I am trying to connect my R4 WiFi to Adafruits Quad Encoder Board 5752. I can get it to work using the I2C pins on the 5752 and the R4. I cannot get it work using the STEMMA connectors on both boards.
I know to use Wire1 instead of Wire.
Using this code
#include <Wire.h>
while (!Serial); // Optional wait for Serial on some boards
Wire1.begin(); // Initialize I2C0 (STEMMA port)
Wire1.setClock(400000); // Set I2C to 400 kHz Fast Mode
Serial.println("I2C Scanner @ 400 kHz on Wire1 (I2C0 - STEMMA Port)");
Serial.println("Scanning I2C devices on STEMMA port...");
int foundCount = 0;
for (byte address = 1; address < 127; address++) {
Wire1.beginTransmission(address);
if (Wire1.endTransmission() == 0) { // 0 = success
Serial.print("Device found at address 0x");
if (address < 16) Serial.print("0");
Serial.println(address, HEX);
foundCount++;
if (foundCount == 0) {
Serial.println("No I2C devices found on STEMMA port.");
Serial.println("I2C scan completed.");
delay(3000); // Wait 3 seconds between scans
finds the 5752
15:00:50.405 -> Scanning I2C devices on STEMMA port...
15:00:50.405 -> Device found at address 0x49
15:00:50.405 -> I2C scan completed.
Using this code to connect to Seesaw on the 5752:
* This is a demo for a QT Py RP2040 connected to a quad rotary encoder breakout
* using the onboard Stemma QT Port
* https://www.adafruit.com/product/4900
* https://www.adafruit.com/product/5752
#include "Adafruit_seesaw.h"
#include <seesaw_neopixel.h>
#include <Wire.h>
#include "Arduino_LED_Matrix.h"
ArduinoLEDMatrix matrix;
uint8_t frame[8][12] = {
{ 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 },
#define SS_NEO_PIN 18
#define SEESAW_ADDR 0x49
#define ENCODER_COUNT 4
Adafruit_seesaw ss = Adafruit_seesaw(&Wire1);
seesaw_NeoPixel pixels = seesaw_NeoPixel(4, SS_NEO_PIN, NEO_GRB + NEO_KHZ800);
uint8_t ss_enc_switch[ENCODER_COUNT] = {12, 14, 17, 9};
int32_t enc_positions[ENCODER_COUNT] = {0, 0, 0, 0};
bool enc_pressed[ENCODER_COUNT] = {false, false, false, false};
volatile bool interruptOccurred = false;
void handleInterrupt() {
interruptOccurred = true;
while (!Serial) delay(10);
pinMode(2, INPUT_PULLUP);
attachInterrupt(digitalPinToInterrupt(2), handleInterrupt, FALLING);
Wire1.begin();
Serial.println("I2C Scanner @ 400 kHz on Wire1");
Serial.println("Looking for seesaw!");
if (! ss.begin(SEESAW_ADDR) || !pixels.begin(SEESAW_ADDR)) {
Serial.println("Couldn't find seesaw on default address");
while(1) delay(10);
Serial.println("seesaw started");
Yields:
15:08:53.848 -> I2C Scanner @ 400 kHz on Wire1
15:08:53.848 -> Looking for seesaw!
15:09:03.975 -> Couldn't find seesaw on default address
Any help would be appreciated.
