Cannot combine I2C with the Serial port
Does someone understand why the below code does not work. Basically it's simple I set up an I2C link to display a message on a 64*128 OLED screen and with python I send H and L bytes to blink the connected LED on pin 2 via serial communication on COM6. When I have commented the write_init();, with //, and send H and L via python the LED blinks. When however I uncomment the write_init(); and send the H and L data via python again the LED does not blink anymore ?? Somehow it looks that using the I2C disables the serial communication. I use an Arduino UNO, How can I resolve this ?
Assembly Programmer
created 2021
by Rolf Dubbeld
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
// Declaration for an SSD1306 display connected to I2C (SDA, SCL pins)
// The pins for I2C are defined by the Wire-library.
// On an arduino Nano: A4(SDA), A5(SCL)
// On an arduino UNO: A4(SDA), A5(SCL)
// On an arduino MEGA 2560: 20(SDA), 21(SCL)
// On an arduino LEONARDO: 2(SDA), 3(SCL),
// On an Teensy 4.0: 18(SDA), 19(SCL),
#define OLED_RESET -1 // Reset pin # (or -1 if sharing Arduino reset pin)
#define SCREEN_ADDRESS 0x3C ///< See datasheet for Address; 0x3D for 128x64, 0x3C for 128x32
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
const int ledPin = 2; // the pin that the LED is attached to
char incomingByte;
// initialize serial communication:
pinMode(ledPin, OUTPUT);
// SSD1306_SWITCHCAPVCC = generate display voltage from 3.3V internally
if(!display.begin(SSD1306_SWITCHCAPVCC, SCREEN_ADDRESS))
{ Serial.println(F("SSD1306 allocation failed"));
for(;;); // Don't proceed, loop forever
write_init();
digitalWrite(ledPin, HIGH);
delay(2000);
digitalWrite(ledPin, LOW);
{ // see if there's incoming serial data:
if (Serial.available() > 0)
{ // read the oldest byte in the serial buffer:
incomingByte = Serial.read();
// if it's a capital H (ASCII 72), turn on the LED:
if (incomingByte == 'H') { digitalWrite(ledPin, HIGH); }
// if it's an L (ASCII 76) turn off the LED:
if (incomingByte == 'L') {digitalWrite(ledPin, LOW); }
void write_init()
{ display.clearDisplay();
display.setTextSize(1); // Normal 1:1 pixel scale
display.setTextColor(SSD1306_WHITE); // Draw white text
display.setCursor(0,0);
display.println("ASSEMBLY RCVR");
display.display(); delay(1000);
I'm thinking about a hardware problem and the I2C bus.
Is something displayed on the OLED ?
Can you add more messages ?
For example
Serial.println( "before write_init");
write_init();
Serial.println( "after write_init");
Could you edit your post and make the sketch look like a sketch, with three backslash-single-quotes ?
Your sketch
What do you get if you run the i2cScanner sketch? Does it show you device on the i2c bus?
