Cannot bootload new ATMega328P-PB(s)
I have 4 brand new ATMEGA328P and I try to bootload them but non of them successes.
Ways I have tried:
USBasp -> ATMEGA328P on breadboard (with external 16M oscillator, 10K pull-up resistor)
USBasp -> ATMEGA328P on breadboard (with nothing, minimum config)
USBasp -> ATMEGA328P on Arduino UNO
Arduino UNO as ISP -> ATMEGA328P on breadboard (with external 16M oscillator, 10K pull-up resistor)
I purchased chips from 2 different vendors so it should not be the chip's problem. I checked the wiring for many many times and there should not be any problem with it. I can use any of the above setup to bootload a bootloaded ATMEGA328P (the one comes with the UNO board), but not any brand new one.
System is Ubuntu 16.04. Installed Avrdude 6.3. USBasp is the standard one from www.fischl.de.
This is the output when using USBasp:
root@Howard-Ubuntu:/home/howard# avrdude -c usbasp -p m328p -v
avrdude: Version 6.3, compiled on Jun 16 2017 at 22:44:18
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/usr/local/etc/avrdude.conf"
User configuration file is "/root/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : usb
Using Programmer : usbasp
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : usbasp
Description : USBasp, USBasp - USB programmer for Atmel AVR controllers - fischl.de
avrdude: auto set sck period (because given equals null)
avrdude: error: program enable: target doesn't answer. 1
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude done. Thank you.
This is the output when using arduino UNO as ISP:
howard@Howard-Ubuntu:~$ avrdude -c avrisp -P /dev/ttyACM0 -p m328p
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude: Device signature = 0x000000 (retrying)
avrdude: Yikes! Invalid device signature.
this check.
I'm confused by your posts title - ATMega328P-PB. The everyday 28 pin dip part should be marked ATMEGA328P-PU.
There is a newer version of the part which is ATMEGA328PB but it's not available in 28 pin dip packages.
What is the exact marking on the devices you purchased?
+1 for what avr_fred said, but also the fact that you're getting a device signature of 0 points towards a wiring problem.
