bytes of input status data
Does this look correct?
Did you ever figure this out? im trying to filter based on the source address
