Cannot connect to Apache through arduino Ethernet Shield
i am having a problem with my arduino when trying to connect to a apache web server.
I tried to use both public ip and local ip to connect but none works, i still get connection failed message…
Here is the arduino sketch:
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = {
  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte ip[] = {
  192, 168, 1, 6 }; //assigned arduino LAN IP address
byte server[] = {
  46,198,212,78	 };
EthernetClient client; //apache web server running on port 80
  Ethernet.begin(mac, ip);
  Serial.println("starting simple arduino client test");
  Serial.println("connecting...");
  if (client.connect(server, 80 > 0)) {
    Serial.println("connected");
    client.println("GET /write.php?value0=99 HTTP/1.0"); //php page invoking my web service
    client.println();
  else {
    Serial.println("connection failed");
  if (client.available()) {
    char c = client.read();
    Serial.print(c);
  if (!client.connected()) {
    Serial.println("disconnecting.");
    Serial.println("==================================");
    Serial.println("");
    client.stop();
    for(;;);
And here is the php script:
<?php
echo "connection receiving";
$value0=$_GET['value0'];
$opendb=mysql_connect("localhost","root","") or die(mysql_error());
$db = mysql_select_db('arduino',$opendb);
if ($opendb){
  echo " database open.";
  if (!$db) {
	echo mysql_error();
  $query = "INSERT INTO analoog0 VALUES(curdate(), curtime(), '$value0');";
  /* Run the query */
  $result= mysql_query($query)or die(mysql_error());
  mysql_close($opendb);
  echo "values written = $value0";
Thanks in advance…!!
Is this server your Apache server? Or is it a hosting company's server?
SurferTim: Is this server your Apache server? Or is it a hosting company's server?
The server is mine.. It is hosted on my machine
Client and server is the same machine.
What do you mean same? Not both on the Arduino, right?
edit: If the Apache server has a 192.168.1.x ip, use that ip as the server in the Arduino.
SurferTim:
Bad syntax, the web server is running on the computer and the client is the arduino. The apache server doesnt have such an ip adress. Only 127.0.0.1 or "localhost"..
Then you will not be able to connect from any other device, not just the Arduino. It will work fine from a web browser on the server, but nowhere else. You must assign it an ip in the localnet range (192.168.1.x), and allow the server to be accessed from the internet. I suggest trying the web server from a separate computer on the localnet. Get it working with the computer first.
Insure the server firewall allows port 80 requests through from the internet.
SurferTim:
I tried with 192.168.1.7 ip adress. I am able to access the server from another local network computer but arduino still gets the error.....
Your parenthesis are not correct:
// this is incorrect
// it should be this:
 if (client.connect(server, 80) > 0) {
SurferTim:
Ye that was the mistake…baaah…
Now i came up with a new problem. I have a sketch that reads Temperature every one minuite and stores it into a database, but the sketch stops running after some minuites…
Here is the sketch… It always stucks at “Connected” line
#include <SPI.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
//EthernetServer server(80);  // create a server at port 80
IPAddress myDns(46, 198, 212, 78);
byte gw[] = { 192, 168, 1, 1 };
byte subnet[] = { 255, 255, 255, 0 };
byte mac[] = {
byte ip[] = {
byte server[] = {
  192, 168, 1, 7 };
int value0 = 13;                //measurement value analog 0
int value1 = 0;                //measurement value analog 1
int ledPin3 = 12;               //led indicating value analog 0 (pwd-pin)
int ledPin5 = 5;               //led indicating value analog 1 (pwd-pin)
unsigned long time;
long previoustime = 0;         // will store last time loop run
long interval = 60000;        // time between measurements in msec.
void setup(){
  // open the serial port
  //setup ledpins
  pinMode(ledPin3, OUTPUT);
  pinMode(ledPin5, OUTPUT);
  //server.begin();
void loop(){
  delay(100);
  time = millis();
  Serial.println(time);
  int ledpin3value = 0;
  int ledpin5value =0;
  value0 = analogRead(13);
  value0 = (5.0 * value0 * 100.0)/1024.0;
 // value1 = analogRead(1);
  ledpin3value = map(value0,0,1023,0,255);         //map read values to pwd values
 // ledpin5value = map(value1,0,1023,0,255);
  analogWrite(ledPin3,ledpin3value);
  analogWrite(ledPin5,ledpin5value);
  //Serial.print(value0);            //debug
  //Serial.println(value1);          //debug
  if (time - previoustime > interval) {    //true, send data to server
    previoustime = time;
    Serial.println(previoustime);
    Serial.println(time);            //debug
    senddata();                      //call function to send data to server
  delay(2000);
void senddata(){
  // start the Ethernet connection and the server:
  Serial.println("setting up ip connection");
  // Initialize the Ethernet server library with the IP address and port you want to use
  // (port 80 is default for HTTP):
  //EthernetClient client = server.available();
  if (client.connect(server, 80)){
    //Serial.println();
   // Serial.println(value0);
    //Serial.println();
    client.print("GET /write.php?value0=");  //GET to php file which handle data (value0 and value1) into a database
    client.print(value0);
    client.println(" HTTP/1.1");
    client.println("Host: 46.198.212.78");  //webserver site with php file (www.asrdff.com/write.php)
    client.println();
    // if there are incoming bytes available
    // from the server, read them and print them:
    delay(100);      //wait some time for server to answer
    while (client.available()) {
      //Serial.println("inside while:");
      Serial.print(c);
  Serial.println("End SendData");
  else{
  client.stop();
Here is the "perfect world" version of this code. There should be a timeout in this, but it should be good enough to get you a couple hours of running without a fail. I deleted the delay(100) call. You don't need that with this.
    while(client.connected()) {
          Serial.print(c);
    client.stop();
The server will close the connection when it is finished sending packets, then you close your end. Otherwise, you could be leaving sockets open, and you only have 4.
SurferTim: Here is the "perfect world" version of this code. There should be a timeout in this, but it should be good enough to get you a couple hours of running without a fail. I deleted the delay(100) call. You don't need that with this.
          Serial.print(c);
    client.stop();
Unfortunately it still doesnt works, it stucks.... :(
What is the last thing displayed on the serial monitor? Does it read part of the page or freeze at “connected”?
edit: Here is the client code I use. It has a timeout feature that keeps it from locking up in the “while(client.connected())” loop.
http://playground.arduino.cc/Code/WebClient
SurferTim: What is the last thing displayed on the serial monitor? Does it read part of the page or freeze at "connected"?
edit: Here is the client code I use. It has a timeout feature that keeps it from locking up in the "while(client.connected())" loop. http://playground.arduino.cc/Code/WebClient
It always freezes on "connected".
I will try to modify my code from your link and see if it works.
Sounds like the server stalls. Your code must compensate for that. Take a look at the example code in the link I posted above. The connectLoop variable controls the timeout feature.
I can create that type of fail (freeze/lockup) by downloading a large page like Google's home page, then pulling the CAT5 out of the Arduino as soon as the page starts downloading. Without the timeout, it will lock up. With the timeout, it stalls for only 10 seconds, then goes right back to it.
SurferTim: Sounds like the server stalls. Your code must compensate for that. Take a look at the example code in the link I posted above. The connectLoop variable controls the timeout feature.
I modified the code from your link above for my needs and it runs for over one hour without problem. :)
That is good news! :) Any time you see "Timeout" on the serial monitor, your old code would have locked up at that point.
SurferTim: That is good news! :) Any time you see "Timeout" on the serial monitor, your old code would have locked up at that point.
If i see "timeout" will the sketch recover on its own or do i have to reset ?
manos437: If i see "timeout" will the sketch recover on its own or do i have to reset ?
When you see "Timeout", the Arduino has already recovered. It will keep right on going. No need for a reset.
