Cannot find -larm_cortexM0l_math
I have been getting this error and I am not exactly sure what is going wrong. I am using an Adafruit Feather M0 with RFM95 LoRa Radio. Any help is much appreciated.
c:/users/evans/appdata/local/arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/bin/ld.exe: cannot find -larm_cortexM0l_math
collect2.exe: error: ld returned 1 exit status
exit status 1
Compilation error: exit status 1
Here is the code:
#include <arm_math.h>
#include <lmic.h>
#include <hal/hal.h>
#include <SPI.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#include <Wire.h>
#include <Adafruit_ADS1X15.h>
#include <DHT.h>
#define DHTTYPE DHT11    // Temp sensor type
#define topTemp 11       // Pin for top box temp sensor
#define bottomTemp 12    // Pin for bottom box temp sensor
#define outTemp 13       // Pin for outside temp sensor
int voltage = A0;        // Pin for voltage reader
int fanControl = A1;     // Pin for box fans
Adafruit_ADS1X15 ads;    // ADC sensor initialization
Adafruit_ADS1X15 shunt;  // Shunt sensor initialization
const float FACTOR = 30; //20A/1V from teh CT
const float multiplier = 0.0005; // Multiplier for ADC conversion
#    Temperature Sensors Definitions     #
DHT sensors_1(topTemp, DHTTYPE);       // Used for defining top box temp sensor
DHT sensors_2(bottomTemp, DHTTYPE);    // Used for defining bottom box temp sensor
OneWire oneWire(outTemp);              // Used for defining outside temp
DallasTemperature sensors_3(&oneWire); // Used for defining outside temp
// This EUI must be in little-endian format, so least-significant-byte
// first. When copying an EUI from ttnctl output, this means to reverse
// the bytes. For TTN issued EUIs the last bytes should be 0xD5, 0xB3,
// 0x70.
static const u1_t PROGMEM APPEUI[8] = {0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00};
void os_getArtEui (u1_t* buf) { memcpy_P(buf, APPEUI, 8);}
// This should also be in little endian format, see above.
static const u1_t PROGMEM DEVEUI[8] = {0x5D, 0x63, 0x04, 0xD0, 0x7E, 0xD5, 0xB3, 0x70};
void os_getDevEui (u1_t* buf) { memcpy_P(buf, DEVEUI, 8);}
// This key should be in big endian format (or, since it is not really a
// number but a block of memory, endianness does not really apply). In
// practice, a key taken from the TTN console can be copied as-is.
static const u1_t PROGMEM APPKEY[16] = {0xE2, 0xD1, 0xBA, 0xFC, 0x9B, 0x82, 0xA5, 0x00, 0x10, 0xA6, 0xE8, 0xD0, 0x50, 0x95, 0x94, 0x86};
void os_getDevKey (u1_t* buf) {  memcpy_P(buf, APPKEY, 16);}
// payload to send to TTN gateway
static uint8_t payload[13];
static osjob_t sendjob;
// Schedule TX every this many seconds (might become longer due to duty
// cycle limitations).
const unsigned TX_INTERVAL = 180;
// Pin mapping for Adafruit Feather M0 LoRa
const lmic_pinmap lmic_pins = {
    .nss = 8,
    .rxtx = LMIC_UNUSED_PIN,
    .rst = 4,
    .dio = {3, 6, LMIC_UNUSED_PIN},
    .rxtx_rx_active = 0,
    .rssi_cal = 8,              // LBT cal for the Adafruit Feather M0 LoRa, in dB
    .spi_freq = 8000000,
void printHex2(unsigned v) {
    v &= 0xff;
    if (v < 16)
        Serial.print('0');
    Serial.print(v, HEX);
void onEvent (ev_t ev) {
    Serial.print(os_getTime());
    Serial.print(": ");
    switch(ev) {
        case EV_SCAN_TIMEOUT:
            Serial.println(F("EV_SCAN_TIMEOUT"));
        case EV_BEACON_FOUND:
            Serial.println(F("EV_BEACON_FOUND"));
        case EV_BEACON_MISSED:
            Serial.println(F("EV_BEACON_MISSED"));
        case EV_BEACON_TRACKED:
            Serial.println(F("EV_BEACON_TRACKED"));
        case EV_JOINING:
            Serial.println(F("EV_JOINING"));
        case EV_JOINED:
            Serial.println(F("EV_JOINED"));
              u4_t netid = 0;
              devaddr_t devaddr = 0;
              u1_t nwkKey[16];
              u1_t artKey[16];
              LMIC_getSessionKeys(&netid, &devaddr, nwkKey, artKey);
              Serial.print("netid: ");
              Serial.println(netid, DEC);
              Serial.print("devaddr: ");
              Serial.println(devaddr, HEX);
              Serial.print("AppSKey: ");
              for (size_t i=0; i<sizeof(artKey); ++i) {
                if (i != 0)
                  Serial.print("-");
                printHex2(artKey[i]);
              Serial.println("");
              Serial.print("NwkSKey: ");
              for (size_t i=0; i<sizeof(nwkKey); ++i) {
                      if (i != 0)
                              Serial.print("-");
                      printHex2(nwkKey[i]);
            // Disable link check validation (automatically enabled
            // during join, but because slow data rates change max TX
            // size, we don't use it in this example.
            LMIC_setLinkCheckMode(0);
        case EV_JOIN_FAILED:
            Serial.println(F("EV_JOIN_FAILED"));
        case EV_REJOIN_FAILED:
            Serial.println(F("EV_REJOIN_FAILED"));
        case EV_TXCOMPLETE:
            Serial.println(F("EV_TXCOMPLETE (includes waiting for RX windows)"));
                if( ( LMIC.txrxFlags & ( TXRX_DNW1 | TXRX_DNW2 ) ) != 0 )
        Serial.print( "Received downlink\r\n");
            if (LMIC.txrxFlags & TXRX_ACK)
              Serial.println(F("Received ack"));
            if (LMIC.dataLen) {
              Serial.println(F("Received "));
              Serial.println(LMIC.dataLen);
              Serial.println(F(" bytes of payload"));
            // Schedule next transmission
            os_setTimedCallback(&sendjob, os_getTime()+sec2osticks(TX_INTERVAL), do_send);
        case EV_LOST_TSYNC:
            Serial.println(F("EV_LOST_TSYNC"));
        case EV_RESET:
            Serial.println(F("EV_RESET"));
        case EV_RXCOMPLETE:
            // data received in ping slot
            Serial.println(F("EV_RXCOMPLETE"));
        case EV_LINK_DEAD:
            Serial.println(F("EV_LINK_DEAD"));
        case EV_LINK_ALIVE:
            Serial.println(F("EV_LINK_ALIVE"));
        case EV_TXSTART:
            Serial.println(F("EV_TXSTART"));
        case EV_TXCANCELED:
            Serial.println(F("EV_TXCANCELED"));
        case EV_RXSTART:
            /* do not print anything -- it wrecks timing */
        case EV_JOIN_TXCOMPLETE:
            Serial.println(F("EV_JOIN_TXCOMPLETE: no JoinAccept"));
        default:
            Serial.print(F("Unknown event: "));
            Serial.println((unsigned) ev);
void printMeasure(String prefix, float value, String postfix)
  Serial.print(prefix);
  Serial.print(value, 3);
  Serial.println(postfix);
void do_send(osjob_t* j){
    // Check if there is not a current TX/RX job running
    if (LMIC.opmode & OP_TXRXPEND) {
        Serial.println(F("OP_TXRXPEND, not sending"));
          Serial.println("Do send else");
        #    Reading Voltage Sensor    #
        float voltagevalue = analogRead(voltage)/46.602;
        #    Reading Temperature Sensors     #
        sensors_3.requestTemperatures();               // Request temp for outside
        float out = sensors_3.getTempFByIndex(0);      // Temp for outside
        float top = sensors_1.readTemperature(true);   // Temp for top box
        float bot = sensors_2.readTemperature(true);   // Temp for bottom box
        #    Reading Output Current     #
        float currentRMS = getcurrent();
        float maxCurrent;
        int16_t results;
        results = ads.readADC_SingleEnded(2);
        // Getting maximum current value
        for (int i=0;i<=5;i++){
        if (maxCurrent <= currentRMS){
          maxCurrent = currentRMS;
        #    Reading Charging Current     #
        float amps = ((float)results * 256.0) / 32768.0; //100mv shunt
        amps = amps * 0.53;
        #    Printing Sensors In Serial    #
        Serial.print("Top Temp: "); Serial.print(top);           // Display temp for top box
        Serial.print("\n");
        Serial.print("Bot Temp: "); Serial.print(bot);           // Display temp for bottom box
        Serial.print("\n");
        Serial.print("Out temp: "); Serial.print(out);           // Display temp for outside
        Serial.print("\n");
        Serial.print("Voltage: "); Serial.print(voltagevalue);   // Display voltage from battery
        Serial.print("\n");
        printMeasure("Ouput Current: ", maxCurrent, "A");        // Display adc current
        Serial.print("Charing Current: ");                       // Display shunt current
        Serial.println(amps);
        #     Fan Control    #
        if (top > 85 || bot > 85){
          digitalWrite(fanControl, HIGH);
          Serial.print("FAN ON");
        else {
          digitalWrite(fanControl, LOW);
        ##    TTN Settings For Sending Payload    ##
        #     Adjust for the f2sflt16 range (-1 to 1)   #
        top = top / 100;
        bot = bot / 100;
        out = out / 100;
        maxCurrent = maxCurrent / 100;
        amps = amps / 100;
        voltagevalue = voltagevalue / 100;
        #    float -> int    #
        // note: this uses the sflt16 datum (https://github.com/mcci-catena/arduino-lmic#sflt16)
        uint16_t payloadTempTop = LMIC_f2sflt16(top);
        uint16_t payloadTempBot = LMIC_f2sflt16(bot);
        uint16_t payloadTempOut = LMIC_f2sflt16(out);
        uint16_t payloadCurrent = LMIC_f2sflt16(maxCurrent);
        uint16_t payloadAmps = LMIC_f2sflt16(amps);
        uint16_t payloadVoltage = LMIC_f2sflt16(voltagevalue);
        #    int -> bytes    #
        byte lowTopBox = lowByte(payloadTempTop);
        byte highTopBox = highByte(payloadTempTop);
        byte lowBotBox = lowByte(payloadTempBot);
        byte highBotBox = highByte(payloadTempBot);
        byte lowOut = lowByte(payloadTempOut);
        byte highOut = highByte(payloadTempOut);
        byte lowVoltage = lowByte(payloadVoltage);
        byte highVoltage = highByte(payloadVoltage);
        byte lowCurrent = lowByte(payloadCurrent);
        byte highCurrent highByte(payloadCurrent);
        byte lowAmps = lowByte(payloadAmps);
        byte highAmps = highByte(payloadAmps);
        #    Place the bytes into the payload    #
        payload[0] = lowTopBox;
        payload[1] = highTopBox;
        payload[2] = lowBotBox;
        payload[3] = highBotBox;
        payload[4] = lowOut;
        payload[5] = highOut;
        payload[6] = lowVoltage;
        payload[7] = highVoltage;
        payload[8] = lowCurrent;
        payload[9] = highCurrent;
        payload[10] = lowAmps;
        payload[11] = highAmps;
        #    Prepare upstream data transmission at the next possible time.                                          #
        #    transmit on port 1 (the first parameter); you can use any value from 1 to 223 (others are reserved).   #
        #    don't request an ack (the last parameter, if not zero, requests an ack from the network).              #
        #    Remember, acks consume a lot of network resources; don't ask for an ack unless you really need it.     #
        LMIC_setTxData2(1, payload, sizeof(payload) - 1, 0);
    // Next TX is scheduled after TX_COMPLETE event.
    delay(5000);
    Serial.println(F("Starting"));
    pinMode(fanControl, OUTPUT);
    pinMode(voltage, INPUT);
    sensors_1.begin(); // Initialize top temp sensor
    sensors_2.begin(); // Initialize bottom temp sensor
    sensors_3.begin(); // Initialize outside temp sensor
    ads.setGain(GAIN_FOUR);      // +/- 1.024V 1bit = 0.5mV
    shunt.setGain(GAIN_FOUR);
    ads.begin();
    shunt.begin();
    // LMIC init
    os_init();
    // Reset the MAC state. Session and pending data transfers will be discarded.
    LMIC_reset();
    // Disable link-check mode and ADR, because ADR tends to complicate testing.
    // Set the data rate to Spreading Factor 7.  This is the fastest supported rate for 125 kHz channels, and it
    // minimizes air time and battery power. Set the transmission power to 14 dBi (25 mW).
    LMIC_setDrTxpow(DR_SF7,14);
    // in the US, with TTN, it saves join time if we start on subband 1 (channels 8-15). This will
    // get overridden after the join by parameters from the network. If working with other
    // networks or in other regions, this will need to be changed.
    LMIC_selectSubBand(1);
    // Start job (sending automatically starts OTAA too)
    do_send(&sendjob);
  os_runloop_once();
float getcurrent()
  float voltage;
  float current;
  float sum = 0;
  long time_check = millis();
  int counter = 0;
  while (millis() - time_check < 1000)
    voltage = ads.readADC_Differential_0_1() * multiplier;
    current = voltage * FACTOR;
    //current /= 1000.0;
    sum += sq(current);
    counter = counter + 1;
  current = sqrt(sum / counter);
  return (current);
What Arduino? What code? Please read the guidelines for posting.
