cannot find a class or type named gregoriancalendar
i am trying to make a clock with arduino and processing…
my arduino code:
 * TimeSerial.pde
 * example code illustrating Time library set through serial port messages.
 * Messages consist of the letter T followed by ten digit time (as seconds since Jan 1 1970)
 * you can send the text on the next line using Serial Monitor to set the clock to noon Jan 1 2010
 T1262347200
 * A Processing example sketch to automatically send the messages is inclided in the download
#include <Time.h>
#define TIME_MSG_LEN  11   // time sync to PC is HEADER followed by unix time_t as ten ascii digits
#define TIME_HEADER  'T'   // Header tag for serial time sync message
#define TIME_REQUEST  7    // ASCII bell character requests a time sync message
void setup()  {
  setSyncProvider( requestSync);  //set function to call when sync required
  Serial.println("Waiting for sync message");
void loop(){
  if(Serial.available() )
    processSyncMessage();
  if(timeStatus()!= timeNotSet)
    digitalWrite(13,timeStatus() == timeSet); // on if synced, off if needs refresh
    digitalClockDisplay();
void digitalClockDisplay(){
  // digital clock display of the time
  Serial.print(hour());
  printDigits(minute());
  printDigits(second());
  Serial.print(" ");
  Serial.print(day());
  Serial.print(" ");
  Serial.print(month());
  Serial.print(" ");
  Serial.print(year());
void printDigits(int digits){
  // utility function for digital clock display: prints preceding colon and leading 0
  Serial.print(":");
  if(digits < 10)
    Serial.print('0');
  Serial.print(digits);
void processSyncMessage() {
  // if time sync available from serial port, update time and return true
  while(Serial.available() >=  TIME_MSG_LEN ){  // time message consists of a header and ten ascii digits
    char c = Serial.read() ;
    Serial.print(c);
    if( c == TIME_HEADER ) {
      time_t pctime = 0;
      for(int i=0; i < TIME_MSG_LEN -1; i++){
        c = Serial.read();
        if( c >= '0' && c <= '9'){
          pctime = (10 * pctime) + (c - '0') ; // convert digits to a number
      setTime(pctime);   // Sync Arduino clock to the time received on the serial port
time_t requestSync()
  Serial.print(TIME_REQUEST,BYTE);
  return 0; // the time will be sent later in response to serial mesg
my processing code:
 * SyncArduinoClock.
 * portIndex must be set to the port connected to the Arduino
 * The current time is sent in response to request message from Arduino
 * or by clicking the display window
 * The time message is 11 ASCII text characters; a header (the letter 'T')
 * followed by the ten digit system time (unix time)
import processing.serial.*;
public static final short portIndex = 1;  // select the com port, 0 is the first port
public static final char TIME_HEADER = 'T'; //header byte for arduino serial time message
public static final char TIME_REQUEST = 7;  // ASCII bell character
public static final char LF = 10;     // ASCII linefeed
public static final char CR = 13;     // ASCII linefeed
Serial myPort;     // Create object from Serial class
  size(200, 200);
  println(Serial.list());
  println(" Connecting to -> " + Serial.list()[portIndex]);
  myPort = new Serial(this,Serial.list()[portIndex], 9600);
void draw()
  if ( myPort.available() > 0) {  // If data is available,
    char val = char(myPort.read());         // read it and store it in val
    if(val == TIME_REQUEST){
       long t = getTimeNow();
       sendTimeMessage(TIME_HEADER, t);
       if(val == LF)
           ; //igonore
       else if(val == CR)
         println();
         print(val); // echo everying but time request
void mousePressed() {
  sendTimeMessage( TIME_HEADER, getTimeNow());
void sendTimeMessage(char header, long time) {
  String timeStr = String.valueOf(time);
  myPort.write(header);  // send header and time to arduino
  myPort.write(timeStr);
long getTimeNow(){
  // java time is in ms, we want secs
  GregorianCalendar cal = new GregorianCalendar();
  cal.setTime(new Date());
  int	tzo = cal.get(Calendar.ZONE_OFFSET);
  int	dst = cal.get(Calendar.DST_OFFSET);
  long now = (cal.getTimeInMillis() / 1000) ;
  now = now + (tzo/1000) + (dst/1000);
  return now;
but when i click run button in processing i get this error “cannot find a class or type named gregoriancalendar”
Can you please help me solve this…
but when i click run button in processing i get this error "cannot find a class or type named gregoriancalendar" Can you please help me solve this..
Where do you expect this:
to find the definition of the class?
Forgot to add import
import java.util.Date;
import java.util.Calendar;
import java.util.GregorianCalendar;
