Cannot change transistor State in peer to peer communication of ESP32 boards
Hi all,
I have connected my ESP32 board to a 12V LED using a MOSFET transistor and is operated using a touchPin. The idea is to have 2 identical boards and when I turn on the lamp on one board it should also light up on the other using Wifi (as the boards will not be located in the same physical location and will be connected to different networks).
On their own they do work like a charm but as soon as I want to retrieve the other boards transistor state via a GET request it does not work as intended. I was wondering if someone could point out to me what is wrong with my code please?
#include <WiFi.h>
#include <WiFiMulti.h>
#include <AsyncTCP.h>
#include <ESPAsyncWebServer.h>
#include <Husarnet.h>
#include <SPI.h>
#include <TFT_eSPI.h>
#define ENABLE_TFT 1  // tested on TTGO T Display
#if ENABLE_TFT == 1
TFT_eSPI tft = TFT_eSPI();
#define LOG(f_, ...)                                                         \
    if (tft.getCursorY() >= tft.height() || tft.getCursorY() == 0) {         \
      tft.fillScreen(TFT_BLACK);                                             \
      tft.setCursor(0, 0);                                                   \
      IPAddress myip = WiFi.localIP();                                       \
      tft.printf("IP: %u.%u.%u.%u\r\n", myip[0], myip[1], myip[2], myip[3]); \
      tft.printf("Hostname: %s\r\n--\r\n", Husarnet.getHostname());          \
    tft.printf((f_), ##__VA_ARGS__);                                         \
    Serial.printf((f_), ##__VA_ARGS__);                                      \
#else
  { Serial.printf((f_), ##__VA_ARGS__); }
#endif
/* =============== config section start =============== */
#if __has_include("credentials.h")
#include "credentials.h"
#else
/* to get your join code go to https://app.husarnet.com
   -> select network
   -> click "Add element"
   -> select "join code" tab
   Keep it secret!
const char *husarnetJoinCode = "XXXXXXXXXXXXXXXXXXXXX";
const char *dashboardURL = "default";
// WiFi credentials
const char* wifiNetworks[][2] = {
  {"Wifi-Name1", "password"},
const char *hostname = "random";
#endif
/* =============== config section end =============== */
using namespace ace_button;
const int PORT = 8001;
//set Pin Numbers
const int touchPin = 4;
const int transistor = 16;
// change with threshold value
const int threshold = 20;
// variable for storing the touch pin value
int touchValue;
byte lastButtonState = LOW;
byte buttonState = LOW;
byte transistorState = LOW;
int transistorStateInt = 0;
unsigned long debounceDuration = 50; // millis
unsigned long lastTimeButtonStateChanged = 0;
// you can provide credentials to multiple WiFi networks
WiFiMulti wifiMulti;
// store index.html content in html constant variable (platformio feature)
extern const char index_html_start[] asm("_binary_src_index_html_start");
const String html = String((const char*)index_html_start);
AsyncWebServer server(PORT);
// Task functions
void taskWifi(void *parameter);
  Serial.begin(1155200);
  // Initialise the LED Pin as an output
  pinMode(transistor, OUTPUT);
#if ENABLE_TFT == 1
  tft.init();
  tft.setRotation(0);
  tft.setTextColor(TFT_WHITE, TFT_BLACK);
  tft.setTextSize(1);
#endif
  // Save Wi-Fi credentials
  for (int i = 0; i < (sizeof(wifiNetworks)/sizeof(wifiNetworks[0])); i++) {
    wifiMulti.addAP(wifiNetworks[i][0], wifiNetworks[i][1]);
    Serial.printf("WiFi %d: SSID: \"%s\" ; PASS: \"%s\"\r\n", i, wifiNetworks[i][0], wifiNetworks[i][1]);
  // Husarnet VPN configuration
  Husarnet.selfHostedSetup(dashboardURL);
  Husarnet.join(husarnetJoinCode, hostname);
  // A dummy web server (see index.html)
  server.on("/", HTTP_GET, [](AsyncWebServerRequest* request) {
    request->send(200, "text/html", html);
  // Send a GET request to <IP>/led/<number>/state/<0 or 1>
  server.on("^\\/led\\/([0-9]+)\\/state\\/([0-9]+)$", HTTP_GET, [] (AsyncWebServerRequest *request) {
    String ledNumber = request->pathArg(0); // currently unused - we use only a predefined LED number
    String state = request->pathArg(1);
    if(state.toInt() == 0){
      digitalWrite(transistor, LOW);
    }else if(state.toInt() == 1){
      digitalWrite(transistor, HIGH);
    request->send(200, "text/plain", "LED: " + ledNumber + ", with state: " + state);
  xTaskCreate(taskWifi,   /* Task function. */
              "taskWifi", /* String with name of task. */
              10000,      /* Stack size in bytes. */
              NULL,       /* Parameter passed as input of the task */
              1,          /* Priority of the task. */
              NULL);      /* Task handle. */
  while (1) {
  touchValue = touchRead(touchPin);
  //Serial.print(touchValue);
  if (millis() - lastTimeButtonStateChanged > debounceDuration) {
  // check if the touchValue is below the threshold
  // if it is, set ledPin to HIGH
    buttonState = (touchValue < threshold) ? HIGH: LOW;
    if (buttonState != lastButtonState) {
      lastTimeButtonStateChanged = millis();
      lastButtonState = buttonState;
      if (buttonState == LOW) {
        transistorState = (transistorState == HIGH) ? LOW: HIGH;
        digitalWrite(transistor, transistorState);
        if(transistorState == LOW){
        } else{
          transistorState = 1;
  for (auto const &host : Husarnet.listPeers()) {
    IPv6Address peerAddr = host.first;
    if(host.second == "master") {
      AsyncClient* client_tcp = new AsyncClient;
      client_tcp->onConnect([](void *arg, AsyncClient *client) {
        String requestURL = "/led/1/state/" + String(transistorStateInt);
        String GETreq = String("GET ") + requestURL + " HTTP/1.1\r\n" + "Host: esp32\r\n" + "Connection: close\r\n\r\n";
        if ( client->canSend() && (client->space() > GETreq.length())){
          client->add(GETreq.c_str(), strlen(GETreq.c_str()));
	        client->send();
          Serial.printf("\r\nSENDING ERROR!\r\n");
      }, client_tcp);
      client_tcp->onData([](void *arg, AsyncClient *client, void *data, size_t len) {
        Serial.printf("\r\nResponse from %s\r\n", client->remoteIP().toString().c_str());
	      Serial.write((uint8_t *)data, len);
        client->close();
      }, client_tcp);
      client_tcp->onDisconnect([](void* arg, AsyncClient* client) {
        Serial.println("[CALLBACK] discconnected");
        delete client;
      }, client_tcp);
      client_tcp->onError([](void* arg, AsyncClient* client, int8_t error) {
        Serial.printf("[CALLBACK] error: %d\r\n", error);
      }, NULL);
      client_tcp->onTimeout([](void* arg, AsyncClient* client, uint32_t time) {
        Serial.println("[CALLBACK] ACK timeout");
      }, NULL);
      client_tcp->connect(peerAddr, PORT);
      LOG("Sending HTTP req to:\r\n%s:\r\n%s\r\n\r\n", host.second.c_str(), host.first.toString().c_str());
void taskWifi(void *parameter) {
  uint8_t stat = WL_DISCONNECTED;
  while (stat != WL_CONNECTED) {
    stat = wifiMulti.run();
    Serial.printf("WiFi status: %d\r\n", (int)stat);
    delay(100);
  Serial.printf("WiFi connected\r\n", (int)stat);
  // Start Husarnet VPN Client
  Husarnet.start();
  // Start HTTP server
  server.begin();
  LOG("READY!\r\n");
  while (1) {
    while (WiFi.status() == WL_CONNECTED) {
    LOG("WiFi disconnected, reconnecting\r\n");
    LOG("WiFi status: %d\r\n", (int)stat);
I haven't read your code.
Anyway I can ask a question: did you try to veryfy if your "get" part works at all by printing to the serial monitor?
I don't know any details about how "get" over Wifi works. But the receiving unit is receiving "something" I guess some characters at least. So it should be possible to print the received characters to the serial monitor to analyse what character-sequence is the receiving unit really receiving.
the while(1) loop under loop itself is not nescessary
inside function taskWifi()
you have a blocking loop while(1)
are you sure that this is working?
best regards Stefan
