cannot convert 'float' to 'const char*' in initialization
Okay, so first of all, i am a noob at this. I have only been playing around with arduino for a few weeks, so i am really bad at coding.
Enough excuses.
I just bought some 433MHz transmitter and receiver modules.
I can send a message that i write myself, like now i'm sending "Stupid arduino" cause i'm mad, well whatever.
But if i write celsius(float from my TMP102 sensor) instead of "Some message" it gives me the error "cannot convert 'float' to 'const char*' in initialization"
I have tried googling, but i haven't found a workaround.
I really hope someone can help me :frowning:
Transmitter code:
// transmitter.pde
// Simple example of how to use VirtualWire to transmit messages
// Implements a simplex (one-way) transmitter with an TX-C1 module
// See VirtualWire.h for detailed API docs
// Author: Mike McCauley (mikem@airspayce.com)
// Copyright (C) 2008 Mike McCauley
// $Id: transmitter.pde,v 1.3 2009/03/30 00:07:24 mikem Exp $
#include <VirtualWire.h>
#include <Wire.h>
int tmp102Address = 0x48;
    Serial.begin(9600);	  // Debugging only
    Serial.println("setup"); // Prints "Setup to the serial monitor"
      Wire.begin();
    vw_set_tx_pin(12);          // Sets pin D12 as the TX pin
    vw_set_ptt_inverted(true);  // Required for DR3100
    vw_setup(4000);	        // Bits per sec
  float celsius = getTemperature();
    const char *msg= "Stupid arduino";   // Message to be sent
    digitalWrite(13, true);      // Flash a light to show transmitting
    vw_send((uint8_t *)msg, strlen(msg)); //Sending the message
    //vm_send((uint8_t *)celsius, 5)
    vw_wait_tx(); // Wait until the whole message is gone
    digitalWrite(13, false);   // Turn the LED off.
    delay(1000);                 // A short gap.
float getTemperature(){
  Wire.requestFrom(tmp102Address,2);
  byte MSB = Wire.read();
  byte LSB = Wire.read();
  int TemperatureSum = ((MSB << 8) | LSB) >> 4;
  float celsius = TemperatureSum*0.0625;
  return celsius;
Receiver code:
** Example Arduino sketch for SainSmart I2C LCD Screen 16x2
** based on https://bitbucket.org/celem/sainsmart-i2c-lcd/src/3adf8e0d2443/sainlcdtest.ino
** by
** Edward Comer
** LICENSE: GNU General Public License, version 3 (GPL-3.0)
** This example uses F Malpartida's NewLiquidCrystal library. Obtain from:
** https://bitbucket.org/fmalpartida/new-liquidcrystal
** Modified - Ian Brennan ianbren at hotmail.com 23-10-2012 to support Tutorial posted to Arduino.cc
** Written for and tested with Arduino 1.0
** NOTE: Tested on Arduino Uno whose I2C pins are A4==SDA, A5==SCL
#include <Wire.h>
#include <LCD.h>
#define I2C_ADDR    0x27 // <<----- Add your address here.  Find it from I2C Scanner
#define BACKLIGHT_PIN     3
#define En_pin  2
#define Rw_pin  1
#define Rs_pin  0
#define D4_pin  4
#define D5_pin  5
#define D6_pin  6
#define D7_pin  7
int n = 1;
int count;
LiquidCrystal_I2C	lcd(I2C_ADDR,En_pin,Rw_pin,Rs_pin,D4_pin,D5_pin,D6_pin,D7_pin);
    Serial.println("setup"); //Prints "Setup" to the serial monitor
    vw_set_rx_pin(12);       //Sets pin D12 as the RX Pin
    vw_rx_start();       // Start the receiver PLL running
 lcd.begin (16,2); //  <<----- My LCD was 16x2
// Switch on the backlight
lcd.setBacklightPin(BACKLIGHT_PIN,POSITIVE);
lcd.setBacklight(HIGH);
lcd.home (); // go home
    uint8_t buf[VW_MAX_MESSAGE_LEN];
    uint8_t buflen = VW_MAX_MESSAGE_LEN;
    if (vw_get_message(buf, &buflen)) // Non-blocking
	lcd.clear();
      int i;
        digitalWrite(13, true);  // Flash a light to show received good message
	// Message with a good checksum received, dump it.
	lcd.print("Got: ");
lcd.setCursor (0 ,1 );
	for (i = 0; i < buflen; i++)
            char c = (buf[i]);
            lcd.print(c);
        count++;
       // Serial.print(count);
	lcd.println("");
You need to convert the float to a string. cf dtostrf().
KeithRB:
A bit more detailed explanation would be great, as i mentioned, i don't really have any coding experience, so i'm not sure how to use that command :frowning:
Mr. Google is.
char str[32];
dtostrf(float_val, 8, 2, str);
vw_send(str, strlen(str));
KeithRB:
char str[32];
It worked! Thank you so much!
