I'm trying to use my Arduino Duemilanove board to burn a bootloader to an ATMega328P device.
My computer is running Linux (Ubuntu 18.04), and I'm using the most recent IDE 1.8.13 downloaded from the arduino.cc site.
I've hooked up the ATMega I'm trying to burn with the bootloader on a breadboard using an external 16MHz crystal, per this article: Using an Arduino as an AVR ISP | ArduinoDev.com (the circuit diagram is at the bottom of the page).
I am following this guide: https://www.arduino.cc/en/pmwiki.php?n=Tutorial/ArduinoISP and I have:
- Opened the ArduinoISP example sketch, #define'd USE_OLD_STYLE_WIRING (as I'm using pins 11, 12, and 13 for MOSI, MISO and SCK respectively)
- Compiled the sketch and uploaded to the Duemilanove
- Tools->Boards: 'Arduino Duemilanove or Diecilma'
- Tools->Processor: 'ATMega328P'
- Tools->Programmer: 'Arduino as ISP'
- Tools->Burn bootloader
Sadly the bootloader burn fails, with this verbose output from the burning process:
/home/tom/bin/arduino-1.8.13/hardware/tools/avr/bin/avrdude -C/home/tom/bin/arduino-1.8.13/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -cstk500v1 -P/dev/ttyUSB0 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0xFD:m -Uhfuse:w:0xDA:m -Ulfuse:w:0xFF:m
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/home/tom/bin/arduino-1.8.13/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/home/tom/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/ttyUSB0
Using Programmer : stk500v1
Overriding Baud Rate : 19200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x15
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x15
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : STK500
Description : Atmel STK500 Version 1.x firmware
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x14
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x02
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x10
Hardware Version: 4238814
Firmware Version: 18613904.0
Topcard : STK502
Vtarget : 1.8 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: stk500_initialize(): (b) protocol error, expect=0x10, resp=0x01
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x10
avrdude done. Thank you.
Error while burning bootloader.
I'm not expert enough in arvdude to be able to debug this further. Any suggestions?
