Cannot comunicate with GY91 (BME280 sensor)
Hello there, hope someone could help me
I am using NodeMCU ESP32 WROOM-32 board
and I have one of this GY-91 sensors that has Bosch BME280 (not BMP280) sensor modules as well as MPU9250 on it
This is how I have it all connected: Imgur: The magic of the Internet
SCL on module -> GPIO22 (SCL)
SDA on module -> GPIO21 (SDA)
VIN on module -> 3.3V on NodeMCU
GND on module -> GND on NodeMCU
SDO on module -> NC (Not connected)
CS on module -> NC (Not connected)
I used this pinout: https://content.instructables.com/FOL/YWLI/JEOILQ5U/FOLYWLIJEOILQ5U.png
I used I2C scanner program from here: arduinoslovakia/i2c/i2c_tester_raspberry/i2c_tester_raspberry.ino at master · RoboUlbricht/arduinoslovakia · GitHub
and what is imidiatly wierd is that the program only finds 1 device (on address 0x77 which coresponds to BME280), while there should be another device (InvenSense MPU9255) on 0x68
but I said, ok, not a problem, since I need humidity and temperature from BME280 sensor only and nothing else
So I tried to use this library: GitHub - Erriez/ErriezBMX280: BMP280 / BME280 temperature/pressure/humidity sensor library for Arduino
like this
#include <Wire.h>
#include <ErriezBMX280.h>
#define SEA_LEVEL_PRESSURE_HPA      1026.25
ErriezBMX280 bmx280 = ErriezBMX280(0x77);
    while (!Serial) {
    Serial.println(F("\nErriez BMP280/BMX280 example"));
    Wire.begin();
    Wire.setClock(400000);
    // Initialize sensor
    while (!bmx280.begin()) {
        Serial.println(F("Error: Could not detect sensor"));
        delay(3000);
    Serial.print(F("\nSensor type: "));
    switch (bmx280.getChipID()) {
        case CHIP_ID_BMP280:
            Serial.println(F("BMP280\n"));
        case CHIP_ID_BME280:
            Serial.println(F("BME280\n"));
        default:
            Serial.println(F("Unknown\n"));
    bmx280.setSampling(BMX280_MODE_NORMAL,    // SLEEP, FORCED, NORMAL
                       BMX280_SAMPLING_X16,   // Temp:  NONE, X1, X2, X4, X8, X16
                       BMX280_SAMPLING_X16,   // Press: NONE, X1, X2, X4, X8, X16
                       BMX280_SAMPLING_X16,   // Hum:   NONE, X1, X2, X4, X8, X16 (BME280)
                       BMX280_FILTER_X16,     // OFF, X2, X4, X8, X16
                       BMX280_STANDBY_MS_500);// 0_5, 10, 20, 62_5, 125, 250, 500, 1000
    Serial.print(F("Temperature: "));
    Serial.print(bmx280.readTemperature());
    Serial.println(" C");
    if (bmx280.getChipID() == CHIP_ID_BME280) {
        Serial.print(F("Humidity:    "));
        Serial.print(bmx280.readHumidity());
        Serial.println(" %");
    Serial.print(F("Pressure:    "));
    Serial.print(bmx280.readPressure() / 100.0F);
    Serial.println(" hPa");
    Serial.print(F("Altitude:    "));
    Serial.print(bmx280.readAltitude(SEA_LEVEL_PRESSURE_HPA));
    Serial.println(" m");
but this library cannot comunicate with my BME280 sensor, I also tried Adafruit_BME280_Library (its default and bme280test example scetch) even Adafruit_BMP280_Library (thinking that maybe someone put the BMP280 to my board instead of BME280) but nothing (of course I change the default i2c address all libaries come with from 0x76 to 0x77
no matter what I do no library can comunicate with my BME280 sensor and I cannot understand why InvenSense MPU9255 is nowhere to be seen even if the chip is present on the board
also a bit wierd is why my i2c address for BME280 is 0x77 not default 0x76 since I didn't connect any CS pin to 3.3V (which is how you change address to 0x77 if I read somewhere)
Not sure whats going on
I did accidently connect my GY-71 board using wrong pinout at first: (uploaded picture)
but I knew something was not right, when my ESP32 could not program itself properly (sketch failed to upload to ESP32) but not sure how I could possibly damanged something with this if sketch didn't even upload to ESP32 and SDA and SCL pins are the same between theese 2 pinouts
so not sure what to do, hopefully someone can help me, the wierd thing is that I can detect the board with i2c scanner but cannot comunicate with it over that address
Thanks for Anwsering and Best Regards
connecting a GY-91 to a ESP32 NodeMCU (pinout looks identical you photo in post 1) and ran I2C_detect
#include <Wire.h>
#include <i2cdetect.h>
#define I2C_SDA 21
#define I2C_SCL 22
  Wire.begin(I2C_SDA, I2C_SCL);
  //Wire.begin();
  Serial.println("i2cdetect example\n");
  Serial.print("Scanning address range 0x03-0x77\n\n");
  i2cdetect();
  delay(2000);
gives
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:          -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- 68 -- -- -- -- -- -- --
70: -- -- -- -- -- -- 76 --
running the following program
 // ESP32 to GY-91 MPU9250+BMP280 10DOF
 // ESP32 3.3V to GY-91 VIN
 // ESP32 GND  to GY-91 GND
 // ESP32 GPIO22 to GY-91 SCL
 // ESP32 GPIO21 to GY-91 SDA
  original code by MohammedDamirchi
#include <MPU9250_asukiaaa.h>
#include <Adafruit_BMP280.h>
Adafruit_BMP280 bme; // I2C
MPU9250_asukiaaa mySensor;
float aX, aY, aZ, aSqrt, gX, gY, gZ, mDirection, mX, mY, mZ;
  while (!Serial);
#ifdef _ESP32_HAL_I2C_H_ // For ESP32
  Wire.begin();//(SDA_PIN, SCL_PIN);
  mySensor.setWire(&Wire);
#else
  Wire.begin();
#endif
  bme.begin(0x76);
  mySensor.beginAccel();
  mySensor.beginGyro();
  mySensor.beginMag();
  // You can set your own offset for mag values
  // mySensor.magXOffset = -50;
  // mySensor.magYOffset = -55;
  // mySensor.magZOffset = -10;
  if (mySensor.accelUpdate() == 0) {
    aX = mySensor.accelX();
    aY = mySensor.accelY();
    aZ = mySensor.accelZ();
    aSqrt = mySensor.accelSqrt();
    Serial.print("accelX: " + String(aX));
    Serial.print("\taccelY: " + String(aY));
    Serial.print("\taccelZ: " + String(aZ));
    Serial.print("\taccelSqrt: " + String(aSqrt));
  if (mySensor.gyroUpdate() == 0) {
    gX = mySensor.gyroX();
    gY = mySensor.gyroY();
    gZ = mySensor.gyroZ();
    Serial.print("\tgyroX: " + String(gX));
    Serial.print("\tgyroY: " + String(gY));
    Serial.print("\tgyroZ: " + String(gZ));
  if (mySensor.magUpdate() == 0) {
    mX = mySensor.magX();
    mY = mySensor.magY();
    mZ = mySensor.magZ();
    mDirection = mySensor.magHorizDirection();
    Serial.print("\tmagX: " + String(mX));
    Serial.print("\tmaxY: " + String(mY));
    Serial.print("\tmagZ: " + String(mZ));
    Serial.print("\thorizontalDirection: " + String(mDirection));
  Serial.print("\tTemperature(*C): ");
  Serial.print(bme.readTemperature());
  Serial.print("\tPressure(Inches(Hg)): ");
  Serial.print(bme.readPressure()/3377);
  Serial.print("\tApproxAltitude(m): ");
  Serial.print(bme.readAltitude(1013.25)); // this should be adjusted to your local forcase
  Serial.println(""); // Add an empty line
as I move the board around gives
accelX: -0.13	accelY: 0.01	accelZ: -1.00	accelSqrt: 1.01	gyroX: -2.20	gyroY: -11.17	gyroZ: -0.37	Temperature(*C): 23.62	Pressure(Inches(Hg)): 29.80	ApproxAltitude(m): 57.81
accelX: -0.13	accelY: 0.02	accelZ: -0.99	accelSqrt: 1.00	gyroX: -2.14	gyroY: -11.05	gyroZ: -0.31	Temperature(*C): 23.63	Pressure(Inches(Hg)): 29.80	ApproxAltitude(m): 57.67
accelX: -0.11	accelY: 0.07	accelZ: -1.13	accelSqrt: 1.13	gyroX: -10.62	gyroY: -50.78	gyroZ: 5.92	Temperature(*C): 23.64	Pressure(Inches(Hg)): 29.80	ApproxAltitude(m): 57.82
accelX: -0.43	accelY: 0.78	accelZ: -0.60	accelSqrt: 1.07	gyroX: 73.00	gyroY: 32.59	gyroZ: -10.31	Temperature(*C): 23.64	Pressure(Inches(Hg)): 29.80	ApproxAltitude(m): 57.97
accelX: -0.92	accelY: 0.36	accelZ: -0.25	accelSqrt: 1.02	gyroX: -60.36	gyroY: 30.21	gyroZ: 75.87	Temperature(*C): 23.66	Pressure(Inches(Hg)): 29.80	ApproxAltitude(m): 57.85
accelX: -0.61	accelY: 0.38	accelZ: 0.82	accelSqrt: 1.09	gyroX: -17.27	gyroY: 81.79	gyroZ: -51.88	Temperature(*C): 23.67	Pressure(Inches(Hg)): 29.80	ApproxAltitude(m): 57.98
accelX: 0.06	accelY: 1.04	accelZ: 0.19	accelSqrt: 1.06	gyroX: -27.04	gyroY: -113.77	gyroZ: -78.25	Temperature(*C): 23.68	Pressure(Inches(Hg)): 29.80	ApproxAltitude(m): 58.04
accelX: -0.16	accelY: 0.86	accelZ: 0.92	accelSqrt: 1.27	gyroX: 52.86	gyroY: -34.06	gyroZ: 12.39	Temperature(*C): 23.70	Pressure(Inches(Hg)): 29.80	ApproxAltitude(m): 58.12
accelX: -0.46	accelY: 0.78	accelZ: 0.19	accelSqrt: 0.92	gyroX: -113.46	gyroY: -74.10	gyroZ: -20.75	Temperature(*C): 23.70	Pressure(Inches(Hg)): 29.80	ApproxAltitude(m): 58.12
accelX: 0.05	accelY: -0.41	accelZ: -0.96	accelSqrt: 1.05	gyroX: -86.73	gyroY: -8.79	gyroZ: 3.48	Temperature(*C): 23.70	Pressure(Inches(Hg)): 29.80	ApproxAltitude(m): 58.04
accelX: 0.28	accelY: -0.55	accelZ: -0.77	accelSqrt: 0.99	gyroX: 68.97	gyroY: -17.52	gyroZ: 18.55	Temperature(*C): 23.70	Pressure(Inches(Hg)): 29.80	ApproxAltitude(m): 58.07
accelX: 0.50	accelY: 0.34	accelZ: -0.65	accelSqrt: 0.89	gyroX: -18.01	gyroY: 42.36	gyroZ: 42.66	Temperature(*C): 23.70	Pressure(Inches(Hg)): 29.80	ApproxAltitude(m): 57.80
accelX: 0.04	accelY: 0.09	accelZ: -0.39	accelSqrt: 0.40	gyroX: -1.53	gyroY: -58.90	gyroZ: 35.03	Temperature(*C): 23.71	Pressure(Inches(Hg)): 29.80	ApproxAltitude(m): 57.96
accelX: -0.15	accelY: 0.06	accelZ: -0.99	accelSqrt: 1.00	gyroX: -2.14	gyroY: -10.86	gyroZ: -0.31	Temperature(*C): 23.70	Pressure(Inches(Hg)): 29.80	ApproxAltitude(m): 57.59
accelX: -0.15	accelY: 0.05	accelZ: -1.00	accelSqrt: 1.01	gyroX: -1.83	gyroY: -11.23	gyroZ: -0.37	Temperature(*C): 23.72	Pressure(Inches(Hg)): 29.80	ApproxAltitude(m): 57.54
accelX: -0.16	accelY: 0.06	accelZ: -0.99	accelSqrt: 1.00	gyroX: -2.26	gyroY: -11.05	gyroZ: -0.18	Temperature(*C): 23.72	Pressure(Inches(Hg)): 29.80	ApproxAltitude(m): 57.80
accelX: 0.05	accelY: 0.08	accelZ: -0.91	accelSqrt: 0.92	gyroX: -3.54	gyroY: -53.77	gyroZ: -3.36	Temperature(*C): 23.73	Pressure(Inches(Hg)): 29.80	ApproxAltitude(m): 57.96
accelX: -0.21	accelY: 0.77	accelZ: -0.52	accelSqrt: 0.95	gyroX: 80.38	gyroY: 107.54	gyroZ: -15.14	Temperature(*C): 23.73	Pressure(Inches(Hg)): 29.80	ApproxAltitude(m): 57.73
accelX: 0.55	accelY: 1.00	accelZ: -0.05	accelSqrt: 1.14	gyroX: 17.33	gyroY: 59.39	gyroZ: -96.68	Temperature(*C): 23.72	Pressure(Inches(Hg)): 29.80	ApproxAltitude(m): 57.99
accelX: 0.99	accelY: 0.24	accelZ: -0.05	accelSqrt: 1.02	gyroX: 31.25	gyroY: -37.90	gyroZ: 13.55	Temperature(*C): 23.73	Pressure(Inches(Hg)): 29.80	ApproxAltitude(m): 57.79
accelX: 0.75	accelY: 0.18	accelZ: 1.11	accelSqrt: 1.35	gyroX: 70.43	gyroY: -107.12	gyroZ: 11.29	Temperature(*C): 23.73	Pressure(Inches(Hg)): 29.80	ApproxAltitude(m): 58.05
accelX: -0.23	accelY: -0.64	accelZ: 0.81	accelSqrt: 1.06	gyroX: -33.45	gyroY: -89.54	gyroZ: 1.10	Temperature(*C): 23.74	Pressure(Inches(Hg)): 29.80	ApproxAltitude(m): 58.25
accelX: -1.00	accelY: -0.07	accelZ: 0.44	accelSqrt: 1.09	gyroX: 3.23	gyroY: -72.51	gyroZ: 4.94	Temperature(*C): 23.74	Pressure(Inches(Hg)): 29.80	ApproxAltitude(m): 58.22
accelX: -0.02	accelY: 0.11	accelZ: -0.59	accelSqrt: 0.60	gyroX: 6.47	gyroY: 9.64	gyroZ: -0.49	Temperature(*C): 23.72	Pressure(Inches(Hg)): 29.80	ApproxAltitude(m): 57.89
accelX: -0.33	accelY: -0.05	accelZ: -0.21	accelSqrt: 0.40	gyroX: 1.34	gyroY: -24.23	gyroZ: -0.92	Temperature(*C): 23.72	Pressure(Inches(Hg)): 29.80	ApproxAltitude(m): 57.96
I am an idiot
this is the board I have: https://www.amazon.de/-/en/CJMCU-680-Pressure-Temperature-Connection-Extremely/dp/B095HBGBWM
No wonder nothing I tried worked :smile:
After installing Adafruit bme680 library everything started to work
why do all this boards have to look so similar
