I've recently started working on a project trying to upload sensor data from my Arduino Uno serially connected to an ESP8266, to a mySQL server. I can't seem to figure out what's incorrect about my post request through AT Commands. Getting the sensor data works great. Also, my php script is probably very buggy as of now, but I am just trying to ensure the $data variable is correctly being assigned as of now (first time working with php and AT commands). Thanks for any help!
I've mainly tried debugging by adjusting the httpRequest string, which I haven't had much luck with. The sensor data is correctly created into a JSON object as I've seen by serially printing the string representation. I'm assuming the error lies in either the AT commands or creating of the http request. $data in the php script receiving the JSON object would be considered a win. Another potential issue is the baud rate, I understand ESP8266 should run at 9600 when serially connected. However, it doesn't seem to connect to the wifi when that is the case. Should I change both baud rates to 9600 (if so how do I still connect to wifi)? Thank you!
#include <Arduino.h>
#include <SoftwareSerial.h>
#include <ArduinoJson.h>
SoftwareSerial ESP8266(2, 3); // RX, TX
const int delayTime = 2000;
void setUpESP();
void connect();
String createJSON();
void postRequest();
int sensor1Test();
const int sensor1 = A0;
ESP8266.begin(115200);
setUpESP();
connect();
pinMode(sensor1, INPUT);
postRequest();
delay(10000);
String createJSON() {
StaticJsonDocument<256> doc;
doc["sensor1Val"] = sensor1Test();
String jsonPayload;
serializeJson(doc, jsonPayload);
return jsonPayload;
void postRequest() {
ESP8266.println("AT+CIPSTART=\"TCP\",\"192.168.4.33\",80");
delay(delayTime);
String jsonPayload = createJSON();
ESP8266.print("AT+CIPSEND=");
ESP8266.println(jsonPayload.length() + 150);
delay(delayTime);
String httpRequest = "POST /sensordata/extractData.php HTTP/1.1\r\n";
// ** = local ipaddress
httpRequest += "Host: ******\r\n";
httpRequest += "Connection: keep-alive\r\n";
httpRequest += "Content-Type: application/json\r\n";
httpRequest += "Content-Length: ";
httpRequest += jsonPayload.length();
httpRequest += "\r\n\r\n";
httpRequest += jsonPayload;
Serial.println(jsonPayload);
ESP8266.println(httpRequest);
delay(delayTime);
ESP8266.println("AT+CIPCLOSE");
int sensor1Test() {
int sensor1Val = analogRead(sensor1);
delay(delayTime);
return sensor1Val;
void setUpESP() {
delay(delayTime);
ESP8266.println("AT+RST");
delay(delayTime);
ESP8266.println("AT+CWMODE=1");
delay(delayTime);
void connect() {
Serial.println("Connecting to Wifi");
unsigned char timer = 0;
unsigned char connection = 0;
while (connection == 0) {
Serial.print(". ");
// ** = ssid and password
ESP8266.println("AT+CWJAP=\"**\",\"**\"\r\n");
ESP8266.setTimeout(5000);
char expectedResponse[] = "WIFI CONNECTED\r\n";
if (ESP8266.find(expectedResponse) == 1) {
Serial.println("WIFI CONNECTED");
timer++;
if (timer > 3) {
timer = 0;
Serial.println("Still attempting to connect..");
PHP Script currently just tries to get the data. I just want it to output anything on that echo statement, which it currently is not doing.
<?php
$data = json_decode(file_get_contents('php://input'), true);
echo "Received JSON Data: " . $data . "<br>";
