Cannot controle webrelais?
Hello,
I am trying to make a webserver to controle some relais.
I also combined some code to implementate a basic auth login.
I can login,but the relais do not switch.
Here is my code:
#include <UIPEthernet.h>
byte mac[] = {xx,xx,xx,xx,xx,xx };
IPAddress ip(192, 168, 1, 10);
EthernetServer server(80);
byte sampledata=50;            //some sample data - outputs 2 (ascii = 50 DEC)
int ledPin1 = 3;  // LED pin 1
int ledPin2 = 4;  // LED pin 2
int ledPin3 = 6;  // LED pin 3
int ledPin4 = 7;  // LED pin 4
String readString = String(30); //string for fetching data from address
boolean LEDON1 = false; //LED status flag
boolean LEDON2 = false;
boolean LEDON3 = false;
boolean LEDON4 = false;
  Ethernet.begin(mac, ip);
  server.begin();
  pinMode(ledPin1, OUTPUT);
  pinMode(ledPin2, OUTPUT);
  pinMode(ledPin3, OUTPUT);
  pinMode(ledPin4, OUTPUT);
void SendOKpage(EthernetClient &client)
     char c = client.read();
      if (readString.length() < 30)     //read char by char HTTP request
        readString.concat(c);    //store characters to string
        //-----readString.append(c);
       if (c == '\n') {   //if HTTP request has ended
          //------------LED 1------------------------------------------------------------------------
           if (readString.substring(6,11) == "L1=ON")
             digitalWrite(ledPin1, HIGH);    // set the LED on
             LEDON1 = true;
             else if (readString.substring(6,12) == "L1=OFF")
             digitalWrite(ledPin1, LOW);    // set the LED OFF
             LEDON1 = false;
//------------LED 2---------------------------------------------------------------------------
           if (readString.substring(6,11) == "L2=ON")
             digitalWrite(ledPin2, HIGH);    // set the LED on
             LEDON2 = true;
             else if (readString.substring(6,12) == "L2=OFF")
             digitalWrite(ledPin2, LOW);    // set the LED OFF
             LEDON2 = false;
//------------LED 3---------------------------------------------------------------------------
           if (readString.substring(6,11) == "L3=ON")
             digitalWrite(ledPin3, HIGH);    // set the LED on
             LEDON3 = true;
             else if (readString.substring(6,12) == "L3=OFF")
             digitalWrite(ledPin3, LOW);    // set the LED OFF
             LEDON3 = false;
//------------LED 4------------------------------------------------------------------------------------
           if (readString.substring(6,11) == "L4=ON")
             digitalWrite(ledPin4, HIGH);    // set the LED on
             LEDON4 = true;
             else if (readString.substring(6,12) == "L4=OFF")
             digitalWrite(ledPin4, LOW);    // set the LED OFF
             LEDON4 = false;
          // now output HTML data starting with standart header
          client.print("<body style=background-color:blue>");    //set background to blue
          client.println F("<h1><center>Welcome To Arduino Online Home Automation</center></h1>");
          client.println F("<font color='black'>");
          client.println F("
//--------LED 1 CONTROLL-------------------------------------------------------------------------------------------
          client.println F("<center><h2>Conrol Panel & Status Of the House</h2></center>");
          client.println F("<center><h2>LED 1</h2></center>");
          client.println F("<center><form method=get name=LED><input type=submit name=L1 value=ON method=get name=LED><input type=submit name=L1 value=OFF ></form></center>");
            if (LEDON1)
             client.print ("<center><font color='green' size='3'> ON</center>");
             client.print ("<center><font color='red' size = '3'> OFF</center>");
//--------LED 2 CONTROLL--------------------------------------------------------------------------------------------------------------------
          client.println F("<center><h2>LED 2</h2></center>");
          client.println F("<center><form method=get name=LED2><input type=submit name=L2 value=ON method=get name=LED2><input type=submit name=L2 value=OFF ></form></center>");
            if (LEDON2)
            client.print ("<center><font color='green' size='3'> ON </center>");
             client.print ("<center><font color='red' size = '3'> OFF </center>");
//--------LED 3 CONTROLL------------------------------------------------------------------------------------------------------------------
          client.println F("<center><h2>LED 13</h2></center>");
          client.println F("<center><form method=get name=LED3><input type=submit name=L3 value=ON method=get name=LED3><input type=submit name=L3 value=OFF ></form></center>");
            if (LEDON3)
//--------LED 4 CONTROLL-------------------------------------------------------------------------------------------------------
          client.println F("<center><h2>LED 4</h2></center>");
          client.println F("<center><form method=get name=LED4><input type=submit name=L4 value=ON method=get name=LED4><input type=submit name=L4 value=OFF ></form></center>");
            if (LEDON4)
           client.println F("</body></html>");
          readString="";     //clearing string for next read
          client.stop();    //stopping client
void SendAuthentificationpage(EthernetClient &client)
          client.println("HTTP/1.1 401 Authorization Required");
          client.println("WWW-Authenticate: Basic realm=\"Secure Area\"");
          client.println("Content-Type: text/html");
          client.println("Connnection: close");
          client.println();
          client.println("<!DOCTYPE HTML>");
          client.println("<HTML>  <HEAD>   <TITLE>Error</TITLE>");
          client.println(" </HEAD> <BODY><H1>401 Unauthorized.</H1></BODY> </HTML>");
char linebuf[80];
int charcount=0;
boolean authentificated=false;
  // listen for incoming clients
  if (client) {
    memset(linebuf,0,sizeof(linebuf));
    charcount=0;
    // an http request ends with a blank line
    boolean currentLineIsBlank = true;
    while (client.connected()) {
      if (client.available()) {
        linebuf[charcount]=c;
        if (charcount<sizeof(linebuf)-1) charcount++;
        // if you've gotten to the end of the line (received a newline
        // character) and the line is blank, the http request has ended,
        // so you can send a reply
        if (c == '\n' && currentLineIsBlank) {
          if (authentificated)
            SendOKpage(client);
            SendAuthentificationpage(client);
        if (c == '\n') {
          // you're starting a new line
          if (strstr(linebuf,"Authorization: Basic")>0 && strstr(linebuf,"cGhwOm5laW4=")>0)
            authentificated=true;
          charcount=0;
        else if (c != '\r') { //
          // you've gotten a character on the current line
          currentLineIsBlank = false;
    // give the web browser time to receive the data
    delay(1);
    // close the connection:
    client.stop();
You're writing to LEDs, not relays.
Why not debug a single device, and then expand the code?
An any given call, you read one character and store it. Then, you expect that there are at least 11 characters in the String.
That might be a reasonable assumption, if this function was the only one reading client data and the function was called often enough.
  if (client) {
    charcount=0;
Oh well, so much for that first assumption...
            SendOKpage(client);
and, so much for the second assumption.
