:smiley-f
Hi everybody, i have an Arduino Uno and control 2 servo motor.
I follow the servo wiki . My Arduino code is as below:
#include <Servo.h>
Servo servoPan;
Servo servoTilt;
servoPan.attach(9); // pan servo is on pin 9
servoTilt.attach(10); // tilt servo is on pin 10
servoPan.write(90); // home both servos to center
servoTilt.write(90); // home both servos to center
if( Serial.available() >= 2 ) { // two bytes waiting for us
int pan = Serial.read(); // 1st byte is Pan position
int tilt = Serial.read(); // 2nd byte is Tilt position
servoPan.write(pan); // move pan servo
servoTilt.write(tilt); // move tilt servo
Moderator edit: ITALIC TAGS removed and CODE TAGS inserted.
and i use the command line to write byte to /dev/ttyACM0 :
printf '%b' '\x00' > /dev/ttyACM0
printf '%b' '\xa4a4' > /dev/ttyACM0
The problem is whenever i open the serial monitor on Arduino Workspace, this work fine but when i closed the serial monitor, i cannot control servo motor via sending byte to /dev/ttyACM0.
Could anyone show me how can i fix this bug
Thanks so much!
hello
If you are specting 2 bytes this code here get all the 2 bytes!!
I remember you that an Int variable are 2 bytes, then int pan will store the 2 first bytes
See arduino Int Doc
int
Description
Integers are your primary datatype for number storage, and store a 2 byte value. This yields a range of -32,768 to 32,767 (minimum value of -2^15 and a maximum value of (2^15) - 1).
About the Serial question if or skectks is waiting for Serial infor how you would expect it to work if you close the serial!!?
It could be auto-reset - those command lines open and close the file each time they run and thus may be toggling the reset line via the auto-reset circuit. Try a controlling program that keeps the file open between commands...
MarkT:
Thanks MarkT, but i don't know how to keep the dev file open between commnad.
Could yould point out for me at this bug.
I'm very thankful
HugoPT:
hello
See arduino Int Doc
int
Description
Thanks HugoPT, it's just only the demo code, in fact i just use one byte to control Pan and Tilt
anyway , could you help me to fix this bug ?
MarkT:
I'm very thankful
Easy answer is to disable the auto reset, several ways of doing it, a 10 uF (1uF to 100uF will work) electrolytic capacitor between GND and Reset works well. It doesn't matter what your software is doing then. You'll need to remove it to upload a new sketch......
Each call to Serial.read() returns one byte, regardless of the size of the receiving variable
Strictly speaking, each call to Serial.read returns one int, but assuming that there is data in the serial rx buffer, that int will contain a value that will fit into a byte, ie. 0..255
True. I looked it up after I'd submitted the post. It's less wrong than the original point though.
MarkT:
I'm very thankful
Hi bro,
I have fix this bug when i use qextserialport library on Qt GUI and control smoothly the Pan Tilt Pod.
But now there is other problem when i try to extend the coverage of the Pan Tilt Zoom Camera, is use a 5m USB cable and connect the Pan Titl Pod with PC.
The first time i run program succesfully, but a bit later, i can't control the Pod. Check the dev using ls /dev command, there is another ttyACM1 device.
I guess that the arduino auto reset and register new device. So i can't continue to control my old ttyACM0 device from Qt GUI.
Check the voltage on the board, it's still approximately 7V , 0.5V lower than the voltage on USB interface.
So i don't know what is the problem here. Did the board isn't provided enough power and it auto reset ? What is the cause ?
Could anyone help me . Thank so much ?
