Hello,
I just cannot decode my sensors data...
Here are relevant parts of my code:
typedef struct __attribute__ ((packed)) sigfox_message {
int8_t moduleTemperature;
int16_t mpcTemperature;
uint16_t bmePressure;
uint16_t bmeHumidity;
} SigfoxMessage;
float pressure = bme.readPressure();
msg.bmePressure = convertoFloatToUInt16(pressure, 200000);
float humidity = bme.readHumidity();
msg.bmeHumidity = convertoFloatToUInt16(humidity, 110);
tempsensor.wake();
float outside_temperature = tempsensor.readTempC();
msg.mpcTemperature = convertoFloatToInt16(outside_temperature, 60, -60);
SigFox.begin();
float module_temperature = SigFox.internalTemperature();
msg.moduleTemperature = convertoFloatToInt16(module_temperature, 60, -60);
SigFox.status();
delay(1);
SigFox.beginPacket();
SigFox.write((uint8_t*)&msg, 12);
Here is code that handle conversion:
#define UINT16_t_MAX 65536
#define INT16_t_MAX UINT16_t_MAX/2
int16_t convertoFloatToInt16(float value, long max, long min) {
float conversionFactor = (float) (INT16_t_MAX) / (float)(max - min);
return (int16_t)(value * conversionFactor);
uint16_t convertoFloatToUInt16(float value, long max, long min = 0) {
float conversionFactor = (float) (UINT16_t_MAX) / (float)(max - min);
return (uint16_t)(value * conversionFactor);
Here is custom grammar:
Temperature_Int::int:8 Temperature_Ext::int:16 Pressure::uint:16 Humidity::uint:16
Raw and Decoded message is:
44221a6f805d7600dc030020
Temperature_Int: 68
Temperature_Ext: 8730
Pressure: 28544
Humidity: 23926
When I print float versions of sensors data to serial monitor, values are correct. What did I wrong?
Thank you.
