cannot convert 'const String' to 'byte {aka unsigned char}' in assignment
Hi everyone, total newbie here working on a sketch for a esp8266. After many hours of trying to figure this out I figured I’d ask for help. So I’m passing some parameters through a server to esp8266 via html input then save to eeprom hopefully.
Now I’m stuck at turning that parameter Stirng “erver.arg(i);” into a byte? My sever input parameters are always a number between 0-100 so they should be a single byte anyways right? example
192.168.4.1/save3?rpm3=78
How can I convert my 0-100 html input perimeter whatever is in “erver.arg(i);” to a byte so that I can save “erver.arg(i);” to eeprom? This doesn’t work:
qrpm3 = server.arg(i); I get error: cannot convert ‘const String’ to ‘byte {aka unsigned char}’ in assignment
This does:
String qrpm3 = server.arg(i);
But its a string, I just need a single byte so I can save it straight to eeprom with:
        EEPROM.write(3,server.arg(i));
        EEPROM.commit();
Part of the code:
  if (server.args() > 0 ) {
    for ( byte i = 0; i < server.args(); i++ ) {
      if (server.argName(i) == "rpm3") {
        // do something here with value from server.arg(i);
        Serial.println(server.arg(i));
        Serial.println(qrpm3);
        //EEPROM.write(3,server.arg(i));
        //EEPROM.commit();
Hi, try the toInt() string object function
byte myByte;
myByte = qrpm3.toInt();
converts the string into integer and then simply store into a byte data type variable.
Here is the syntax
https://www.arduino.cc/reference/en/language/variables/data-types/string/functions/toint/
I’m struggling to see how this is a “general electronics” question - you could ask a moderator to move the topic to the programming section.
I actually wrote my own converter since toInt() returns 0 for an incorrect input and then i cannot test for that (if 0 is a valid input as a value)
myele:
I get error: cannot convert 'const String' to 'byte {aka unsigned char}' in assignment
I think you want:
qrpm3 = server.arg(i).toInt();
Nikosant03:
byte myByte;
This worked awesome thanks so much :slight_smile:
