Cannot convert 'String' to 'const char*'
Hi!
I have an issue with my code for my RFID project. I'm trying to get input from the serial console that is longer than one character. Help?
Code:
  if (option == 'w') {
    while (Serial.available() == 0) {
      String stringVariable( Serial.readString() );
      strcpy(stringBuffer, stringVariable);  // you may try a different string here, with LESS than MAX_STRING_SIZE characters
      int stringSize = strlen(stringBuffer);
      // starting from tag's block #1, writes a data chunk labeled "mylabel", with its content given by stringBuffer, of stringSize+1 bytes (because of the trailing 0 in strings)
      result = rfidReader.writeFile(BLOCK, "mylabel", (byte*)stringBuffer, stringSize+1);
      if (result >= 0) {
        printfSerial("--> Successfully written \"%s\" to the tag, ending in block %d\n", stringBuffer, result);
        printfSerial("--> Error writing to the tag: %d\n", result);
-eetnaviation
Hmm, while nothing is available to read, try to read a complete string. What am I missing?
And why read a String and not bytes with Serial.readBytes; saves you the strcpy.
