Success!
I rewrote the code and now TCMux, DHT22 and TEMT6000 are giving me nice data on the serial monitor.
//Lib für RTC
#include "RTClib.h"
//lib for TCMux
#include <string.h> //Use the string Library
#include <ctype.h>
#include <EEPROM.h>
//lib for DHT22
#include <DHT.h>;
//Define var für rtc funktion
RTC_PCF8523 rtc;
// Define var for temt6000
int temt6000Pin = A0;
float light;
int light_value;
// vars and pins for TCMux
/* PINS */
//#define SHOWMEYOURBITS // Display the raw 32bit binary data from the MAX31855
#define PINEN 7 //Mux Enable pin
#define PINA0 4 //Mux Address 0 pin
#define PINA1 5 //Mux Address 1 pin
#define PINA2 6 //Mux Address 2 pin
#define PINSO 12 //TCAmp Slave Out pin (MISO)
#define PINSC 13 //TCAmp Serial Clock (SCK)
#define PINCS 9 //TCAmp Chip Select Change this to match the position of the Chip Select Link
/* COM */
static const uint16_t BAUDRATE = 9600;
int Temp[8], SensorFail[8];
float floatTemp, floatInternalTemp;
char failMode[8];
int internalTemp, intTempFrac;
unsigned int Mask;
//char data[16];
byte j, NumSensors =8, UpdateDelay = 1;
char i;
char Rxchar, Rxenable, Rxptr, Cmdcomplete, R;
char Rxbuf[32];
char adrbuf[3], cmdbuf[3], valbuf[12];
int val = 0, Param;
unsigned long time;
//Define var & const for DHT22
//Constants
#define DHTPIN 2 // what pin we're connected to
#define DHTTYPE DHT22 // DHT 22 (AM2302)
DHT dht(DHTPIN, DHTTYPE); //// Initialize DHT sensor for normal 16mhz Arduino
//Variables
int chk;
float hum; //Stores humidity value
float temp; //Stores temperature value
// setup for RTC
Serial.begin(BAUDRATE);
// überprüft ob er den rtc findet oder nicht
// wenn nicht Couldnt find rtc und wartet 10ms
if (! rtc.begin()) {
Serial.println("Couldn't find RTC");
Serial.flush();
while (1)
delay(10);
if (! rtc.initialized() || rtc.lostPower()) {
Serial.println("RTC is NOT initialized, let's set the time!");
// When time needs to be re-set on a previously configured device, the
// following line sets the RTC to the date & time this sketch was compiled
rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
rtc.start();
//setup for temt6000
pinMode(temt6000Pin, INPUT); //data pin for ambientlight sensor
//setup for TCMux
pinMode(PINEN, OUTPUT);
pinMode(PINA0, OUTPUT);
pinMode(PINA1, OUTPUT);
pinMode(PINA2, OUTPUT);
pinMode(PINSO, INPUT);
pinMode(PINCS, OUTPUT);
pinMode(PINSC, OUTPUT);
digitalWrite(PINEN, HIGH); // enable on
digitalWrite(PINA0, LOW); // low, low, low = channel 1
digitalWrite(PINA1, LOW);
digitalWrite(PINA2, LOW);
digitalWrite(PINSC, LOW); //put clock in low
//setup for DHT22
dht.begin();
void selectChannel(char thermo) {
switch (thermo) //select channel
case 0:
case 1:
digitalWrite(PINA0, HIGH);
case 2:
digitalWrite(PINA1, HIGH);
case 3:
case 4:
digitalWrite(PINA2, HIGH);
case 5:
case 6:
case 7:
delay(5);
digitalWrite(PINCS, LOW); //stop conversion
delay(5);
digitalWrite(PINCS, HIGH); //begin conversion
delay(100); //wait 100 ms for conversion to complete
digitalWrite(PINCS, LOW); //stop conversion, start serial interface
delay(1);
// loop for rtc
DateTime now = rtc.now();
Serial.print(now.year(), DEC);
Serial.print('/');
Serial.print(now.month(), DEC);
Serial.print('/');
Serial.print(now.day(), DEC);
Serial.print(' ');
Serial.print(now.hour(), DEC);
Serial.print(':');
Serial.print(now.minute(), DEC);
Serial.print(':');
Serial.print(now.second(), DEC);
//loop for TCMux
if (millis() > (time + ((unsigned int)UpdateDelay*1000)))
time = millis();
//loop for temt6000
int light_value = analogRead(temt6000Pin);
light = light_value * 0.0976;// percentage calculation
Serial.print("Light value = ");
Serial.println(light_value);
// loop for DHT22 - either that or TCMux - Why
//Read data and store it to variables hum and temp
hum = dht.readHumidity();
temp= dht.readTemperature();
//Print temp and humidity values to serial monitor
Serial.print("Humidity: ");
Serial.print(hum);
Serial.print(" %, Temp: ");
Serial.print(temp);
Serial.println(" Celsius");
if (j<(NumSensors-1)) j++;
else j=0;
selectChannel(j);
//this logic could be coded much more clear:
Temp[j] = 0;
failMode[j] = 0;
SensorFail[j] = 0;
internalTemp = 0;
for (i=31;i>=0;i--)
digitalWrite(PINSC, HIGH);
delay(1);
if ((i<=31) && (i>=18)) //14bit T data, 31 sign, 30 MSB 2^10, 18LSB 2^-2 (0.25 degC)
Mask = 1<<(i-18);
if (digitalRead(PINSO)==1)
if (i == 31)
Temp[j] += (0b11<<14);//pad the temp with the bit 31 value so we can read negative values correctly
Temp[j] += Mask;
if (i==16)
SensorFail[j] = digitalRead(PINSO);
if ((i<=15) && (i>=4)) //12 bit internal Temp, 15 sign, 14 MSB 2^6, 4 LSB 2^-4 (0.0625degC)
Mask = 1<<(i-4);
if (i == 15)
internalTemp += (0b1111<<12);//pad the temp with the bit 31 value so we can read negative values correctly
internalTemp += Mask;//should probably pad the temp with the bit 15 value so we can read negative values correctly
if (i==2)
failMode[j] += digitalRead(PINSO)<<2;//bit 2 is set if shorted to VCC
if (i==1)
failMode[j] += digitalRead(PINSO)<<1;//bit 1 is set if shorted to GND
if (i==0)
failMode[j] += digitalRead(PINSO)<<0;//bit 0 is set if open circuit
delay(1);
//delay(1);
//Serial.println();
//Serial.println(Temp,BIN);
Serial.print("#");
Serial.print(j+1,DEC);
Serial.print(": ");
if (SensorFail[j] == 1)
Serial.print("FAIL");
if ((failMode[j] & 0b0100) == 0b0100)
Serial.print(" SHORT TO VCC");
if ((failMode[j] & 0b0010) == 0b0010)
Serial.print(" SHORT TO GND");
if ((failMode[j] & 0b0001) == 0b0001)
Serial.print(" OPEN CIRCUIT");
} else
floatTemp = (float)Temp[j] * 0.25;
Serial.print(floatTemp,2);
Serial.print(" degC");
Serial.print(" Int: ");
floatInternalTemp = (float)internalTemp * 0.0625;
Serial.print(floatInternalTemp, 4);
Serial.println("");
}//end time
if (Serial.available() > 0) // Is a character waiting in the buffer?
Rxchar = Serial.read(); // Get the waiting character
if (Rxchar == '@') // Can start recording after @ symbol
if (Cmdcomplete != 1)
Rxenable = 1;
Rxptr = 1;
}//end cmdcomplete
}//end rxchar
if (Rxenable == 1) // its enabled so record the characters
if ((Rxchar != 32) && (Rxchar != '@')) //dont save the spaces or @ symbol
Rxbuf[Rxptr] = Rxchar;
//Serial.println(Rxchar);
Rxptr++;
if (Rxptr > 13)
Rxenable = 0;
}//end rxptr
}//end rxchar
if (Rxchar == 13)
Rxenable = 0;
Cmdcomplete = 1;
}//end rxchar
}//end rxenable
}// end serial available
if (Cmdcomplete == 1)
Cmdcomplete = 0;
cmdbuf[0] = toupper(Rxbuf[1]); //copy and convert to upper case
cmdbuf[1] = toupper(Rxbuf[2]); //copy and convert to upper case
cmdbuf[2] = 0; //null terminate Command = Chr(rxbuf(3)) + Chr(rxbuf(4))
// Command = Ucase(command)
//Serial.println(cmdbuf);
valbuf[0] = Rxbuf[3]; // Mystr = Chr(rxbuf(5))
R = Rxptr - 1;
for (i = 4 ; i <= R ; i++)//For I = 6 To R
valbuf[i-3] = Rxbuf[i]; //Mystr = Mystr + Chr(rxbuf(i))
valbuf[R+1] = 0; //null terminate
Param = atoi(valbuf);// Param = Val(mystr)
//Serial.println(Param); // 'Print "Parameter: " ; Param
if (strcmp(cmdbuf,"NS")==0) //NumSensors
//'Print "command was ON"
if ((Param <= 8) && (Param > 0))
NumSensors = Param;
if (strcmp(cmdbuf,"UD")==0) //UpdateDelay
if ((Param <= 60) && (Param >= 0))
UpdateDelay = Param;
if (strcmp(cmdbuf,"SV")==0) //Save
EEPROM.write(0,NumSensors);
EEPROM.write(1,UpdateDelay);
EEPROM.write(511,1);
