Canbus Shield V1.2 problems
using Arduino Uno + Canbus Shield V1.2 using the library
during testing with a numberof other Can devices the methods MCP_CAN::isExtendedFrame() and MCP_CAN::isRemoteRequest() were reporting incorrect values
in particular after the first Extended frame MCP_CAN::isExtendedFrame() reported all following frames as Extended 29bit even if they were standard 11bit frames
investigation showed problems with method MCP_CAN::mcp2515_read_canMsg not setting the parameters correctly
this code appears to work
void MCP_CAN::mcp2515_read_canMsg( const byte buffer_load_addr, volatile unsigned long *id, volatile byte *ext, volatile byte *rtrBit, volatile byte *len, volatile byte *buf)        /* read can msg                 */
  byte tbufdata[4];
  byte i;
  MCP2515_SELECT();
  spi_readwrite(buffer_load_addr);
  // mcp2515 has auto-increment of address-pointer
  for (i = 0; i < 4; i++) tbufdata[i] = spi_read();
  *rtrBit=(tbufdata[3]&0x08 ? 1 : 0 );            // <<<  does not work 23/1/2018
  *id = (tbufdata[MCP_SIDH] << 3) + (tbufdata[MCP_SIDL] >> 5);
   *ext=0;                                           // <<<   zero EXT bit  23/1/2013
  if ( (tbufdata[MCP_SIDL] & MCP_TXB_EXIDE_M) ==  MCP_TXB_EXIDE_M )
    /* extended id                  */
    *id = (*id << 2) + (tbufdata[MCP_SIDL] & 0x03);
    *id = (*id << 8) + tbufdata[MCP_EID8];
    *id = (*id << 8) + tbufdata[MCP_EID0];
    *ext = 1;
 // *len=spi_read() & MCP_DLC_MASK;             // <<< replaced with following statements
   byte pMsgSize=spi_read();                    // <<< read Data Length 23/1/2018
  *len=pMsgSize & MCP_DLC_MASK;                // <<< message length 23/1/2018
  *rtrBit=(pMsgSize & MCP_RTR_MASK ? 1 : 0 );  // <<  get RTR bit  23/1/2018
 for (i = 0; i < *len && i<CAN_MAX_CHAR_IN_MESSAGE; i++) {
    buf[i] = spi_read();
  MCP2515_UNSELECT();
testing with
#include <SPI.h>
#include "mcp_can.h"
// the cs pin of the version after v1.1 is default to D9
// v0.9b and v1.0 is default D10
const int SPI_CS_PIN = 10;//9;
MCP_CAN CAN(SPI_CS_PIN);                                    // Set CS pin
    while (CAN_OK != CAN.begin(CAN_500KBPS))              // init can bus : baudrate = 500k
        Serial.println("CAN BUS Shield init fail");
        Serial.println(" Init CAN BUS Shield again");
        delay(100);
    Serial.println("CAN BUS Shield init ok!");
    unsigned char len = 0;
    unsigned char buf[8]={0};
    if(CAN_MSGAVAIL == CAN.checkReceive())            // check if data coming
        CAN.readMsgBuf(&len, buf);    // read data,  len: data length, buf: data buf
        unsigned long int canId = CAN.getCanId();
        char text[50]={0};
        // setup standard 11 bit or extended 29 bit frame and add ID value
        if(CAN.isExtendedFrame()) strcat(text,"EXT "); else strcat(text,"STD ");
        sprintf(&text[strlen(text)]," ID %08lx ", canId);
        Serial.print(text);
        // check RTR or data frame
        if(CAN.isRemoteRequest()) Serial.print(" RTR ");
           for(int i = 0; i<8; i++)    // print the data
             Serial.print(buf[i], HEX);
a run gives
STD  ID 00000008 E6594DC30000
STD  ID 00000008  RTR
EXT  ID 000879fd E6594DC30000
EXT  ID 000879fd  RTR
STD  ID 00000087 E6594DC30000
has anyone else found similar problems?
