Canbus message filtering
if (mcp2515_check_message())
    if (mcp2515_get_message(&message))
          if(message.id == 0x181 and
     message.data[0] == 0x00 and
     message.data[1] == 0x23 and
     message.data[2] == 0x00 and
     message.data[3] == 0x01)
               Serial.println("Show green LED");
               digitalWrite(ledPin, HIGH); //Set LED on
               digitalWrite(ledPin, LOW); //Set LED off
How can I add additional message with 181 data: 00 23 00 00 and show RED led ?
      if (message.id == 0x181 and
      message.data[2] == 0x00)
        digitalWrite(GreenLEDPin, LOW); // Set LED off
        digitalWrite(RedLEDPin, LOW); //Set LED off
        if (message.data[3] == 0x01)
          digitalWrite(GreenLEDPin, HIGH); //Set LED on
        else if (message.data[3] == 0x00)
          Serial.println("Show red LED");
          digitalWrite(RedLEDPin, HIGH); //Set LED on
If you compare the same value to more than two constants it is probably time to change to a switch/case statement:
        switch (message.data[3])
          case 0x00:
          case 0x01:
It's a shortcut for:
  if (intVariable == intConstantA)
  else if (intVariable == intConstantB)
  else if (intVariable == intConstantC)
  else if (intVariable == intConstantD)
    // Default if nothing else matched
