Cannot find Device ID and PAC on my MKRFOX1200 package
I bought Arduino MKR FOX 1200 (ABX00014) and now i need to register the device od Sigfox sites. I need device ID and PAC to complete registration, but i couldn't findt it. Should it be located on package or printed directly on the board?
Hello,
you have to use the first configuration code so you can see your ID and PAC from your board.
SigFox First Configuration
This sketch demonstrates the usage of MKRFox1200 SigFox module.
Since the board is designed with low power in mind, it depends directly on ArduinoLowPower library
This example code is in the public domain.
#include <SigFox.h>
#include <ArduinoLowPower.h>
while (!Serial) {};
// Uncomment this line and comment begin() if you are working with a custom board
//if (!SigFox.begin(SPI1, 30, 31, 33, 28, LED_BUILTIN)) {
if (!SigFox.begin()) {
Serial.println(“Shield error or not present!”);
return;
// Enable debug led and disable automatic deep sleep
// Comment this line when shipping your project :slight_smile:
SigFox.debug();
String version = SigFox.SigVersion();
String ID = SigFox.ID();
String PAC = SigFox.PAC();
// Display module informations
Serial.println(“MKRFox1200 Sigfox first configuration”);
Serial.println("SigFox FW version " + version);
Serial.println("ID = " + ID);
Serial.println("PAC = " + PAC);
Serial.println("");
Serial.print("Module temperature: ");
Serial.println(SigFox.internalTemperature());
Serial.println(“Register your board on https://backend.sigfox.com/activate with provided ID and PAC”);
delay(100);
// Send the module to the deepest sleep
SigFox.end();
Serial.println(“Type the message to be sent”);
while (!Serial.available());
String message;
while (Serial.available()) {
message += (char)Serial.read();
// Every SigFox packet cannot exceed 12 bytes
// If the string is longer, only the first 12 bytes will be sent
if (message.length() > 12) {
Serial.println(“Message too long, only first 12 bytes will be sent”);
Serial.println("Sending " + message);
// Remove EOL
message.trim();
// Example of message that can be sent
// sendString(message);
Serial.println(“Getting the response will take up to 50 seconds”);
Serial.println(“The LED will blink while the operation is ongoing”);
// Example of send and read response
sendStringAndGetResponse(message);
void sendString(String str) {
// Start the module
SigFox.begin();
// Wait at least 30mS after first configuration (100mS before)
delay(100);
// Clears all pending interrupts
SigFox.status();
delay(1);
SigFox.beginPacket();
SigFox.print(str);
int ret = SigFox.endPacket(); // send buffer to SIGFOX network
if (ret > 0) {
Serial.println(“No transmission”);
Serial.println(“Transmission ok”);
Serial.println(SigFox.status(SIGFOX));
Serial.println(SigFox.status(ATMEL));
SigFox.end();
void sendStringAndGetResponse(String str) {
// Start the module
SigFox.begin();
delay(100);
SigFox.status();
delay(1);
SigFox.print(str);
int ret = SigFox.endPacket(true); // send buffer to SIGFOX network and wait for a response
if (ret > 0) {
if (SigFox.parsePacket()) {
Serial.println(“Response from server:”);
while (SigFox.available()) {
Serial.print(“0x”);
Serial.println(SigFox.read(), HEX);
Serial.println(“Could not get any response from the server”);
Serial.println(“Check the SigFox coverage in your area”);
Serial.println(“If you are indoor, check the 20dB coverage or move near a window”);
SigFox.end();
